Fourier transform: signal with filter
JustPeter
Hi Guys,
I'm having trouble with the following:
A finite-time signal is the result of a filter G(t) applied to a signal. The filter is simply “on” (1) for t ∈ [0,T] and off (“0”) otherwise. If x(t) is the signal, and x(ω),its Fourier transform, compute the Fourier transform of the filtered signal. Next, take a simple sine for x(t), x(t) = sin(ω0t), and compute the Fourier transform for the finite-time signal. Write the result, it must involve the filter, and integrations should stretch [−∞,∞]
I don't really know what to do exactly, with the first problem.
I can try calculating the Fourier transform of the filter:
G(ω)= ∫0T e-iωtdt = -1/(iω)⋅(e-iωT-1)
The Fourier transform of the signal is: x(ω)
The convolution theorum says that the convolution of two functions is the product of the Fourier-transformed functions. Which makes: G(ω)x(ω).
But I have the idea that this isn't right. Could one of you guys assist me?
Peter
The convolution theorem also works the other way around: the Fourier transform of the product of a step function and some other function is the convolution of their Fourier transforms.
By the way: do use the template, don't erase it. It helps you order to your thinking and us to help you better
Ok. If I understand you correctly, you mean:
Fourier{x(t)g(t)} = 1/2π ⋅ X(ω)⊗G(ω) ==>
Writing -1/(iω)⋅(e-iωT-1) to -1/iω⋅e-iωT/2(e-iωT/2-eiωT/2) = T⋅e-iωT/2⋅sinc(ωT/2)
Fourier{x(t)g(t)}=1/2π⋅∫-∞ X(w-w')⋅T⋅sinc(ω'T/2) dω' ??
Sorry, I will do that next time, thanks!
Looks reasonable (all the contributions are there -- didn't check the gory details. Most of the time I use a table like this)
I take it you mean ##\ x(\omega-\omega_0) \ ## ?
Now for the second part ...
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
