FORTRAN, open several files and read it
  • Context: Fortran
  • Thread starter Thread starter vikincarioca
    files Fortran
20 replies · 37K views
vikincarioca
Hi pals I'm using fortran program to open several files like iso1.dat,iso2.dat... iso9.dat withis this files are number that I can read with my program, but I don't know how can I open the files above and then read it
this is my simple code
Code:
      implicit real*8(a-h,o-z)
      parameter(nx=100)
      dimension y(nx),eta(nx),iso(nx)
      integer::nl1,i,n
      character*60 dumi
      nl1=9
	do i=1,8
      open(10,file='iso00.dat')
	end do
      do i=1,nl1
      read(10,fmt=*)dumi
      end do
	DO n=1,5
      read(10,fmt=*)i,y(n),eta(n),j,k,p,q,s
      write(*,'(2d14.6)')y(n),eta(n)
	END DO
      stop
	end
In this code
Code:
do i=1,8
end do
you are attempting to open the same file 8 times. Since you want to open 8 different files, I don't see any way of doing that in a loop. Instead, what you should do is open the first file, read the data you need from it, then close the file. After that, do the same with the second file, then the third, and so on.
There are a couple ways of opening files in a DO loops. The easiest is to just open them prior to the DO loop, and then just reading unit number of the do iterator, e.g.
Code:
OPEN(11,file...)
OPEN(12,file...)
OPEN(13,file...)
OPEN(14,file...)
DO i=1,4
 ii = i + 10
 READ(ii,*) ...
END DO
There is a better way to do it with an arbitrary number of files, but if this works, then its easiest.
Code:
OPEN(11,file...)
OPEN(12,file...)
OPEN(13,file...)
OPEN(14,file...)
DO i=1,4
 ii = i + 10
 READ(ii,*) ...
END DO
Thanks for your replied but I need to do the same steps for 400 files so How can I do it, for instance
Code:
DO I=1,400
OPEN(I,file=' ISO?.DAT'...) HERE IS MY PROBLEM HOW CAN I OPEN FILES AS ISO1,ISO2...ISO400
END DO
DO i=1,4
 ii = i + 10
 READ(ii,*) ...
END DO
looking forward for a replied
I had actually started a thread a little while back that you can see below in the similar threads. You'll basically want something like:
Code:
      CHARACTER(len=12) :: FN
      N=5 !--arbitrary number of files
      DO I=1,N
      WRITE(FN,10)I
      WRITE(6,*)FN
      OPEN(1,FILE=FN)
      CLOSE(1)
      END DO
   10 FORMAT('ISO',I2.2,'.DAT')
      STOP
      END
This should open a file according to the format statement, i.e. ISOxx.DAT...then just do whatever you got to do.
following your tips I compile the program and it worked, but I need to read and stored the dates in another file,well I thought It wouldn't difficult but I was wrong, so further details of my code is
Code:
      parameter(nx=100)
      integer::nl1,i,j,k
      character(len=12)::fn
      n=5  !arbitrary number of files
      nl1=9
   10 format('iso',i2.2,'.dat')
	do i=2,n
	write(fn,10)i
	write(6,*)fn
	open(1,file=fn)
	do j=1,nl1
	read(1,fmt=*)dumi  THIS LINE  READ THE CHARACTERS
	end do
	do k=1,5
	read(1,fmt=*)w,y(k),eta(k),p,q,s,t,r THIS LINE SHOULD BE STORE MY DATAS IN 2 VECTORS
	end do
	close(1)
	end do
      stop
	end
something is wrong in this code,but I can't get to see :-(
any tip to help me please
RG
Im going to explain what I need to do.
First I would like to open 400 files e.g ISO1.dat,..ISO400.dat, within this files I have datas which means numbers for instance( X,Y,Z are vectors)
ISO1.dat has X1,Y1,Z1 vectors
ISO2.dat has X1,Y2,Z2 vectors
ISO3.dat has X1,Y3,Z3 vectors
I only need to read X and Y
then write in a unique file X1,Y1,Y2,Y3...Y400
How Can I do it
Hope to be clear this time
Tks
As Jeff mentioned, it'll be a lot easier if your files are ISO001, rather than just ISO1. Using that method, you can just open another file
Code:
      PROGRAM
      IMPLICIT NONE
      INTEGER :: n
      REAL,DIMENSION(:),ALLOCATABLE :: x,y,z
      n=400
      OPEN(11,file='output.dat',form='formatted')
      !--allocate your vectors here
      DO I=1,N
      WRITE(FN,10)I
      WRITE(6,*)FN
      OPEN(1,FILE=FN)
      READ(1,*) x,y,z
      WRITE(11,*) x,y
      CLOSE(1)
      END DO
   10 FORMAT('ISO',I3.3,'.DAT')
      DEALLOCATE( x,y,z )
      END PROGRAM
hey thanks for your replied, One more question since my vector X,Y,Z has 5 elements so what I need to do is a loop
Code:
      PROGRAM
      IMPLICIT NONE
      INTEGER :: n
      n=400
      DO I=1,N
      WRITE(FN,10)I
      WRITE(6,*)FN
      OPEN(1,FILE=FN)
      DO j=1,5
      READ(1,*) x(J),y(J),z(J)   HERE I STORED MY VECTORS WITH ITS ELEMENTS
      WRITE(11,*) x(J),y(J)
      END DO
      CLOSE(1)
      END DO
      DEALLOCATE( x,y,z )
      END PROGRAM
it is what I think
Many thanks
Hi Pals I got to read the files finally :-) and the write in one file in this case output.dat
[code\]
PROGRAM eta
implicit none
integer ::n,i,j
real,dimension(:),allocatable::x,y,z,u,v,w,p,f
n=3 !NUMBER OF FILES
open(11,file='output.dat',form='formatted') !allocate your vectors here
allocate (x(5),y(5),z(5),u(5),v(5),w(5),p(5),f(5))
DO i=1,n !LOOP FOR THE NUMBER OF FILES
write(fn,10)i
write(6,*)fn
open(1,file=fn)
do j=1,5
read(1,*)x(j),y(j),z(j),u(j),v(j),w(j),p(j),f(j)
write(11,*)y(j),z(j)
end do
close(1)
END DO
10 format('iso',i3.3,'.dat')
deallocate(x,y,z,u,v,w,p,f)
END PROGRAM eta
Code:
but I have one problem in the output I wrote vector X1 three times and then vector Y1 follow Y2 and Y3 in one column, I would like to write it in this shape
X1 Y1 Y2 Y3...Y400 it means 400 columns
Can you suggest me something I am really close what I want, just I need a bit help please
Rather than having your write statement inside your second DO loop, just put it after, e.g.
