Average Force Formula - Solving for Force
The average force required to stop a 6.0 g bullet traveling at 350 m/s in 1.8 ms is calculated using the impulse-momentum theorem. The formula for average force is derived from the change in momentum divided by the change in time, represented as F = Δp / Δt. In this case, the change in momentum (Δp) is 2100 kg·m/s, leading to an average force of approximately -1.2 x 10^3 N when rounded. This calculation confirms the teacher's provided answer.
  • Understanding of impulse-momentum theorem
  • Basic knowledge of momentum and force equations
  • Familiarity with unit conversions (grams to kilograms)
  • Ability to perform calculations involving time in milliseconds
  • Study the impulse-momentum theorem in detail
  • Learn how to convert units, specifically from grams to kilograms
  • Explore real-world applications of average force calculations in ballistics
  • Practice solving problems involving momentum and force using different scenarios
This discussion is beneficial for physics students, educators teaching mechanics, and professionals in fields related to ballistics and force analysis.
wyclefchick
[SOLVED] Formula for average force?
In a ballistics test at the police department, Officer Rios fires a 6.0 g bullet at 350 m/s into a container that stops it in 1.8 ms. What is the average force that stops the bullet?
can anyone help me to do this? or just give me the formula? The teacher gave us the right answer and it's -1.2 x 10^3N
The average force is the change in momentum divided by the change in time.
This is just an impulse-momentum theorem problem. Impulse = Change in momentum. Impulse is F*delta t (t=time of impact) and change in momentum is just final momentum - initial momentum. Good luck
delta p= J
and J= F(delta t)
so
delta p=6.0g(350m/s)
delta p=2100
2100/1.8=1166.6666667
is that the same thing as 1.2x10^3?
wyclefchick said:
delta p= J
and J= F(delta t)
so
delta p=2100
It would be rounded to 1.2x10^3, yes.
thank you so much guys!
You're welcome (I'll speak on behalf of the people that actually helped you! :smile:)
  • · Replies 19 ·
29K
