Fourth Generation Nuclear Weapons
77 replies · 35K views · last reply
NavyMan said:
I read recently it was possible to get the critical mass documents due to the freedom of information act, they are supposedly available from the National Archives and cost about $20. Scary thought
Unless they have been declassified, I doubt that key critical mass calculations are available. The details of nuclear weapons are not in the public domain, and are not available under FOIA.
There was a move during the Clinton administration to declassify some DOE records. IIRC, that program was suspended.
NavyMan,
NO - anything that is classified by the Atomic Energy Act of 1954 is IMMUNE from the
Freedom of Information Act.
In addition to my job as a physicist, I am also an Authorized Derivative Classifier. That
is, with published guidance from DOE, I decide if a document is classified or not.
In that capacity, I also handle Freedom of Information Act requests. There is a check
box on the FOIA form which states that the information is covered by the Atomic Energy
Act. If I check that box, then the FOIA request is automatically DENIED.
Dr. Gregory Greenman
Physicist
Astronuc,
You are correct about FOIA.
The Clinton Administration did seek to declassify a lot of information. Most classified
information is defined by an Executive Order - so the President has a lot of latitude in
the determination of classified information.
http://www.fas.org/sgp/clinton/eo12958.html
However, nuclear information is classified by the Atomic Energy Act of 1954 - which is
an Act of Congress - i.e. a Law. It takes another Act of Congress to change its provisions.
https://www.osti.gov/opennet/forms.jsp?formurl=od/rdfrdhtm.html
Specifically, the Clinton Administration stated that for "borderline" cases, the
determination should favor a finding that the information is unclassified.
However, the Atomic Energy Act, with its "born secret" provisions, states that the
determination should favor classified, not unclassified in borderline cases.
In order to overule the "born secret" provisions, it would take an Act of Congress, as I
stated above; which the Clinton Administration did not pursue.
Physicist
Hi Folks;
I can imagine the potential for shaped charged nuclear devices able to produce enough heat and pressure to induce fusion in a limited subset of or throughout entire body of water. Note that shaped charge nuclear devices may be able to produce a concentrated jet of plasma and thermalized gamma rays with a blackbody temperature of about 10 EXP 14 K to 10 EXP 15K and pressures of perhaps 100,000,000 million atmospheres based on the estimate that the device could concentrate the reaction energy/plasma as much as 6 orders of magnitude above that of a spherically symmetric nuclear explosion. Nested shaped charges wherein a shape charge jet would be formed from a multitude of primary shaped charge jets could probably best this figure by several orders of magnitude.
Such a device might be detonated in a small pond or lake in an enemies territory thus roasting the enemies whole country in one feld-swoop. The danger is that it could be detonated in the ocean causing a chain fusion reaction to propagate through the entire Earth's ocean in a fraction of a second thus vaporizing the Earth with an effective 10 EXP 18.5 metric ton fusion bomb.
At a temperature of 10 EXP 15 K, it might be possible to create a macroscopic aggregate of Higg's Bosons thus causing a type of energy release that might be associated with such a large concentration of Higg's Bosons. Perhaps such a device could be used to alter the zero point energy state of the space within with the device is set off perhaps leading to a Higg's field imbalance and a limited release of zero point energy which is estimated by some physics theories to have a density 120 orders of magnitude greater than that of the average mattergy density of the obsevable universe. One cubic meter of space might have the latent energy of 10 EXP 41 times that of the mattergy within the observable within the universe. The danger here obviously is that a runaway phase change might ensue to envelope the whole universe. The worst possible scenario would be that the phase change might effect the whole multiverse or omniverse if such exist or the entire fractal verse proposed to exist within the theory of chaotic inflation due to any weak causal coupling between our Big Bang and any others in any form of causal coupling with our universe.
The message is that we had better be careful with our nuclear weapons experiments. No doubt, improvements in our ability to produce ever greater amount of liberated energy will continue, but let's be careful.
Regards;
Jim
James Essig said:
Hi Folks;
... thermalized gamma rays ...
Hadn't heard of these.
