What was the average force exerted by the wall on the ball during the collision?
  • Thread starter Thread starter Nirupt
    Force Wall
The average force exerted by the wall on the ball during the collision is calculated to be 2.32 x 103 N. This value is derived using the formula F = ma, where the mass of the ball is 180 kg and the average acceleration is determined to be 1.29 x 104 m/s2. The ball, initially traveling at 25.0 m/s and rebounding at 20.0 m/s, was in contact with the wall for 3.50 ms. The correct calculation of average acceleration is crucial for determining the average force accurately.
  • Understanding of Newton's laws of motion
  • Knowledge of impulse and momentum concepts
  • Familiarity with basic physics equations, particularly F = ma
  • Ability to perform calculations involving time, mass, and velocity
  • Review the concept of impulse and its relation to momentum
  • Study detailed examples of force calculations in collision scenarios
  • Learn about the application of Newton's second law in real-world problems
  • Explore advanced topics in dynamics, such as elastic and inelastic collisions
Physics students, educators, and anyone interested in understanding the dynamics of collisions and force calculations in mechanics.
Nirupt
Above you had a ball traveling horizontally at 25.0 m/s bouncing off a brick wall and rebounding at 20.0 m/s. The ball was in contact with the wall for 3.50 ms, and you found the magnitude of the average acceleration during the time the ball was in contact with the wall. Now, what was the average force that the wall exerted on the ball during this collision, if the mass of the ball is 180
Where it says above all I solved a question asking for acceleration which was 1428.57 m/s^2
Not sure.. my only guess is that it goes with a free fall equation or an x not known since the ball was throw horizontally
Hint: Newton's laws.
\vec{F}=\frac{d\vec{p}}{dt}, this is related to impulse.
Impulse is the change in momentum.
But that's the wrong answer for the scenario in the OP.
Presumably you arrived at that by dividing the change in velocity by the time taken, Δv/Δt.
Average force is defined similarly: change in momentum divided by time taken.
I probably should have posted my optional answers:
2.32 * 10^3 N
1.61 * 10^3 N
952 N
4.06 * 10^4 N I'll post my attempt later tonight when I am home.
But you need to get the average acceleration right first. it's nearly ten times the figure you posted.
1.43 * 10^3 was the answer for acceleration
Are you saying that's the answer you got or that it is the correct answer? And are you saying it is the average acceleration for this scenario?:
(20+25)/.0035 = 1.29*104.
You appear to have calculated (25*2)/0.035.
Ah thanks for the correction. So.. this makes F = Ma easier to use correct?
1.29*10^4*180 = 2.32*10^3 N since mass and acceleration are known
That's it.
  • · Replies 23 ·
