Frames with inclined legs using slope-deflection method
1 reply · 6K views · last reply
Ashu2912
This is a diagram from "Structural Analysis" by Aslam Kassimalli while solving frames using slope-deflection method. In the figure, the tangent to the deflected shape at C` is parallel to the original member AC implying that the slope at C is zero. However, later they have considered θC (the slope at C) as an unknown while writing the slope deflection equations. Why so?
  • Two-part diagram of a portal frame with sidesway: top shows the deflected shape with points A, B, C, C', D, D' and labelled angles β1 and β2 and displacement Δ; bottom shows the same frame with chord rotation angles ψAC, ψCD and ψBD marked.
I don't think you can assume that the tangent at C' (the prime symbol ' is not clear enough in the figure) is parallel to AC. The tangent at D' is not visibly parallel to BD, and shouldn't be. In general, I would expect both C and D to rotate somewhat, because the rotation is only partially restrained by the stiffness of the attached members.