All mine sort of fade out once they've been comptonized a bit and then photoelectronized.
A particular spectrum of gamma rays?
Photoneutron production maybe?
Gamma rays produced by thermal sources? (not just really high energy x-rays)
I've not thought of gamma rays being in equilibrium, they just go down in energy.
Inverse Compton scattering?
Are we talking such density of gamma rays, the most likely thing they might collide with is each other? That would have to be like 10 EXP zillion or so, at which point my puzzler gets sore and goes to sleep.
Interesting to think of though, Thanks!
- Ed
Hi GammaScanner;
I was sort of thinking gamma rays produced with an energy of rough order of magnitude of the temperature of the plasma in the form of black body radiation. The temperature of the plasma with nucleon/proton/other charged particles of about 10 EXP 15 K might very briefly radiate gamma rays on the order of 10 EXP 12 to 10 EXP 13 eV extrapolated from 1million to 10 million eV gamma rays from the initial plasma produced in the nanoseconds after the fusion sequence of a thermonuclear device is complete. A more realistic model might be the gamma ray energies that exist within the fission component just after the chain reaction has effectively ended. The maximum temperature of the fission reaction is about 100 million K at fission completion. For the fusion sequence, the maximum temperature reaches about 300 million to 400 million K although these temperatures are probably at locations well within the fusion stage where pressures and temperatures can be compounded by the compressive effects of the overlayers of fusioning material. At gamma ray energies approaching 1 TeV, interaction with quarks composing the nucleons no doubt becomes important.
Collisions of gamma rays among nucleons might produce some of the desired gamma rays through compton scattering, charged particle collisions might produce additional gamma rays, and other exotic reactions that produce extremely hard gamma rays such as those that occur in 1 TeV accellerators and soon, the 14 TeV accellator at the upgraded CERN may be gamma ray components. Although I would say that some way of producing a high enough plasma density would be required to allow for gamma ray interactions before the gamma rays would escape for compton scattering to work at these extreme energies.
Thanks for the insights and questions!
Regards;
Jim
James Essig said:
Hi GammaScanner;
I honestly doubt that you could get to TeV energies with nuclear explosions, even with very special ones. After all, individual processes start out at the 200 MeV range (fission energy, or of the order of 14 MeV fusion energy), and thermodynamics will normally make it such that this energy gets distributed over more and more degrees of freedom.
Hi vanesch;
Thanks very much for the insights and comments.
It will be interesting to see what sort of particles and interactions can and will occur when the upgraded Large Hadron Collider goes on line at CERN this May. Perhaps more particles and decay sequences will be discovered adding to the great number of Feyman diagrams for which we would have discovered real particle interaction sequences thereby allowing even more degrees of freedom thus really putting the kobash on the concept that TeV energies could be generated by any realistically sized nuclear device.
Regards;
Jim
Cluster Nuclear Devices
Hi Folks;
I once, and I believe only once, read of the concept of cluster bomblet nuclear munitions back in the very late 1970s in a public dailly news paper. I believe it was either the Washington Post or some other newspaper of the Washington D.C. metro area.
I have often wondered how effective such a device could be, say perhaps on the battlefield, or for use in a counter strike on populated areas if the U.S. were to suffer a very unfortunate first strike.
My idea is that the device could contain 100 or perhaps even 1,000 bomblets each of the mass of the "Davy Crockett" warhead which as a very low mass nuclear device with a yield of between 10 and 20 tons of TNT, as small of a yield for which nuclear devices have been produced. I hear that 2,100 of the "Davy Crockett" devices were produced but that they were retired in the early 1970s.
The device reportedly would produce a near instantly fatal dose or ionizing radiation at a range of about 500 feet and a most probably lethal dose at a range of 1/4 mile. I can imagine if the yield were to be boosted to 1 kiloton in the form of a neutron bomb, a similarly compact device would have great deterent value in the form of a neutron cluster bomb.
