FORTRAN calculator program with input and operation functions
6 replies · 3K views
mattmac.nuke
Alright, so I've updated it once more... The only thing I need to do is figure out how to convert the functions x_data, y_data and choi_1 that store all 3 of the inputs I need for the main program and other functions.
program calculator
IMPLICIT NONE
REAL :: addition, subtraction, multiplication, division, x, y, j, k, x_data, y_data !x = A, y = B
CHARACTER :: choice, a, b, c, d, l, choi_1WRITE (*,*) ' '
WRITE (*,*) 'LAB 6- Baby Calculator'
WRITE (*,*) '----------------------'j = x_data(x)
k = y_data(y)
l = choi_1(choice)
SELECT CASE (l)
CASE ('A','a')
WRITE (*,*) 'A+B = ', addition (x, y)
CASE ('B','b')
WRITE (*,*) 'A-B = ', subtraction (x, y)
CASE ('C','c')
WRITE (*,*) 'A*B = ', multiplication (x, y)
CASE ('D','d')
WRITE (*,*) 'A/B = ', division(x, y)
END SELECT
end program calculator
CHARACTER FUNCTION choi_1 (choice)
IMPLICIT NONE
CHARACTER :: choice
WRITE (*,*) ' A) A+B'
WRITE (*,*) ' B) A-B'
WRITE (*,*) ' C) A*B'
WRITE (*,*) ' D) A/B'
WRITE (*,*) 'Enter choice:'
READ (*,*) choice
choi_1 = choice
END FUNCTION choi_1
REAL FUNCTION x_data (x)
IMPLICIT NONE
REAL :: x
WRITE (*,*) 'Enter a value A:'
READ (*,*) x
x_data = x
END FUNCTION x_data
REAL FUNCTION y_data (y)
IMPLICIT NONE
REAL :: y
WRITE (*,*) 'Enter a value B:'
READ (*,*) y
y_data = y
END FUNCTION y_dataREAL FUNCTION addition (x, y)
IMPLICIT NONE
REAL, INTENT(IN) :: x, y
addition = x + y
END FUNCTION addition
REAL FUNCTION subtraction (x, y)
IMPLICIT NONE
subtraction = x - y
END FUNCTION subtraction
REAL FUNCTION multiplication (x, y)
IMPLICIT NONE
multiplication = x*y
END FUNCTION multiplication
REAL FUNCTION division (x, y)
IMPLICIT NONE
IF ( y == 0) THEN
division = 0
ELSE
division = x/y
END IF
END FUNCTION division
program calculator
IMPLICIT NONE
WRITE (*,*) ' '
j = x_data(x)
k = y_data(y)
l = choi_1(choice)
SELECT CASE (l)
CASE ('A','a')
CASE ('B','b')
CASE ('C','c')
CASE ('D','d')
END SELECT
IMPLICIT NONE
CHARACTER :: choice
READ (*,*) choice
choi_1 = choice
END FUNCTION choi_1
IMPLICIT NONE
REAL :: x
READ (*,*) x
x_data = x
END FUNCTION x_data
IMPLICIT NONE
REAL :: y
READ (*,*) y
y_data = y
END FUNCTION y_data
IMPLICIT NONE
addition = x + y
IMPLICIT NONE
subtraction = x - y
IMPLICIT NONE
IMPLICIT NONE
IF ( y == 0) THEN
division = 0
ELSE
division = x/y
END IF
You're missing the READDATA function, so there should be a function with this name. From your PDF, the specification is:
Create a FUNCTION READDATA that will ask the user to enter real numbers A and B and a character CHOICE and stores that data in variables A and B and returns CHOICE.
Instead of having two functions - x_data and y_data - that each read a number from input, write a single function with two parameters that returns a character. This function should prompt the user to enter two numbers and a character that represents the choice of operation.
I've written it as one function now, but after making a choice selection it tells me I'm missing a left parenthesis in format.
program calculator
IMPLICIT NONE
WRITE (*,*) ' '
READ choi_1(x, y, choice)
SELECT CASE (l)
CASE ('A','a')
CASE ('B','b')
CASE ('C','c')
CASE ('D','d')
END SELECT
CHARACTER FUNCTION choi_1 (x, y, choice)
IMPLICIT NONE
CHARACTER :: choice
REAL :: x, y
READ (*,*) x
READ (*,*) y
READ (*,*) choice
choi_1 = choice
END FUNCTION choi_1
IMPLICIT NONE
addition = x + y
IMPLICIT NONE
subtraction = x - y
IMPLICIT NONE
IMPLICIT NONE
IF ( y == 0) THEN
division = 0
ELSE
division = x/y
END IF
It's this line:
This is not how to call this function. What you want is something like
Code:
choice = choi_1(x, y, choice)
BTW, you have way too many character variables.
Code:
Get rid of a, b, c, d, and l. You aren't using a, b, c, or d, so they should not be in your program.
You also have way too many numeric variables; namely, x, y, j, k, x_data, y_data. Get rid of all but two of these. Having extra variables makes your program needlessly confusing, especially to you.
Also, you should pick a better name for your function than choi_1, which is silly. A better name would be GetInput.
When calling a FUNCTION, the syntax is VARIABLE = FUNCTION (Arg1. Arg2, ...)
In the main program section, your FUNCTION calls need correction.
Also, you have READ CHOI_1 () and CHARACTER FUNCTION CHOI1 (). You cannot have the same name assigned to a variable and a FUNCTION at the same time.
Another possibility is to use the returned value from the function, such as in a call to WRITE; e.g.,
WRITE *,* ADDITION(x, y)
The one in the READ statement definitely needs to be fixed. The others are OK.
I really appreciate all the help guys! I actually wound up debugging it during class. I discovered that I can reference the function in my case statements, where all 3 of the data inputs can be used in the arguments and computations. The TA's were amazed that it worked...
Now I have a slightly trivial question, you know how the cursor moves to the next line following a WRITE statement where there is a READ execution, well I need for the cursor to remain on the same line in which the WRITE statement was made. I believe the slash descriptor is used to do this, but I can't seem to apply it correctly, could you perhaps show me a simple example of it's use, where the user is prompted to enter a simple real number?
