Flywheel problem with limited data? Is it possible?
  • Thread starter Thread starter RichMortimer
    Data Flywheel
The discussion revolves around a physics problem involving a solid circular flywheel and a mass attached to a string. Participants explore the relationship between the distance fallen by the mass, its velocity, and the rotational velocity of the flywheel, using the principle of conservation of energy. The focus is on deriving an equation that relates these variables, despite limited initial data.
  • Homework-related
  • One participant expresses confusion about how to start solving the problem without specific values for height, inertia, or time, and seeks guidance on substitution methods.
  • Another participant suggests that the distance the mass drops directly relates to the unwinding of the rope, establishing a connection between the falling mass's speed and the rotational speed of the wheel.
  • There is a discussion about needing to find a connection between potential and kinetic energy to relate the variables, with some participants emphasizing the importance of the conservation of energy equation.
  • One participant realizes that they do not need specific values for height or velocity, as they are unknowns in the equation provided.
  • A later post indicates that a participant has derived the equation correctly, confirming their understanding of the relationship between the variables involved.
Participants generally agree on the approach to use conservation of energy to relate the variables, but there is some initial confusion about how to manipulate the equations without specific values. The discussion reflects a process of clarification and refinement of understanding rather than a definitive conclusion.
Participants express uncertainty about how to derive certain values and the implications of the variables in the conservation of energy equation. The discussion highlights the need for additional information regarding inertia and the relationship between linear and rotational motion.
RichMortimer
A solid circular flywheel around which a string is wrapped. At the end of the string is a 2 kg mass. If the mass is dropped, the drum will rotate.
After the mass has fallen h metres, it has a velocity of v m/s and the wheel has a rotational velocity of ω rad/s
The flywheel radius is 120 mm. Use principle of conservation of energy to show that the distance fallen h, and the velocity v, are related by the equation h = v^2(0.051+1.77xI)
Right then,
Firstly, please don't give the answer as I would like to work it out. However, I'm a little lost on the direction to go.
Conservation = mgh = 1/2mv^2+1/2Iω^2
We have no height, Inertia, radius of gyration or time... So how can we start?
I've thought about substitution but do I just pluck a number? See's to random to do that?!
I'm assuming I can substitute equations into the above equation but yet still don't seem to have the relevant information.
As I said, not after the answer, just a kick in the right direction if possible.
P.S. That's all the information... no more!
Thanks in advance.
I think the key insight here is that for every cm that the mass drops, this much rope unwinds. And for every cm of rope unwound, a point on the circumference of the wheel moves by this same distance. Can you see that?
If so, you have a relationship between the speed of the falling mass, and the speed moved by a point on the outside edge of the wheel. You also have a relationship between this tangential speed, and the rotational speed of the wheel.
Hello cepheid,
Thanks for the reply.
I initially thought something similar, using the radius. However, unless I "create" a height and time value I can't see how I relate to the function h = v^2(0.051+1.77xI)
I'm assuming I can somehow find a connection between the above values and a PE or KE combination but still looking!
Thanks again.
RichMortimer said:
Hello cepheid,
Thanks again.
You have this equation:
All you have to do is solve it for h and plug in numbers. The only additional info that you need is how v (the speed at which the object falls) relates to ω (rotation speed of the wheel). I explained how in my first post.
So would you just pick a random height? Or try working backwards from the given equation?
I'll try again in the morning and re-post.
See where we get to!
Thanks,
Night.
Thanks,
Night.
I don't understand what you're asking. You don't need to pick any height. As stated in the problem, "h" is the distance by which the thing has fallen. So mgh (potential energy lost) = (1/2)mv2 + (1/2)Iω2 (kinetic energy gained by mass and flywheel). Solve for h.
A clear rested mind is a wonderful thing!
I've just read your last post... I realize that I had indeed been asking the wrong question!
I don't need a value for h or v as they are unknown in the given equation!
I'll have a go at the question again and feed back.
Once again, thank you!
Ok, sorry about quality, just easier than trying to type it all out!
See attached...
I feel like I'm nearly there but I'm not sure how to bring the 2*g*m*r^2 out from below. I know I'm on the right lines as I can equate the 0.051 required but as yet figured where the 1.77 has come from.
Please can you confirm that I'm right up until now.
I'll keep trying.
Haaaaaaaaaaaaa haaa!
Just got it!
I must be a singular. Therefore there is a 1 in front. 1/0.565 = 1.77 :-D Therefore:
h=(v^2(m*r^2+I)) / (2*g*m*r^2) is equal to h=v^2(0.051+1.77*I) Wow.
Thanks again cepheid... :)
Glad to see that you figured it out.
  • · Replies 20 ·