A fourth generation nuclear device utilizing pure fusion bomblets within a cluster bomb might have even greater deterent value. If a kilogram of hydrogen were to undergo complete nuclear fusion, then the resulting yield would be about 225 Kt/Kg. Now obviously, a pure fusion bomb would probably not have all of its fusion fuel fused simply because some of it would be blasted away by the explosion before it would fuse. But my God, could you imagine a pure fusion cluster bomb utilizing 100 or even 1,000 225 kiloton yield bomblets! Talk about deterence!
Just a thought.
Regards;
Jim
Keep in mind that anyone really familiar with this stuff can't talk about it on forums, much less publish papers about new "fourth generation" concepts in apparently unrefereed unclassified online journals. I'd take any information stated in this article with many grains of salt.
Hi Folks;
Bear in mind that the same laws of physics that the folks at LLNL and other nuclear weapons R&D labs are bound by are the same laws that all other physiciists are bound by. The U.S. government is not bound by Divine providence to have an absolute monopoly on all possible nuclear weapons designs that have not been realized. I am sure there are workable nuclear weapons configurations that have not been tested and perhaps not even thought about by the folks at LLNL and the like.
Some of the folks at the Relativistic Heavy Ion Collider and at the LHC at CERN, which is soon to be operational again, will no doubt want to look for additional nuclear forces aside from the strong nuclear force and the weak nuclear force. The existence of additional nuclear forces has been hinted at by experimental anomalies as we probe the nature of fundamental particle physics at ever greater energy levels. One can only speculate what nuclear devices might be capable for devices that would somehow involve the principles of the application of any yet to be discovered nuclear forces.
I personally think that this is a fine thread with lots of good comments being posted.
Regards;
Jim
Hi Sanman;
The idea of using buckballs or other fullerines to contain compressed hydrogen, perhaps in a metallic state does seem to have good potential within the field of nuclear weapons design.
Any way in which hydrogen in its various isotopic forms can be produced in an ever more dense and stable manner potentially allows for more of the hydrogen isotopic fusion fuel to be fused instead of being blasted away by the fission primary stage. Note that the most exothermic fusion reactions convert about 0.7 percent of the reactants mass to energy. This allows 1 kilogram of this ideal fusion fuel to yield about 180 kilotons + when fully fused. Thus any process that allows more densely concentrated precursor fuel can potentially lead to higher mass specific yields for thermonuclear devices.
Thanks for asking.
Jim
Hi James,
Thanks for your response. My understand is however that nobody has found a way to synthesize these idealized these densely-hydrogen-filled buckyballs. I was wondering if quantum tunneling might be able to get hydrogen inside buckyballs. Since hydrogen is smaller and lighter than the buckyball, perhaps it could tunnel its way across the graphene shell, to get inside the buckyball.
Another idea I had was perhaps using an ultra-short (femtosecond/attosecond) pulse laser, to deform a local region on the buckyball's graphene mesh long enough for hydrogens to get inside.
Does anyone else have any speculations or conjectures on how metallic or ultra-dense hydrogen within the confinement of buckyballs could be achieved?
Another idea I had was to use the photon resonance with the buckyball to manipulate the surface plasmons and/or volume plasmons to help us get the hydrogen inside.
http://www-als.lbl.gov/als/science/sci_archive/103plasmon.html
Perhaps with the volume plasmon effect we could make the buckyball expand and contract enough, so that when its mesh is expanded we could get the hydrogen inside, and then when its mesh contracts it will compress the hydrogen.
Hmm, sort of like the pumping action of a heart, except without any primary inlet and outlet. All the gaps in the expanded mesh could act as inlets.
Later on, by introducing muons into the picture, then all bond orbital lengths could be made to contract even further -- not just the D-T bonds, but also the C-C bonds -- so that everything gets even more compressed.
Hi sanman;
Those are some very interesting ideas. Another possible way to get the hydrogen, deuterium, and/or tritium inside is to beam it at the sample of carbon buckyballs or other fullerenes in a manner similar to ion beam deposition. For those of the Physics Forums readership who might not be familiar with ion beam deposition, it is a technique by which a relatively low energy ion beam is directed to a metal surface or alloy surface wherein it is desired to produce special surface characteristics within the surface layer of certain pieces of metal such as for very hard surfaced temperature and scratch resistant components of mechanical systems and the like.
