Fourier Transform Vs Prony/GPOF
Generalized Pencil of Functions (GPOF) and the Prony Method are effective for extracting resonances from data without the windowing effects that can complicate Fourier Transform (FT) and Discrete Fourier Transform (DFT) analyses. When the number of poles is significantly lower than the number of data samples, Prony's method is recommended, especially with advancements like the "smallest eigenvector" method and optimum joint estimation techniques. Various methods, including autocorrelation and covariance, offer alternatives to FT, which can suffer from limitations due to windowing. The discussion highlights a shift in preference from FT to these advanced methods for better spectral estimation. Overall, GPOF and Prony methods are often superior for resonance extraction in many scenarios.
zinda_rud
I have been recently reading papers on Generalized Pencil of Functions and Prony Method (parameteric modeling). It turns out that GPOF/Prony are very good in extracting resonances from a given data and don't suffer from the so called 'windowing effects' associated with FT.
My question is:
Is there any advantage of using FT (or specifically DFTs) in extracting poles/resonances from a given data or GPOF/Prony's are the best in all such cases?
Thanks.
If the number of poles is much lower than the number of data samples, a version of Prony would be suggested. Many improvements to Prony's algorithm have been made since 1795. The "smallest eigenvector" method of Howard J Price is better than Prony's original method. Still better is the optimum joint pole and coefficient estimation of Bresler and Macovski.
See D. Kundu's book "Computational aspects of statistical signal processing", chapter 14, which is on the web if you Google it.
zinda_rud said:
... Is there any advantage of using FT (or specifically DFTs) in extracting poles/resonances from a given data or GPOF/Prony's are the best in all such cases?
'Windowing' causes FT and DFT problems that several http://www.digitalCalculus.com/demo/rainbow.html" don't have or at least don't show. Methods include Autocorrelation, Covariance, Prony, Akaike, Burg, etc. Steven Kay published a textbook about 1986 called 'modern spectral estimation' that convinced me to forget FT and start using these other methods. Prony was WAY ahead of his time it seems to me.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 24 ·
