Force of Wind from these variables
43 replies · 6K views
Jetflyer0
I have a strip of foil with an area of 10 square cm and a mass of .561392 grams. The length of the foil is 5 cm and the width is 2 cm. The foil is hanging from a pivot point at the very top. The foil rotates 17 degrees backwards from where it started. The foil is in a sealed container where no outside factors are acting on it except for this wind. I cannot figure out how much force the wind that is pushing the foil back is exerting. Any help would be greatly appreciated. Thank you.
F=ma
I have tried to find ways to solve this, but none have worked. The wind speed is so slight, an extremely sensitive anemometer won't pick it up.
Think about the first Newton's law instead of the second. Provide us with yor sketch with all the forces and angles.
Sorry it's crap, had to do on a computer using paint
The foil is not moving if the wind is constant, right? So the vectorial sum of all the forces on the foil should be zero. (This is the 1st Newton's law). Is the sum really zero in your sketch? Is there no other force?
Your sketch shows Fg acting in mid air. Where does it really act? Show it in that position with dimensions.
The wind acts on the whole piece
Where is the point of application?
I don't know, the wind is from a fan, and by the time the wind hit the foil, the wind was greatly dispersed
Wind does acts on every small piece of the foil, but the effect is the same if we assume it acts in one point? where is this point? And do not forget, one force is still missing in your sketch.
Im assuming the point is in the center, and I am pretty sure I have all the forces
Is the sum of Fwind and Fg zero?
At the time it stabilizes at 17 degrees
The force is not the force of gravity acting on it either, because the wind is blowing horizontally instead of vertically
Which force prevents the foil from falling down (because of the Fg) and to being blown away (because of the Fwind)? Where is its point of application?
srecko97 said:
Such sketches are useless.
Then why did you want me to add the force?
Fg is the force of gravity not the wind.
Look, this is a useful sketch. You need to write F_ceiling as a sum of F_ceilingX in x direction and F_ceilingY in y direction. Use sine and cosine. Then you need to eqaulise forces in x and y.
I think he means your sketch is poor.
As I said before... Where does the force of gravity act? Hint: It does not act in mid air.
As I see he has problems even with elementary forces, I assume that he is not familiar with torques. And the result can be found from writing only forces equilibrium as well...
from F_ceiling * cos 17 = F_g you get F_ceiling ...
F_wind = F_ceiling * sin17
I'll have to think about that. The angle of the reaction force at the ceiling isn't known.
I understand that you guys know more about how to solve this problem, but I am a high school student who is new to physics. I am also taking geometry this year, and we have not yet learned about sine or cos. If you could explain a way to solve this that would be easier to understand, I would be very grateful
There would be no equilibrium of forces if the angle was not the same.
continuation of my way:
F_ceiling * cos 17 =F_g
F_ceiling = F_g / cos 17
F_wind = F_ceiling * sin 17 = F_g * sin 17 / cos 17 = F_g * tan 17
calculating with torques:
r1*F_wind* cos 17 = r1 * F_g * sin 17
F_wind* cos 17 = F_g * sin 17
F_wind = F_g * sin 17 / cos 17 = Fg * tan 17
I do not see any difference, CWatters. I do not understand your scepticism
If so, I think you have set yourself a too difficult problem.
The force on the ceiling has little to do with solving this problem ?
All you actually have is a top hinged vane with wind pushing it to the left and gravity force pulling it downwards . @CWatters gave you the clue in post #22 .
You are not asked to work out how the wind generates the force so we can reasonably say that there is just an effective wind force acting at one point on the vane . Strictly we should investigate to find where that point is but for this problem just take it as being at the mid height point of the vane .
How to solve the problem without trig ? It can be done by using a graphic calculation method . Do you know how to use the parallelogram of forces ?
If there would be no F_ceiling (ceiling acts on the vane), which force would prevent the vane from falling down and being blown away? Maybe it would be better to name it F_reaction instead of F_ceiling, but name is not so important.
