Fortran How to Pass and Combine Arrays in Fortran g77?
  • Thread starter Thread starter mazinse
    Fortran
The discussion addresses several key points regarding array manipulation in Fortran. First, to determine the index of non-zero cells in an array, a do-loop can be used to iterate through each cell and count non-zero values. For passing an entire array to a function, the correct syntax is 'call function(array)', which passes the address of the array rather than its contents. It is noted that standard Fortran 77 lacks intrinsic functions for array operations like merging or copying, although some newer compilers like g77 may offer additional functionalities. Concerns about seeing many zeros when writing an array to a file suggest that if non-zero values were stored, the zeros might indicate uninitialized or empty cells. To clarify issues, providing a specific code example is recommended. Additionally, when passing multi-dimensional arrays, the leading dimension must be specified to ensure proper array storage layout in the subroutine.
mazinse
1. Is there a way to get the index of array, how many cells are nonzeros and have actual data. I can probably do it the hard way.
2. How do you pass an array to a function, the entire array I mean, do I do like function (array(i)) or function (array())
3. Is there an easier way to combine two arraries.
If there are libraries or functions out there that I can call to, lease help
Technology news on Phys.org
Write a do-loop that tests each cell one at a time, and increments a counter each time it finds a nonzero cell.
Neither way. Use 'call function (array)'.
Easier than what?
easier than write a loop, checks every cell for value then add them all to a new array.
but I have a new question. When I write my array to a file, I see a lot of 0's, are they empty cells or something else
With older Fortran compilers, only the addresses of paramters were passed to subroutines. I don't know if this has changed. If it hasn't, then function(array) just passes the address of the array, not the contents of the array.
I'm pretty sure standard Fortran 77 doesn't have intrinsic functions for array operations (copy, merge, etc.). g77 might add some such functions, but you'd have to search through the g77 documentation.
If you stored non-zeroes in all the array cells, then you shouldn't get any zeroes on output. But it's hard to say whether anything is wrong because your description is vague. Can you post a specific code example that demonstrates what you're talking about? It would be best if you can post a short complete compilable program that doesn't do anything else.
Also, when you pass an array, you're passing the starting address of the array, ie, a reference to the first element of the array. Hence, for a vector, you can pass any valid "starting address" within the array by specifying the array element, for example
Code:
Call MySubProgram(MyVector(2))
or
Code:
MyVar = MyFunction(MyVector(2))
This passes a reference to the vector MyVector element 2 to your subprogram or function. Your subprogram or function then sees MyVector starting with element 2 as defined in the main
Also, when passesing multi-dimensioned arrays, you must also pass the physical dimension of the column length so that the subprogram can resolve the array storage layout. For example, passing a two dimensioned array such as
Code:
c      MAIN
       REAL  MyArray2(10,20)
c      variable "LDA" is "Leading dimension of Array"
       INTEGER LDA
       LDA = 10
       CALL MySubProgram(MyArray2, LDA)
       Subroutine MySubProgram(Array, L)
       INTEGER L
       REAL Array(L,1)
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 31 ·
