Force applied by someones hand on a lever
The discussion revolves around estimating the force that a person's hand can apply to the tip of a lever in the context of redesigning a bicycle wheel quick release lever. Participants explore force diagrams, assumptions in calculations, and the role of torque in the mechanics of the lever system.
  • Homework-related
  • One participant seeks a rough estimate of the force a hand can exert on a lever for calculating the force on a locking mechanism, noting difficulty in finding sources.
  • Another participant suggests that the maximum static force one can apply is equal to one's weight.
  • A participant questions the assumptions in their force diagram, specifically regarding the resistance force caused by friction and whether torque needs to be considered.
  • One participant describes the operation of quick release devices, emphasizing the hand grip principle and references documented hand grip strength.
  • Another participant advises that all forces and moments must be summed to find the missing force, indicating that torque must be taken into account for accurate calculations.
  • There is a request for clarification on the mechanics and connections in the lever system, with a suggestion to label the diagram for better understanding.
Participants express differing views on the necessity of considering torque in the calculations, with some emphasizing its importance while others seek to simplify the analysis. There is no consensus on the exact force values or assumptions to be made in the force diagram.
Limitations include potential missing assumptions regarding the lever mechanics, dependence on specific definitions of forces, and unresolved steps in the mathematical calculations related to torque and force relationships.
sitting_duck
I am redesigning a bicycle wheel quick release lever for a design project. I am trying to put together a force diagram as part of the project and I need to know the average force someones hand could apply to the tip of the lever to calculate the force exerted on the locking mechanism. Could anyone point me in the direction of a rough estimate of the force someones hand could exert, sources would be great but I haven't found anything after extensive googling.
Thanks
Thanks
The maximum force one can apply statically is equal to one's weight.
CS
Thanks stewartcs, that will work for the calculations.
On a slightly different question. Can I make these assumptions in my force diagram?
(R is the resistance force caused by friction)
F1x(45x10^-3)=F2
F2-R=N
Or do I have to take torque into account, I'm trying to keep it as simple as possible and the project doesn't require me to go into to much detail, its more a question of if I know how to do a project then anything else.
The lever -quick release devices I am familiar with operate on a hand grip principle, the lever being pushed with the thumb against the pull of the other fingers on the rest of the wheel.
The strength of hand grip is well documented eg
http://www.brianmac.co.uk/grip.htm
F1x(45x10^-3)=F2
F2-R=N
Generally speaking, you'll need to sum all of the forces and moments acting on they body in order to find the missing force. So yes you'll need to consider the torque (i.e. moments).
F1 x (0.045) = Torque, not force. Now the torque at the fulcrum will be constant since you are applying a constant force from F1. So if you have some type of lever arrangement then you can calculated the force at F2 based on that torque (i.e. F1 x 0.045 = F2 x d). Then you'll have the horizontal force. From that you can sum the remaining horizontal forces to find the net horizontal force (magnitude and direction).
I'm not sure what parts are moving or how they are connected in your diagram. Can you label it or explain it a bit better?
CS
Sorry I didn't really explain how it works. Hopefully these pictures explain it better then words.
The first one is when the mech is open and the second when it's closed. The third the detail of the lever.
...and the exploded views, could only upload 3 files at a time.
12K
  • · Replies 65 ·
  • · Replies 18 ·
12K
