Fourier transform of e^(jπn(t/T))
4 replies · 3K views · last reply
benjamince
Fourier Transform help! (bit urgent)
Hi there,
I'm having a recurring problem with my Fourier transforms that I have tried really hard to figure out but I feel like I'm missing something important. It keeps popping up in my communications and signal processing papers.
I keep getting FTs like:
∫e^(j2π(n/2T - f)t).dt
Does this reduce to anything? I've tried for a few hours to understand it and I'm pretty much stuck. If I had the fundamental frequency then it would make more sense to me, but I don't.
The question involves finding the FT of:
e^(jπn(t/T)
Thanks in advance for any help!
Ben
benjamince said:
Hi there,
e^(jπn(t/T)
Ben
Hey benjamince and welcome to the forums.
Assuming all your other parameters are constant or not related to t, You should be able to use the fact that integrating e^(at)dt gives 1/a x e^(at) for the anti-derivative.
Is the above true or is your integral in terms of something more complicated where the a, above is in terms of a function of t?
Thanks for the quick reply chiro!
Yeah, I did try that, but because I'm integrating over limits from -∞ to +∞ (the signal is a pulse train) then I get an undefined result:
1/(n/2T - f) * sin(2π*(n/2T - f)*∞)
- that's after converting from exponentials into sine form.
Should I be using these limits? I guess that the frequency content of a periodic signal is the same for each period right?
The function corresponding to a pulse train is not the same function that a sinusoidal continuous funtion from -infinity to +infinity.The writing of your integral is for the second, not for the first one.
Thanks for the reply.
Sorry I'm misunderstanding a bit. You can represent the pulse train as an infinite summation of sinusoids (hence the n in the equation), but I moved the summation sign outside the integral due to linearity properties of the FT - the pulse is actually a sinc function itself. (I think)
The problem I'm trying to solve doesn't say what the pulse train is doing, but it's likely being used for sampling, in which case I thought it theoretically did go from -infinity to +infinity.
The original question is:
Find the Fourier transform of:
(A/T) Ʃ sinc(πn(tau/T)) * e^(jπn(tau/T)) * e^(jπn(t/T))
T is the period, and tau/T is the mark-to-space ratio.
My answer is:
A Ʃ sinc(πn(tau/T)) * e^(jπn(tau/T)) * sinc(π(n/2T - f)T)
The answer isn't given..
Thanks again for the replies!
