Forces on symmetrical electrostatic charges
The discussion focuses on calculating the forces acting on three point charges located at L(-b, b), M(b, b), and N(0, 0) with charges Q, -3Q, and Q, respectively. The primary objective is to determine the net force on the charge at the origin using Coulomb's Law, expressed as F = 1/4∏ε0 (Q1Q2/r^2) r(hat). The user struggles with the vector components of the forces between the charges and seeks advice on simplifying the calculations, particularly in deriving the x- and y-components of the force.
  • Coulomb's Law for electrostatic forces
  • Vector algebra for force component calculations
  • Trigonometric functions, specifically for angles in triangles
  • Understanding of charge interactions in electrostatics
  • Study the derivation and application of Coulomb's Law in electrostatics
  • Learn how to resolve forces into x- and y-components using vector algebra
  • Explore the properties of triangles formed by point charges in electrostatic configurations
  • Investigate the geometric interpretation of forces in electrostatics for simplification
Students and educators in physics, particularly those focusing on electrostatics and vector analysis, as well as anyone needing to solve problems involving multiple point charges and their interactions.
Roodles01
3 point charges L(-b, b) M(b, b) & N(0, 0) have charges Q, -3Q & Q.
I need to find the force on the charge at the origin.
Coulomb's Law important, here. F = 1/4∏0 q^2/r^2 r(hat)
z-component no existent (from coordinates given)
x- & y-components to be found
Now, I'm finding it difficult to see thew wood from the trees with this relatively simple thing. I'm trying to find the x- & y- bits of force between the charges 1 & 2 to the charge at the origin for each charge.
Now, F = 1/4∏ε0 ((Q(2b*-cos45)*Q)/(2cos45)) - (-3Q(2b*cos45)/(2cos45)
Then factor out the Q^2/r^2 terms.
I would like it in the form F=1/4∏ε0 (Q^2/r^2) (!ex - !ey) but am finding the (!ex - !ey) bit difficult to get due to the trig bits I think.
Advice needed, please.
I'm sure this is wrong, but is the main stumbling block.
If I can get this then magnitude of force & direction of unit vector will be easy.
For this problem it would probably be simpler to go right to the geometry rather than deal with a purely vector algebra approach. From the charge locations, what can you say about the type of triangle they form? Do you know anything about angles and sides for such triangles?
The other thing I will point out is that the Coulomb force law applies between two charges, Q1 and Q2 (not Q2 unless both charges happen to be equal). So the magnitude of the force is:
F = k \frac{Q_1 Q_2}{r^2} ~~~~~~~\text{where}~~~~k = \frac{1}{4 \pi \epsilon_o}
