[fortran90] have problem in real array index
3 replies · 13K views
s_hy
hi all...i have problem in understanding in array index. my codes are as below
Code:
subroutine  tmz2d
implicit none
double precision                   :: phi
double precision                   :: cosphi,sinphi
double precision                   :: d,dp,dpp,d1,d2
integer                            :: i,j,m,h
integer                            :: minit,mlast
integer                            :: l,p
integer                            :: iinit,ilast,hlast,pinit,plast
integer                            :: n
integer                            :: linit,llast
integer                            :: jinit,jlast
double precision,dimension(200)    :: Hm,Em
double precision                   :: Einc,Hinc
double precision,dimension(200,200):: Ezinc,Hxinc,Hyinc
double precision, parameter        :: pi = 3.14159265
character(len=20)                  :: filename
 minit = 1
 mlast = 100
 linit = 1
 llast = 100
 pinit = 1
 plast = 100
 iinit = 1
 ilast = 100
 jinit = 1
 jlast = 100
 phi = pi/4.0
 cosphi = cos(phi)
 sinphi = sin(phi)
 print *, 'cosphi=',cosphi,'sinphi=',sinphi
do n = 1,100
  write (filename, "('data',I3.3,'.dat')") n
  open (unit=130,file=filename)
 call bg1d
 !print *, 'see me2'
  do m = 2,2*ilast-1
    do p = 2,2*jlast-1
      if (Mod(m,2)/=0) then
	if (Mod(p,2)/=0) then
         d = cosphi*(m - minit) + sinphi*(p - pinit)
         dp = d - int(d)
         Einc = (1-dp)*Em(int(d))+dp*(Em(int(d)+1))
         Ezinc(m,p+2) = Einc
         write(130,*) Ezinc(m,p+2)
        end if
      end if
    end do
  end do
  do m = 2,2*ilast-1
    do p = 2,2*jlast-1
      if (Mod(m,2) == 0) then
	if (Mod(p,2) == 0) then
         dpp = d+1
         dp = dpp-int(d)
           Hinc = (1-dp)*Hm(int(dpp)-0.5)+dp*Hm(0.5+int(dpp))
           Hxinc(m,p+1) = sinphi*Hinc
           Hyinc(m-1,p+2) = -cosphi*Hinc
        end if
      end if
    end do
  end do
end do !n
print *, 'see me3'
end subroutine tmz2d
and i got this warning when execute
subroutines.f90:167.48:
Warning: Extension: REAL array index at (1)
subroutines.f90:167.28:
the problem come from line 167 and i found out that fortran do not allow real index...(int(dpp) -0.5)..can anyone give me an advice how to solve this problem.
thank you in advance
The obvious answer (which should remove the warning, but doesn't have to be correct for your problem) is to use int(dpp-0.5) - right now you are converting dpp to an int, then subtracting (or adding) 0.5 converting it back to a real. Do the subtraction first, conversion to an int later.
O.k., you found out that Fortran does not allow "real" index; more precisely, it allows a "real argument" but the final index needs to be integer...to that end, it allows a "real argument" which gets automatically typecast into an integer. If "real argument" wasn't allowed, you would get a compiler "error" instead of a "warning".
Say, is there a chest of drawers in your room? Does it have drawer 1.37?...It's the same with arrays.
thanks Borek, its worked and removed the warning
thanks gsal for the explanation..i am really new in fortran90