Regarding the application of muons, in consideration of ultra dense forms of metallic hydrogen, one thing comes to mind, and that is muon catalyzed fusion. The ultra dense state of the hydrogen would allow a significantly reduced mean free path for the muons within the sample hydrogen thus potentially allowing more hydrogen nuclei to be fused via the muons acting as an intermediary between the hydrogen nuclei. Once a sample of such densely packed hydrogen would undergo muon catalyzed fusion, perhaps the fusion process could boot-strap itself with the energy released by the muon catalyzed fusion reactions thus resulting in a thermonuclear explosion.
I am not sure, however, how small muon production apparatus have become. One would not want to build a substantially large particle accelerator just to initiate a modest size thermonuclear device's explosion. However, your idea of using muons to facilitate the filling of the buckyballs is intriguing.
Note, I am not sure if this posting went through so it may appear in duplicate form at least temporarilly. I have been having some software troubles as of late.
Thanks;
Jim
Hi Jim,
I totally agree with you - that's why I posted about the muons, because of their ability to catalyze the hydrogen fusions. I had posted about this a couple of months ago, on a separate thread:
https://www.physicsforums.com/showthread.php?t=226759
Here's a good refresher on muon-catalyzed fusion for everyone:
http://en.wikipedia.org/wiki/Muon-catalyzed_fusion
So to make a net energy profit, 600 fusions have to be catalyzed per muon before it expires. Right now, the best that's been demonstrated is 150, so that has to be quadrupled at least.
The density of frozen hydrogen is cited at 0.088g/cm^3:
http://hyperphysics.phy-astr.gsu.edu/Hbase/pertab/h.html
The density of metallic hydrogen is cited at 0.4g/cm^3:
http://www.springerlink.com/content/h226824477441582/
Metallic hydrogen seems to offer a density ~5 times greater than frozen hydrogen, which I'd hope might be enough for net energy output above breakeven.
Another significant problem mentioned may be the "alpha-sticking", whereby the alpha-particle produced by the fusion reaction might snatch away the muon due to its double-positive charge. I'm hoping that within the confines of the metallic hydrogen and surrounding buckyball, the alpha particle might have more difficulty leaving, so its muon might be kept available.
The other problem, mentioned in that older thread, is that the main holdup in the fusion process is the time it takes to form the muonic bond between D-T (5 nanosecs). Again, I'm hoping that the metallic state with its shorter interatomic separation distances, would accelerate the bond formation process.
Another way to favor net energy output is to reduce the energy requirements of a muon production:
http://www.springerlink.com/content/r5370246874n605u/ The next question is, how many hydrogens can fit into a C60 buckyball, at near-metallic pressures?
If required, there are larger sizes of buckyball, including C540:
http://www.3dchem.com/moremolecules.asp?ID=218&othername=c540
Perhaps with a nested buckyball (buckyonion), you could afford even higher pressures and densities of hydrogen inside.
Comments?
Hi sanman;
The idea of using buckyonions I think is really neat for potentially storing high density hydrogen or deuterium. Another possible nanoscale storage material for dense hydrogen is carbon nitride which may have a bulk modulus in some forms higher than that of even pure diamond. If the pressure and temperature of the fusing hydrogen was high enough for devices based on dense hydrogen fusion fuel stored within carbon fullerenes, perhaps the carbon buckyballs could undergo nuclear fusion also, i.e., carbon nuclear fusion.
Regarding reliable warheads which use benign, cheap, and safe fusionable materials, I wonder if anyone has seriously investigated a so called water bomb, Such a device might make an excellent latter generation nuclear weapon if not a good fourth generation nuclear weapons technology.
