Fluid Statics/depth in a cylinder
6 replies · 4K views · last reply
tennisgirl92
Mercury is added to a cylindrical container to a depth d and then the rest of the cylinder is filled with water. If the cylinder is 0.8 m tall and the pressure at the bottom is 1.3 atmospheres, determine the depth of the mercury. (Assume the density of mercury to be 1.36
104 kg/m3.)
Ptotal=Patmosphere+Pwater+Pmercury
P=density x g x height
1 atmosphere=1.013e5 Pa
density of water=1 x 103 kg/m3
pressure of atmosphere=1 atm
I first subtracted out the pressure of the atmosphere, so
.3 atm=Pwater + Pmercury
.8m=Hwater + Hmercury
Pmercury=1.36 x 104 x 9.8 x Hmercury
Pwater=1 x 103 x 9.8 x Hwater
I am having difficulty putting all 4 of these equations together. I feel like there is substitution needed, but which equations should I use?
Perhaps you should be more systematic, Starting with your equation
substitute
Pwater=ρwaterg hwater
Pmercury=ρmercuryg hmercury
and solve for hmercury.
tennisgirl92 said:
Mercury is added to a cylindrical container to a depth d and then the rest of the cylinder is filled with water. If the cylinder is 0.8 m tall and the pressure at the bottom is 1.3 atmospheres, determine the depth of the mercury. (Assume the density of mercury to be 1.36 View attachment 195815 104 kg/m3.)
You have 4 linear algebraic equations in 4 unknowns. Are you familiar with Gaussian elimination?
substitute
Ok, if I do that
.3atm=(1000 x 9.8 x Hwater) + (1.36 x 104 x 9.8 x Hmercury)
I still need to find the height of water, right? Where would that come from?
No, never heard of that. What is Gaussian elimination?
Since the cylinder is filled to the top,
Height of water = height of cylinder - height of mercury
thank you! Got it!
