Fourier Series of a step function
The discussion focuses on deriving the Cosine Fourier Series for a step function defined on the interval [0, 4]. The function is zero for 0 < x < 2 and one for 2 < x < 4. Participants clarify that the Fourier series requires extending the function to be even about x = 0, which is necessary for cosine series. There is some confusion regarding the calculation of the coefficients, particularly the formula for a_n, which should be adjusted for the specified interval. The conversation concludes with a note that the choice of extension for complex exponential Fourier series is not bound by symmetry requirements.
Oreith
[/B]
<br /> f(x)=\left\{\begin{array}{cc}0,&amp;\mbox{ if }<br /> 0&lt; x &lt; 2\\1, &amp; \mbox{ if } 2&lt;x&lt;4\end{array}\right.<br />
Show that the Cosine Fourier Series of f(x) for the range [0,4] is given by:
A + B\sum^{\infty}_{n=0}\frac{(-1)^n}{(2m+1)}cos(\frac{(2m +1) \pi x}{2})
a_n = \frac{2}{L}\int^{x_0 + L}_{x_0} f(x)cos(\frac{2\pi nx}{L})dx
L = 4
a_n = \frac{1}{2}\int^{4}_{0} f(x)cos(\frac{\pi nx}{2})dx =\frac{1}{2}\int^{2}_{0} 0cos(\frac{\pi nx}{2})dx+\frac{1}{2}\int^{4}_{2} cos(\frac{\pi nx}{2})dx = \frac{1}{2}\int^{4}_{2} cos(\frac{\pi nx}{2})dx
= \frac{1}{2}[\frac{2 sin(2n\pi)}{\pi n} - \frac{2 sin(n\pi)}{\pi n} = \frac{1}{2}[0 - 0] = 0
I do get a non-zero a0 term but it seems weird to me that B would be zero, is my L wrong?
When dealing with Fourier cosine and sine series, you are actually extending a non-periodic function onto a periodic even or odd domain. Hence the effective period is actually twice as large instead, that is to say, you are actually working with the interval -4 < x < 4 here as the basic unit.
I see, is this symmetrisation of the interval around x = 0 always necessary or does it depend on f(x)?
Well, if you want to express a non-periodic function in terms of a Fourier series, then you will have to choose how to extend it to a periodic function - there are arbitrarily many different ways of doing so, but for convenience, usually we will choose the odd or even extensions, which lead respectively to the Fourier sine and cosine series.
My function is only defined for 0 < x < 4. To make it periodic does my function become:
<br /> f(x)=\left\{\begin{array}{cc}<br /> 0,&amp;\mbox{ if }<br /> -4&lt; x &lt; -2\\<br /> 1,&amp;\mbox{ if }<br /> -2&lt; x &lt; 0\\<br /> 0,&amp;\mbox{ if }<br /> 0&lt; x &lt; 2\\1, &amp; \mbox{ if } 2&lt;x&lt;4\end{array}\right.<br />
No. Because you're asked to find the cosine series, you have to extend f(x) such that it's even about x=0.
Likes Oreith
Thanks! Is the choice completely arbitrary for the complex exponential Fourier Series since it has both sine and cosine components?
Oreith said:
[/B]
Your problem is in that formula for ##a_n##. In your problem with ##L=4## it should read
$$a_n = \frac 2 4 \int_0^4 f(x) \cos(\frac{n\pi x}{4})~dx$$
I'm sorry but I don't really see that?
Look here, for example:
http://www.intmath.com/fourier-series/4-fourier-half-range-functions.php
That's right. There's no symmetry requirement for the complex exponential series.
  • · Replies 16 ·