Code:
write(fn,10)i
write(6,*)fn
open(1,file=fn)
do j=1,5
end do
close(1)
END DO
write(11,*)x(1),y(:)
After it reads in the vectors for an individual file, it will write out the first X variable, followed by the entire Y vector.
Code:
write(fn,10)i
write(6,*)fn
open(1,file=fn)
do j=1,5
end do
close(1)
END DO
Hi it works I got to write my vectors Y1 and Z1,Z2,Z3... with its elements, this is a result
Code:
  -20.50000      -13.50000      -6.500000       7.500000       14.50000    this is   Y1
   1.450721       1.410950       1.247190       1.258387       1.406754     this is    Z1
   1.320300       1.294613       1.176677       1.187839       1.292512    this is     Z2
   1.228186       1.202048       1.076701       1.095856       1.203530    this is     Z3
that's good but now i have the last question I think how can write the elements of Y1,Z1,Z2,Z3 as a column and not as a above, I tried differents formats but I can't get to write as I wish. Is there any special format?
You should really get a Fortran book and start from page 1. In order to write those as a column and not a row, you can loop over the vector writing out a single entry each time.
In fact, that's what you were doing in post 11. If you want, you can use a counter variable and store the entire XYZ values (all of them from each file) in a separate file, and write it out at the end...the possibilities are numerous.
Yeah I did what you suggested me but I got this
Code:
  -20.50000       1.450721
  -13.50000       1.410950
  -6.500000       1.247190
   7.500000       1.258387
   14.50000       1.406754
  -20.50000       1.320300
  -13.50000       1.294613
  -6.500000       1.176677
   7.500000       1.187839
   14.50000       1.292512
  -20.50000       1.228186
  -13.50000       1.202048
  -6.500000       1.076701
   7.500000       1.095856
   14.50000       1.203530
[\code]
all together but this is what I don't wish, I want Y1,Z1,Y1,Z2,Y1,Z3 or if I could get to write it as:Y1,Z1,Z2,Z3 would be better but I dude that i can write it out in that way, anyway FORTRAN is a big complicated
Thanks for your discussion which was really helpful to my work... AND THANKS TO PHYSICS FORUMS
Dear all!
i have collected 1000 numbers of gridded rainfall data. The name file of that file are like 2007_01_01_01, 2007_01_01_02, ......(1000 files)
I want to read all data file and want to calculate average of each grid of that file as a output.
more details, main problem for me is how to read and write all these data( because, there is not good solution to open individually 1000 files and to write 1000 times)
so I need your guide and suggestion as soon
I tired by like
program test
implicit none
integer,parameter :: nrow = 240
integer,parameter :: ncol = 324
real rain(nrow,ncol)
real,allocatable:: rain(:,:)
real,allocatable:: Avg_rain(:,:)
integer i,j,k
integer dis, size
inquire(iolength=dis) rain(1,1)
inquire(iolength=dis) avg_rain(1,1)
size = nrow*ncol*dis
open(22,file='2007_01_01_01.bin',form='unformatted ',access='direct',recl=size)
!( problem is here how to open and read all rest 999 files)
open(33,file='avg_rain.bin',form='unformatted',acc ess='direct',recl=size)
! how to read alll those files and each grid cell to calculate average of each gird of rainfall
read(22,rec=1)((rain(i,j),i=1,nrow),j=1,ncol)
close(22)
read(33,rec=1)((Avg_rain(i,j),i=1,nrow),j=1,ncol)
close(33)
do i=1,nrow
do j=1,ncol
Avg_rain(i,j)= avg( how to write for those 1000 files)
end program test
I am hoping for good suggestion from you...
shaktipande
Hi!
I have a problem i don't have any information about column of my data in separate files.
How can I allocate such column x,y ,which has ex.isooo1:(1310),is0002:(1186),... row of data.
my code:
DO I=1,200
WRITE(A,10)I
WRITE(6,*)A
OPEN(1,FILE=A,IOSTAT=OPENSTATUS,STATUS='OLD')
IF(STATUS==0) THEN
DO j=1,SIZE(X)
read(1,*,END=200)x(j),y(j)
200 write(11,*)x(j),y(j)
END DO
close(1)
ELSE
STOP "****CANNOT OPEN FILE****"
END IF
! END DO
END DO
10 FORMAT('iso',I3.3,'.dat')
what about writing the output in multiple files? I have a program to read number of of data files, process them and have to write the output in multiple files. May anyone share the idea please?
Minger , I want to say Thanks you for your support in this problem !. really.
