Forced oscillation (mass & spring)
5 replies · 8K views
kash25
A 2 kg object attached to a spring moves without friction and is driven by an external force given by F = (3.00N)sin(2[tex]\pi[/tex]t). The force constant of the spring is 20.0N/m.
Find the amplitude of the motion.
I am not sure but I am trying to use:
A = (F0/m)/[tex]\sqrt{}(w^2-w<sub>0</sub>^2)^2[/tex]
Applying this equation using w equals 2pi and w0 is k/m (10) gives an amplitude of 0.00173. The solution in the book says 5.09cm.
Am I approaching this question correctly?
Hi kash25,
w0 is not equal to k/m. If you correct this you should get the right answer.
Not exactly sure...but that equation you have might be for forced oscillations working against friction; in this case there is no friction.
No, it's the right equation. If it was a damped spring there would be another term under the radical. Using that equation (with the corrected value for w0) gives the answer given in the post.
remember that w0 = sqrt (k/m).
That will give you the right answer :)
stupid mistake..thanks for your help!
