Force needed to pull a block up an incline.
The problem involves calculating the force required to pull a 20 kg mass up an incline at a uniform slow speed, considering the angle of the incline and the coefficient of kinetic friction.
  • Participants discuss the implications of constant speed indicating no net force, and explore the calculations for friction and gravitational forces. Questions arise about whether these forces should be balanced, added, or compared to determine the required pulling force.
The discussion is ongoing, with participants exploring different interpretations of how to balance the forces involved. Some guidance has been offered regarding the relationship between the forces, but no consensus has been reached on the exact approach to take.
Participants are navigating the implications of the problem setup, including the effects of friction and the direction of forces, while adhering to the constraints of the homework context.
garfiegrl
Calculate the force needed to pull a mass of 20 kg at a uniform slow speed up a plane inclined at an angle of 30 with the horizontal if the coefficient of kinetic friction is 0.20.
WN= w cos [tex]\vartheta[/tex]
WT= w sin [tex]\vartheta[/tex]
[tex]\mu[/tex]s= tan[tex]\vartheta[/tex]
I don't even know how to get started.
If the block is moving at a constant speed then you know that there is no net force acting on the block.
so the friction force is
(.2)(20)(9.8)(cos 30) ?
and the gravitational force is
(20)(9.8)(sin 30) ?
i got 34 N for friction and 98 N for gravitational.
are they supposed to equal zero? or do i add them together to find the force i need to overcome? or could i just overcome the strongest?
So what force is needed to make them balance?
okay, so 34 N for friction pull the box up the slope, and 98 N gravity pull down.
98 N - 34 N = 64 N needed to equalize them, and more than 64 to make it move uphill?
What direction will the friction be acting in if the box is being pulled up the slope?
What is the direction of the force applied and whether the friction will depend on that direction.
If the minimum force needed is required than the force must be applied at an angle equal to angle of friction [tan^-1 (u)] with the incline.
  • · Replies 27 ·
10K
  • · Replies 19 ·
