Fourier Series Coefficient Symmetries
8 replies · 3K views
Marcus95
Let ## f(x) = \frac{a_0}{2} + \sum_{n=1}^{\infty} (a_n \cos nx + b_n \sin nx) ##
What can be said about the coefficients ##a_n## and ##b_n## in the following cases?
a) f(x) = f(-x)
b) f(x) = - f(-x)
c) f(x) = f(π/2+x)
d) f(x) = f(π/2-x)
e) f(x) = f(2x)
f) f(x) = f(-x) = f(π/2-x)
Sine is odd and cosine is even. Even functions can only contain cosine terms and odd functions only sine terms in their Fourier Series.
Here is how far I have gotten:
a) All b=0 because even function
b) All a=0 because odd function
c) Funtion has period π/2 (?)
d) Funtion has period π/2-2x (?)
e) Function has period x (not neccessarily the shortest period)
f) All b=0 because even function.
But here I am stuck, because I have no idea how to relate the coefficients to the period in c)-f), and in c)-e) I don't know if the funtion is odd or even.
Many thanks for any help! :)
a) f(x) = f(-x)
b) f(x) = - f(-x)
c) f(x) = f(π/2+x)
d) f(x) = f(π/2-x)
e) f(x) = f(2x)
Use the identities for sin and cos:
## sin(x+y)=sin(x)cos(y)+sin(y)cos(x) ##
## cos(x+y)=cos(x)cos(y)-sin(x)sin(y) ##
for the different for terms in the sum. What is happening with ##a_n## and ##b_n## for odd and even values of ##n##?
By putting different values for ##y## you can study the different cases in c), d), e) and f).
Hello! Thanks for your help!
Alright, I tried using the formulas in case c):
##\sin(\pi/2 +x) = \cos x##
##\cos(pi/2 +x) = -\sin x##
which is as expected. However, I am confused about how this should be applied to the problem. We have a general function ##f(x)## and I can't really see how the above properties reveal anything about the coefficients.
Yes, but this is only valid for ##n=1##. What do you get for ##cos n(\pi/2+x)## and ##sin n(\pi/2+x)##, for ##n## odd and even? You can then write the Fourier serie for ##f(\pi/2+x)## and simplify the sum. An advice is to split into odd and even ##n##. I hope this helps.
Alrigth, I feel like the solution is close but I am still not really there. I have found the following:
##\sin n(\pi/2 +x) = \pm \cos nx## for odd n
##\sin n(pi/2 +x) = \pm \sin nx## for even n
##\cos n(\pi/2 +x) = \pm \cos nx## for even n
##\cos n(pi/2 +x) = \pm \sin nx## for odd n
But to me these are still "just" some trigonometric identities which I don't know how to apply to the function.
You can write the above relations as
##\sin n(\pi/2+x)=(-1)^{(n-1)/2}\cos nx ##
##\sin n(pi/2 +x) = (-1)^{n/2} \sin nx## for even n
##\cos n(\pi/2 +x) = (-1)^{(n-1)/2} \cos nx## for even n
##\cos n(pi/2 +x) =-(-1)^{n/2} \sin nx## for odd n
Furthermore, we can write
##f(\pi/2+x)=\frac{a_0}{2} + \sum_{n=1}^{\infty} (a_n \cos n(\pi/2+x) + b_n \sin n(\pi/2+x)) ##,
Can you now see how to use the above trignometric identies?
It is also convenient to split the sum into odd and even values of ##n##, i.e. something like ##\sum_{n=1}^{\infty}=\sum_{odd\: n}+\sum_{even\: n}##. It is then convenient to introduce a variable ##k## through ##n=2k+1## (for the sum over odd ##n##) and similarly ##n=2k## (for even n).
Hmm, I think there migth be an algebraic miss in the exponents in your previous post. shouldn't it be:
##\sin n(\pi/2+x)=(-1)^{n/2}\cos nx ## for odd n
##\sin n(\pi/2 +x) = (-1)^{(n-1)/2} \sin nx## for even n
##\cos n(\pi/2 +x) = (-1)^{n/2} \cos nx## for even n
##\cos n(\pi/2 +x) =-(-1)^{(n-1)/2} \sin nx## for odd n?
Nevertheless,
##f(x) = f(\pi/2+x)=\frac{a_0}{2} + \sum_{n=1}^{\infty} (a_n' \cos n(\pi/2+x) + b_n' \sin n(\pi/2+x)) ##,
Supposed we have odd n, that would imply: ##a_n' \cos n(\pi/2 +x) = a_n'( -(-1)^{(n-1)/2} \sin nx)## and ##b_n' \sin n(\pi/2+x)= b_n'(-1)^{n/2}\cos nx ##. But exactly what is this telling us? Just that:
##a_n = b_n'(-1)^{n/2}## and ##b_n = -a_n'(-1)^{(n-1)/2)}##? (I use prime to note that it is the coefficients for ##f(\pi/2+x)##, and unprimed for ##f(x)##)
Is this helpful at all?
Nevertheless,
Yes, I did a typo while writing my previous post. Thanks for pointing this out. First, first I don't think you should not introduce other coefficients for ##f(\pi/2+x)## since the function ##f## is the same on both sides. By comparing term by term the series for ##f(\pi/2+x)## and ##f(x)## you get as said
##-(-1)^{(n-1)/2}a_n=b_n## and ##(-1)^{(n-1)/2}b_n=a_n## if ##n## is odd. But this can only be satisfied if ##a_n=b_n=0##. Now, for even ##n## one has ##(-1)^{n/2}a_n=a_n## and ##(-1)^{n/2}b_n=b_n##. So, we must have ##(-1)^{n/2}=1## or ##a_n=b_n=0##. Therefore, we have only non-zero ##a_n## and ##b_n## for ##n## being a multiple of 4. We have thus
##f(x)=a'_0/2+\sum_{n=1}^{\infty}(a'_n\cos(4nx)+b'_n\sin(4nx))##, where
##a'_n=a_{4n}## and ##b'_n=b_{4n}##. As is discussed on the page http://mathworld.wolfram.com/FourierSeries.html this correspond to a function with period ##\pi/2## which you already concluded from the beginning. This was maybe a long way to see this. But, I hope you are now able to proceed with the other parts of the exercise.
Thank you very much for the help! I managed to solve all the problems except for the case when ## f(x) = f(2x)##, because here the trigonometric relations are much more complicated with squares and mixed terms. Do you have any last advice for this case?
