Free fall velocity and distance
34 replies · 5K views · last reply
poh
A 0.1 kg nut is thrown by a squirrel off of the top of a 10 m tall tree. It is thrown with an initial upward velocity of 4 m/s and an initial horizontal velocity of 3 m/s.
a) How long till it reaches the top of its arc?
b) From the top of its arc how long till it reaches the ground?
c) How far will it travel horizontally from the moment it is let go to when it reaches the ground? (Consider the combination of the time in both parts a and b.)
Vf=Vi + at
Xf= Xi + Vit +1/2at^2
am I applying information correctly?
to find time i should Yf= Yi+at ?
I am lost for a) I should use Vf= Vi + at
and for B) Yf= Yi + Viyt + 1/2at^2
  • Handwritten physics working on lined paper: kinematic equations at top left, a table of x and y components (Xi = 0, Xf = ?, Vix = 3 m/s, ax = 0; Yi = 10 m, Yf = 0, Viy = 4 m/s, ay = -9.8 m/s^2, t = ?), then Yf = Yi + at, t = (Yf - Yi)/a = (0 - 10 m)/-9.8 m/s^2 = 1 s.
Did you mean that? I assume Yi and Yf are heights.
If X means horizontal, what is a?
Yes.
You can, but define exactly what you mean by Yi, Vi and t here.
Yi is initial height
Yf is final height
a=0 right?
haruspex said:
You can, but define exactly what you mean by Yi and t here.
Yi - initial height and t is the time
Yf is final height
Then the equation is wrong. The right hand side, at, has dimension of velocity. Elsewhere you have correctly used Vf= Vi + at.
poh said:
a=0 right?
In that equation, yes.
I wrote "exactly". You are asked to consider the trajectory of the nut in two stages, from being thrown to reaching top of arc, then from top of arc to ground. Which point are you considering "initial" in this equation and to what interval does t refer?
for b) i tried Yf= yi + Viyt + 1/2 at^2
0=10m +4m/s*t + 1/2(9.8m/s)t^2
t= 2*(10m+4m/s)/9.8 m/s
t= 28/9.8s
t= 2.9s
t is time to reaches the ground from the top
Or i should assume my Yi is 0?
Careful with signs.
Let me decode your equation, on the assumption that up is positive:
For a certain motion lasting time t, the final height is zero, the initial height is 10m, the initial speed is 4m/s upwards, and the acceleration is 9.8m/s2 upwards.
Anything in your post you'd like to correct?
haruspex said:
Careful with signs.
acceleration should be -9.8m/s^2
Right, and what about the meaning of t in your equation?
poh said:
t is time ... from the top
haruspex said:
For a certain motion lasting time t ... the initial height is 10m
t is time how much time takes to fall ?
haruspex said:
From where?
from 10 m tall tree to the ground
haruspex said:
Yes. So what do you get for that time?
I got t= 2.9s
poh said:
I got t= 2.9s
There's another problem I had not previously noticed, that your next line was:
This is completely wrong. You cannot add a distance to a speed. Your equation has a 't' term and a 't2' term. How do you solve equations like that?
divede t by itself or I should use square roof to take out t^2 ?When I assume Viy = 0 then I got 1.4s
It is a quadratic equation. Use the formula.
i got 1.1s
You have excluded air-friction etc, should mention that you've done so to show 'Due Care'...
haruspex said:
I get something different. Please post your working.
I did mistake in calculations.. my new calculations are 1.8 or 1.1
  • Handwritten quadratic formula on graph paper: -4 ± √(4² - 4(-5)(9.8)(10)) over 2(-5)(-9.8)... simplified to -4 ± 14.5 over -9.8, giving 1.8 and 1.1 s.
Again, be careful with signs.
You also need a bit more precision.
-1.1 and 1.9s
poh said:
-1.1 and 1.9s
Yes, that's better.
Clearly you want the pisitive answer, but the negative one also has a physical meaning. Can you see what it is?
Oh, and remember that what you have found is the time from being thrown up. Is that what you were asked for?
haruspex said:
Yes, that's better.
Negative means that's going down?
Sort of.
The equation you solved is valid forwards and backwards in time. If you imagine the nut being thrown from ground level 1.1s earlier, with just the right speed and angle, it would have passed the monkey at "time 0" and continued on exactly the same trajectory described by your equation.
And please note the edit to my preceding post.
haruspex said:
Sort of.
I was asked how longs takes to reach the ground. so answer is 1,9s
is Vf=Vi + at where a=0 and t=1.9s ?
a=0 is for horizontal motion. For a) and b) we only need consider vertical motion.
The questions were
In post #1 you had the right equation for a), but I did not see what answer you got. It should not be 1.9s.
In post #22 you got 1.9s, but that was the time from where to where?
The questions were
ah I see now so Vf=Vi+at where Vf=0 Vi 4m/s and a=9.8 m/s t=? so
t= (Vf-Vi)/a t= -4m/s / -9.8 m/s^2
t= .41s
from top to the ground or I should 1.9 s- 1.1s = .8s and that's time from top to ground ?
poh said:
t= .41s
Yes, that is the time for part a).
What was the value of Vi in the equation you used to get the 1.9s? At what point of the trajectory was that the nut's vertical velocity?
Vi = 4m/s I think it was all the time vertical velocity