The idea here is that a very high mass specific yield fission or fission fusion device would be used to set of a fusion reaction within a much larger volume of pure ordinary water, or perhaps pure heavy water. The yield of such devices could be staggering but kept at a safe predeployed level, wherein, when it was time to deploy the device, the liquid water could be quickly and safely added to the device in a manner in which the detonation of the primary would fuse the oxygen and hydrogen in the water thus resulting in a device with extreme yield.
If a spherically symmetrically exploding primary device could not produce the requisite pressures and temperatures to ignite the water stage, then perhaps a focused or shaped charged style nuclear device could.
It occurred to me to mention that other cheap, safe, and non-volatile exothermically nuclear fusionable fuels could be used in the construction of adjustable yield or yield augmentable thermonuclear devices including but not limited to carbon, perhaps even carbon containing plastic materials such as solid polymers, Nylon, Kevlar, and the like. Such high strength materials might somehow be utilized for their high elastic modulus to momentarily, at least on the scale of nanoseconds, provide mechanical resistance to the intense energy blast from the devices primary for purposes of allowing a super high pressure and temperature wave to develop within the carbonaceous fusion fuel in order to initiate a self propagating fusion wave front to travel thru the fussile material. Note that carbon is a good absorber of certain forms of ionizing radiation on the energy scale of nuclear reactions and has utility in modern nuclear fission reactors as a neutron flux moderator.
Although white dwarf stars as the dead remnant of stars with a mass of below about 1.4 times that of the sun are much more dense than ordinary matter at STP, in fact about a million times as dense, they can and do occasionally under go supernova which result in the complete fusioning of the entire star in a fraction of a second. So in a sense, carbon detonation fusion devices already exist in the form of naturally occurring solar mass range bodies.
Now the temperatures and pressures required to initiate a carbon fusion reaction are likely to need to be much higher, in fact they are higher, than that required for the initiation of traditional fussile materials in nuclear devices such as Lithium Dueteride. As a result, a highly optimized mass specific energy dense primary may be required, perhaps even a shaped charge type primary might be required to set off the carbonaceous or other higher atomic number fusion fuel. The use of these exotic fuels would probably only make sense for devices that have extremely high yield and thus which have a relatively large mass wherein cheap fusion fuel is desired.
Thanks;
Jim
I have the impression there's a lot of talking here without any sound ground. Now, of course, apart from some rudimentary knowledge, I'm of course no nuclear weapon expert - and has been said here, anyone who is will not put his knowledge to display on a public forum.
However, it seems to me that always the same elementary errors are made. It is not because certain mechanisms seem 'violent' that they also correspond to high particle energies. I think that most of the mechanisms proposed here, where one wants to take into account any solid material strength, miss the point that solid materials obtain their strength from eV level binding energies, not something that can contain KeV and MeV energy particles. What nuclear explosions is concerned, any material can be seen in good approximation as a fluid.
As to metallic hydrogen, the gas giants are full of it, under much higher pressure, and with much higher inertial confinement than can be achieved in a small box, and of course there's sometimes the occasional muon which comes by (be it by the rare capture of a muon neutrino), and they don't explode like monster thermonuclear bombs.
As to the 'water bomb', as there have been nuclear tests under water, clearly (happily!) there is no self-ignition of water. H-H fusion is much more difficult than D-T and D-D fusion, and H-H is still much easier than O-O fusion. You need a supernova to achieve that!
So please, a bit more realism in the discussion, and when things become hypothetical, please provide at least some numerical estimates for the claims.
hi Vanesch,
Well, I was then specifically mentioning the muon-catalyzed fusion to address those points, which you had also similarly made in the other thread.
But I'm not sure about what further research has been done into reducing the D-T formation time. I do think there has been research into attempting more efficient production of muon beams, to reduce energy cost and increase muon beam intensity.
The thing is that people want safe and abundant nuclear energy, but there aren't enough solutions forthcoming on how to provide it.
Hi Folks;
Part of the reason why underwater tests of nuclear devices never set off ocean water in a fusion reaction might be due to the limited mass specific yield of the nuclear devices tested or perhaps the limited mass specific yield of spherically symmetrically exploding devices in general.
