Fortran95 datafile extraction help
  • Context: Fortran
  • Thread starter Thread starter eth
    Extraction Fortran95
5 replies · 3K views
eth
Hello,
I'm pretty new to fortran95 and I've run into a stuck point extracting data from a file, here's what's up:
I have a file test.dat that has 2 columns and variable number of rows (different experiments will yield different amounts of points). I want to put the data into a matrix of equivalent dimensions as the file, if possible. My main issue is that since I won't be able to know the number of rows in the datafile, the "read" command crashes the program at the end of the file-reading.
datafile looks like this, with around 50000 rows:
Code:
   2        14.2000
   1        17.9000
   1        27.7000
   2        28.8000
   1        44.3500
   2        43.5000
   2        58.2500
   1        58.3500
   1        72.6700
   2        72.6500
The fortran code I have right now looks like:
Code:
      double precision datamatrix(200000,2)
      open(unit=9,file='data/test.dat')
      read(9,901) datamatrix
  901 format(F10.4,F10.4)
I think I'm in need of a command that finds how many rows are in the textfile
help please! Thanks!
Dr Transport said:
Look for an End of file (EOF) character.
eek, can someone offer further explanation?
Dr Transport said:
My other suggestion is to use a while-loop...
what should it be "while"ing for?
btw I'm using
gfortran
ubuntu 8.04
if anyone needed to know that...
Read() has an optional 3rd parameter. Since not all Fortran compilers have while loops I used goto:
Code:
      integer i,n
      i = 0
100   i = i+1
      read(9, 901, END=101) datamatrix[i,1],datamatrix[i,2]
      goto 100
101   n = i
or
Code:
      integer i,n
      integer sts
      i = 0
100   i = i + 1
      read(9, 901, IOSTS=sts) datamatrix[i,1],datamatrix[i,2]
      if(sts .NE. 0) goto 101
      goto 100
101   n = i
While loops will go until you reach the exit condition and are the preferred way to read a file where you don't know how long it is, which is what you indicated in the original post.
as pseudo code
while (not end of file)
read line into matrix
end of while
in C++ it looks like
Code:
while ( x < 10 ) { // While x is less than 10
    cout<< x <<endl;
    x++;             // Update x so the condition can be met eventually
Thanks all, I got it working. I was just missing the end= command.
