Force and Constant Acceleration Problem
22 replies · 3K views
sb13
Sunjamming. A “sun yacht” is a spacecraft with a large sail that is pushed by sunlight. Although such a push is tiny in everyday circumstances, it can be large enough to send the spacecraft outward from the Sun on a cost-free but slow trip. Suppose that the spacecraft has a mass of 780 kg and receives a push of 23 N. (a) What is the magnitude of the resulting acceleration? If the craft starts from rest, (b) how far will it travel in 1 day and (c) how fast will it then be moving?
F= ma
And the equations for motion with constant acceleration:
v=vo+at
x-xo= volt+ 1/2at^2
v^2= vo^2+2a(x-xo)
x-xo= 1/2(vo+v)t
x-xo=vt-1/2at^2
I understand how to solve for the magnitude of acceleration in (a)
a= F/m = 23/780 =0.029487 m/s^2
But for the (b), I don't know how I would find the meters that the spacecraft travels in one day if all I have is acceleration which does have time units but they are squared, and then I would use one of the constant acceleration equations, but I need more information.
If I were to figure out the answer to (b) which is the time (t), then I think I could just plug it into one of those equations and easily get the velocity for (c).
Could someone help me with part (b) please?
x-xo= vo+ 1/2at^2
This equation is incorrect. How can you add/subtract velocity from distance? Units of terms in equations MUST be uniform.
Use the correct version of this equation to determine how far it travels in a specified time.
Those are the equations that my Physics book gave me. I did forget to include the t which is multiplied by the initial velocity, but I don't know where I could find the "correct" equations if those equations are not usable.
That is what I was getting at. You left the 't' out.
That equation enables one to compute the displacement when a object that may or may not be moving is accelerated at a constant rate. All you have to do is use it with the correct units.
Do I need to convert seconds to days? Because I am not sure how to do that when the the units are s^2.
You have computed the acceleration in terms of m/sec^2. So if you choose to use those units in the equation
x = V0*t + 0.5*a*t^2
you must determine how many seconds there are in a day. If, on the other hand, you had determined the acceleration rate in terms of m/day^2, then you can plug it in directly. You will get the same answer.
The V0 accounts for the fact the object is already moving. If it is not, the term vanishes.
It cannot be overstressed how important units are when using equations. Many years ago when I was a student, I did not comprehend that. As I progressed in my studies and professional career, I realized how important units are. They keep you 'out of trouble'.
Oh! Thank you so much. That was my main problem. I just was worried because I ended up with days^2 and I thought that would mess things up.
So for (c) I tried the equation v=vo + at to find the velocity, but it is not giving the correct answer. The initial velocity is equal to zero, and the acceleration is equal to 0.029487 m/s^2, but I want the time to be in seconds so that it will cancel off one of the seconds leaving just m/s right? Which means the time equals one? That doesn't give the correct answer and that just means the acceleration is equal to the velocity. What do I do?
Did you determine how many seconds there are in a day?
I got the correct distance of 1.1006 X 10^8, and for the time I converted seconds squared to days squared by multiplying by (3600^2)(24^2). In the equation of x-xo = volt+ 1/2at^2, I assumed that the initial velocity and initial distance was zero. Is that correct?
For the velocity with a zero initial velocity the equation reduces to
v = a*t
If a is .029 m/sec^2, the velocity is gotten from plugging the number of seconds in a day into the above equation.
sb13 said:
Yeah. Well, the acceleration was 0.029, so I got 1.1006 X 10^8 for the distance, but that is what I did. In the equation of x-xo = volt+ 1/2at^2, I assumed that the initial velocity and initial distance was zero. Is that correct?
I get something close to that but not that exactly. Your assumptions are correct.
You didn't get exactly 1.1006X10^8 for the distance?
But, I do need the velocity to be in m/s.
Here are my numbers:
x = .5 a t^2 = .5*.029*(3600*24)^2=1.08X10^8
Where do we differ?
The only difference is that I carried out the significant digits on my acceleration.
(0.5)(0.029487)(3600*24)^2 = 1.1006 X 10^8
Good, then that part is finished. Did you get the velocity part yet?
Well, I did end up getting the correct velocity. But I am wondering why I couldn't get the right answer with the v=vo + at formula
v=vo + at= (0.029487m/s^2)(1s)? Is one second the time? Then the velocity equals the acceleration, and that's not the right answer.
I tried v^2= vo^2 + 2a(x-xo), and that gave me the correct answer though. But, why do they give different answers? They aren't supposed to are they?
So v^2 = 0 + 2(0.029487 m/s^2)(1.1006X10^8 m) = 6.49068X10^6 m^2/s^2, so v = square root of 6.49068X10^6 = 2547.08 m/s
When I took the square root of the number, it took away the squares of the meters and seconds right?
The question asks how fast will it be moving after a day of accelerating.
Ok. So does that mean that the equation that I choose to use to determine the velocity should include the distance (x)?
Yes. If you use the other equation where V = at you'll get the same result.
V = .029487*(3600*24)=2547.6 m/sec
V = sqrt(2*.029487*1.1006X10^8)=2547.6 m/sec
Oh. So I was not supposed to square the (3600 * 24) then I guess. Thanks.
The equation is
V = a * t
If you were to square the time, you would not wind up with the units of m/sec.
Other questions?
Nope. I finally understand it completely.
