Forced Oscillator where Damping is Negligible
The discussion centers on solving a forced oscillator problem involving a 0.139 kg mass attached to a 7.00 N/m spring, driven by a force of 1.88 N. The goal is to determine the frequency at which the mass vibrates with an amplitude of 0.430 m. The correct approach involves using the equation A = (Fo/m) / (ω^2 - ωo^2), where ωo = √(k/m). The user initially misapplied the algebra, leading to an incorrect frequency calculation of 1.49 Hz, which was later corrected after identifying the algebraic error.
  • Understanding of harmonic motion and oscillators
  • Familiarity with the concepts of amplitude and frequency
  • Knowledge of algebraic manipulation and equations of motion
  • Basic principles of spring constants and mass-spring systems
  • Review forced oscillation equations and their applications in physics
  • Study the derivation of the amplitude formula for damped and undamped systems
  • Explore the relationship between angular frequency and frequency in oscillatory motion
  • Practice solving similar problems involving mass-spring systems and external forces
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for examples of forced oscillation problems.
Becca93
Damping is negligible for a 0.139 kg mass hanging from a light 7.00 N/m spring. The system is driven by a force oscillating with an amplitude of 1.88 N. At what frequency will the force make the mass vibrate with an amplitude of 0.430 m? There are two possible solutions, enter one of them.
A = (Fo/m) / (√((ω^2 - ωo^2)^2 + (bω/m)^2)
Damping is negligible, therefore b = 0, therefore
A = (Fo/m) / (√((ω^2 - ωo^2)^2)
ωo = √(k/m)
So,
m = 0.139 kg
k = 7.00 N/m
Fo = 1.88 N
A = 0.430 m
Rearranged to find ω, is
(ω^2 - √(k/m)^2)^2 = (Fo/m) / A
ω^2 = √((Fo/m)/A) + (k/m)
ω = √( √((Fo/m)/A) + (k/m) )
So,
ω = √( √((1.88/0.139)/0.430) + (7/0.139) )
ω = √( 1.77 + 50.3597)
ω = 7.22 rad/s
ω = 2(pi)f
7.22 /2(pi) = f
f = 1.49 Hz
This is not the correct answer and I have no idea where I'm going wrong.
Am I using the wrong equations? Are my calculations incorrect? Any assistance would be much appreciated.
You simplified ##\sqrt{(\omega^2-\omega_0^2)^2}## incorrectly.
How? I did the following:
√((ω^2 - ωo^2)^2)
Shouldn't the square root and the square cancel, leaving
(ω^2 - ωo^2)
ω^2 - (√k/m)^2
ω^2 - (k/m)
Resulting in:
Where did I go wrong?
After setting b=0 and moving some stuff around, you should have
$$A = \frac{F_0/m}{\sqrt{(\omega^2-\omega_0^2)^2}} = \frac{F_0/m}{\omega^2-\omega_0^2}$$My take was that you ended up with
$$A = \frac{F_0/m}{\sqrt{(\omega^2-\omega_0^2)^2}} = \frac{F_0/m}{(\omega^2-\omega_0^2)^2}$$ (compare to "(ω^2 - √(k/m)^2)^2 = (Fo/m) / A" which is what you wrote in your first post) which leads to the incorrect answer.
If you check the units on your result, you'll see they don't work out. That means you messed up the algebra somewhere.
Ahh, yes, I see what I did. I did mess up the algebra without noticing. I had it straight in my head but not on paper.
Thank you very much for pointing that out for me. I've got the correct answer now.
