Forces at an angle to one another.
  • Thread starter Thread starter SherlockOhms
    Angle Forces
A particle with a mass of 2 kg is subjected to two forces of 12 N and 8 N acting at a 60-degree angle to each other. The correct approach to solve for the particle's acceleration involves decomposing the forces into their vector components. The 12 N force can be represented as F = (12, 0) N, while the 8 N force is decomposed into components based on the 60-degree angle. The resultant force is calculated using Pythagoras' theorem, leading to the determination of both the magnitude of acceleration and its direction relative to the 12 N force.
  • Understanding of Newton's second law (F = ma)
  • Knowledge of vector decomposition and component analysis
  • Familiarity with trigonometric functions (sine and cosine)
  • Ability to apply Pythagorean theorem in vector addition
  • Learn vector decomposition techniques in physics
  • Study the application of Newton's laws in multi-force systems
  • Explore trigonometric identities and their use in physics problems
  • Investigate advanced topics in dynamics, such as resultant forces and acceleration
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of force analysis in two-dimensional systems.
SherlockOhms
A particle of mass 2kg is moving under the action of two forces. They
are of magnitudes 12N and 8N, acting at an angle of 60
to each other. Find
the magnitude of the acceleration of the particle and its direction relative to the
direction of the 12N force.
F = ma.
I know that this isn't actually a tricky problem but I can't seem to think it out properly.
Am I correct in decomposing both the 12N and 8N forces into vector form, i.e. 12cos60i = 12sin60j and 8cos60i + 8sin60j respectively. Then summing them and calculating both the magnitude and direction using tanθ = vj/vx. Is this correct? I'm sort of confused by the whole "relative to the 12N force" part. Thanks.
I think for this problem, assume the direction of the 12N force is a convenient reference, say F = (12, 0) N, so that this force acts in the positive x-direction. Then, the 8N force acts in a direction such that the angle with F is 60 degrees. Then, you can decompose into components and find the resultant before figuring the effect on the particle. In the OP, you had both force vectors heading in the same direction.
I don't really know what you're doing with is vector thing. I believe the best way to solve this would be to find the total force in the direction along the 12N, and the total force perpendicular to it. Then use Pythagoras' theorem.
I understand what you're saying. Sounds correct to me like. Thanks.
I'm not too sure what you have in mind. I can't think of anyway to solve this without the use of vectors. I'm struggling to visualise what you have in mind.
