Fluid static problem with wooden block being pulled down
The discussion revolves around a fluid statics problem involving a wooden block and a metal object suspended by a cord. The wooden block has specific dimensions and specific gravity, while the metal object has a defined volume. Participants are tasked with finding the mass of the metal object and the tension in the cord, working with gage pressure.
  • Participants discuss the forces acting on the wooden block, including weight, buoyant force, and tension. There is uncertainty about how these forces interact and affect calculations. Questions arise regarding the calculation of specific weight and the application of pressure in the context of the problem.
Some participants have suggested identifying the forces acting on the wooden block as a starting point. There is recognition of the need to understand Archimedes' principle, although not all participants are familiar with it. The conversation indicates a mix of attempts to clarify concepts and explore the problem without reaching a consensus.
Participants express uncertainty about the concepts of fluid statics and the forces involved, indicating a potential gap in prior knowledge that may affect their ability to solve the problem.
tonnieee
The figure below shows a metal object (2) hanging by a thin cord from a floating wooden block (1). The wood block has a SG of 0.3 and dimensions of 50mm x 50mm x 10mm. The metal part as a volume of 6600m^3. Find the mass of the metal part and the tension in the cord. Work in gage pressure.
Specific weight = W / m^3
Pressure = specific weight X h = pgh
W = mg
I find pressure on the point at the bottom of the wooden block - P = 9810 X 0.01
If I am not wrong, that is the tension in the cord ? But I am totally unsure on how to go about solving the mass of the metal part. I suspect that I need to use specific weight = W / V since they gave volume. But how am I suppose to find the specific weight ? Thanks..[/B]
I suggest starting by identifying the forces acting on each object. What forces act on the wooden block?
Force acting downwards by its weight and the metal block? The force acting upwards by the cord ? But how these are going to affect my calculations hmm
Three forces act on the wooden block: buoyant force, weight, tension in the cord. What must they add to?
You calculated the pressure at the bottom of the block. Pressure is not a force, for one. And you neglected the weight of the block.
Doc Al said:
Three forces act on the wooden block: buoyant force, weight, tension in the cord. What must they add to?You calculated the pressure at the bottom of the block. Pressure is not a force, for one. And you neglected the weight of the block.
Is there a way to find the forces ? I was not really taught about this in fluid statics.
Have you heard of Archimedes principal?
No
tonnieee said:
No
Well, you need to learn about that before you can solve this problem.
He was the head of the school young Archimedes attended, right?
Ha! Good one.
