Fourier Transform H(t).cos(w0t)
The discussion focuses on calculating the Fourier Transform of the function f(t) = H(t)·cos(ω0t), where H(t) is the Heaviside function. The key equations referenced include the Fourier Transform of H(t), which is FT[H(t)] = π·δ(ω) + 1/iω, and the Fourier Transform of cos(ω0t), which is FT[cos(ω0t)] = π(δ(ω-ω0) + δ(ω+ω0)). The solution involves using integration by parts and applying the linearity and modulation properties of the Fourier Transform. The final approach utilizes Euler's formula to express cos(ω0t) in terms of complex exponentials.
  • Understanding of Fourier Transform principles and properties
  • Familiarity with the Heaviside function and its applications
  • Knowledge of integration techniques, particularly integration by parts
  • Proficiency in using Euler's formula for complex exponentials
  • Study the properties of the Fourier Transform, including linearity and modulation
  • Learn about the application of the Heaviside function in signal processing
  • Explore integration techniques, focusing on integration by parts in the context of Fourier Transforms
  • Investigate the use of Euler's formula in transforming trigonometric functions
Students and professionals in electrical engineering, signal processing, and applied mathematics who are working with Fourier Transforms and need to understand the implications of the Heaviside function and cosine modulation in their analyses.
tsumi
Fourier Transform f(t)=H(t).cos(ω0t) ,using the transform of H(t)
H(t)=Heaviside function (also known as signal function if I ain't wrong)
(1) FT[f(t)] = ∫ f(t).e^-(iωt) dt
(2) FT[H(t)] = pi.δ(ω) + 1/iω
(3) δ(ω) = Delta Dirac Function
(4) FT[cos(ω0t)] = pi (δ(ω-ω0) + δ(ω+ω0))
I used equation (1) to get it, integrating by parts. The first part of parts integration yealds 0, then the new integral has the derivative of H(t), which is not bad since we can use the derivative propertie of the transform, but integrating cos(ω0t).e^-(iωt) yealds something quite far from the expected result. Am I on the right way? Any suggestions?
Thank you for any help
Please show the details of your work.
I got it! You have to make cos(ω0t) = 1/2 (e^(iω0t) + e^-(iω0t)) (euler formula)
Then use the linearity propertie of the transform and then the modulation propertie.
Thanks for such a quick response anyway =)