Perhaps, a shaped charge nuclear device that concentrates its explosive flux energy and pressure in a manner similar to that of a bazooka could do the job in setting off a water bomb. Note that shaped charged nuclear devices, according to some open literature on the subject, may be capable of concentrating their explosive flux energy as much as 6 orders of magnitude above that of a spherically symmetric explosion. If such high flux concentration is possible, I would not be surprised if water bombs are eventually produced.
An ordinary piece of TNT with a mass of a few kilograms detonated outside the hull of an M1Abrams tank will not phase the vehicle, a HESH round can indeed disable our best battle tanks as we have seen in the war in Iraq.
Regarding nuclear weapons researchers not posting nuclear weapons concepts on line, that is definitely true in all cases. However, these researchers are not guaranteed to have a monopoly on nuclear weapons designs or concepts any more than the US is endowed by God to always be the most powerful country on Earth. New ideas come from all places and times and new paradigms are rarely predicted in advance.
Thanks;
Jim
Muon-catalyzed fusion works - is demonstrated without doubt, and is also understood, for D-D, H-D, and D-T. I don't think it has been shown for H-H. But you still have to make the muons! http://en.wikipedia.org/wiki/Muon-catalyzed_fusion
As muons don't exist in abundant quantity on earth, and are unstable http://en.wikipedia.org/wiki/Muon with a life time of 2 microseconds there are not many options. Given that its mass is 105 MeV / c^2, you will need a process that spends *at least* 105 MeV per muon, that will live for about 2 microseconds. The only known way to produce muons is to have a beam of protons slam into some matter, produce a hadronic shower containing also a lot of pion particles of which there are 3 kinds: pi-+, pi-- and pi-0. pi-- decay preferentially into muons (pi+ into anti-muons), which can then be extracted by a thick iron wall which will stop all gamma and other particles, and a magnetic selection which will take out the muons and send the anti-muons elsewhere.
Not really something that you can put in a tabletop device or in a bomb.
You seem to forget that you were talking about *weapons* with sci-fi properties.
I think if we rely on nuclear power, then there is more than enough of it, in relatively safe ways, for everybody. Thermal fission can provide enough in the coming decades, fast breeder fission can provide enough in the coming centuries, and a few centuries should allow us harness fusion in one way or another. Even D-T fusion is enough for millions of years.
Although it is true that nuclear power has a (tiny) risk to it, and is not 100% clean, it is more than good enough, compared to the *realistic* alternatives that we have.
I would like to see something about that - I have a hard time believing it, and it depends what quantity is "6 orders of magnitude" larger. If you simply think of some radiant energy or whatever, that would mean that instead of sending out a flux in 4 pi (spherically symmetric), this same flux is now sent out in a beam with angular divergence 4 pi / 10^6 ~ 10-5 sterrad, which means an angle of opening of about 0.003 rad, or 0.2 degrees. That's much much better directivity than a flashlight (around 10 degrees), even much better than a search light (about 5 degrees). Hell, that's even better than a laser pointer, which is around 0.01 rad !
accelerating D-μ-T formation
Hi Vanesch
I feel that the difference with having the hydrogen inside buckyballs is the geometry. Each buckyball would be able to shape or channel external forces to focus them on squeezing the hydrogen contained inside.
Similarly, muon-catalyzed fusion has achieved the highest energy return so far (~67% of breakeven), more than even the tokamaks, because the muon at 207 times the electron's mass can create a molecular bonding orbital between hydrogens that is 207 times closer. At this short distance, quantum tunneling causes the hydrogens to fuse within half a picosecond.
Even though the short-lived muon lasts only 2.2 microseconds before it expires, it can catalyze a couple of hundred fusions during that time.
So as with the buckyball, it's the close-up interaction that the muon is having with the hydrogens (or more accurately, D-T) which is helping to broker the fusion process.
It is only due to the slow formation time of the muonic D-T molecule (5 nanoseconds) which seems to be limiting the muon from catalyzing more fusions. If only some way could be found to speed up the formation of D-μ-T, then perhaps the process could exceed breakeven. Perhaps the buckyball might help in this regard, by squeezing the hydrogens closely enough that their separation distances are closer to that of the muonic bonding orbital distance, so as to make the formation of that muonic bonding orbital easier.
Cycle diagram of muon-catalyzed fusion: free muon (μ-) forms muonic atom with D or T, then DT+ molecule, fuses releasing 17.6 MeV and a neutron (n) and alpha (α); about 99.5% of muons repeat the cycle, 0.5% stick to α. Labels show ~10^-11 sec, ~5x10^-9 sec, ~10^-12 sec for fusion, cycle time ~5 nsec, muon lifetime ~2.2 μsec.
So with a quick calculation based on 12 H for every C (8%Wt hydrogen from the articles), there would be 720 hydrogens inside a C60 buckyball (60C*12H/1C=720H). From wikipedia the muon must be able to catalyze at least 600 fusions in order to achieve breakeven, which means we need at least 1200 atoms inside there.
That means we need to go to the next larger size of buckyball, C240, which should be able to contain at least the same 8% H by weight, if not more.
So 240C*12H/1C=2880H which is more than enough for possible achievement of breakeven.
In my mind, if the buckyball's compression can achieve metallic DT having interatomic distances closer to the muonic molecular bonding orbital length, then this would facilitate/accelerate the D-μ-T formation. If this can appreciably lower the 5nanosecond bottleneck in the fusion-catalysis process, then it could be well worth it.
Comments?
Hi Vanesch;
The web based document that I recall reading the 6 orders of magnitude figure mentioned some disk-like shaped configuration of the nuclear reaction fuel wherein a proper detonation of the fuel along the disk's radial dimension might do the job. Perhaps the pressure within the superhot plasma being ejected from the central part of the disk can be greatly amplified and this along with any thermal electromagnetic emissions from this plasma jet with greatly increased pressure and temperature corresponds to the figure of 6 orders of magnitude.
Thanks;
Jim
sanman said:
Hi Vanesch
Circular cycle diagram of muon-catalyzed fusion: free muon (μ-) becomes muonic atom Dμ or Tμ in ~10^-11 sec, then DT+ molecule in ~5x10^-9 sec, fusion in ~10^-12 sec releasing 17.6 MeV alpha and neutron, with ~0.5% of muons sticking to alpha and ~99.5% repeating the cycle; cycle time ~5 nsec, muon lifetime ~2.2 μsec.
Comments?
I think you answered your own question. The muonic molecule is about 207 times smaller than the normal D-T molecule, so no way that a normal chemical set of bonds (like in buckyballs) is going to achieve such a compression. In fact, if it did, there would be no need for muons ! But it can't. It is as if you were trying to compress a massive iron ball 207 times by using a fisherman's net around it.
That's no explanation at all, sorry. That could eventually explain a factor of 6 or so, but not a factor of one million. Again, saying that something has, because of directivity, a factor of 1000000 more "stuffiness" (energy, pressure, heat, whatever) than an isotropic thing, means that it must have a directivity with a divergence of 0.2 degrees: the narrowness of the beam of a laserpointer.
I figured you would say that. I didn't say that the buckyball compression would achieve that scale of interatomic distance, I said that it would bring the interatomic distance closer to that of the muonic molecular orbital bond length - and every little bit helps. It remains to be seen what effect the metallic density and interatomic distance would have on the formation time of D-μ-T, but if it could even reduce the formation time by just 1 order of magnitude, then that could push things well past breakeven.
Hi Folks;
Perhaps the 6 orders of magnitude of energy flux compression could work for the disk shaped supply of fusion fuel and that just inside and outside the volume of space of the original disk near its center, one could obtain the 6 orders of magnitude. Just because the 6 orders of magnitude could not exist within a long extended beam does not mean that it could not start out with such energy flux compression. The highly compressed energy flux might indeed start out that way and then quickly diverge in terms of blast direction angular spread. If the disk shaped configuration is not up to producing the 6 orders of magnitude energy flux compression, perhaps other configurations can and perhaps even surpass this value.
Thanks;
Jim
