Free-hanging string with 4 attached masses
  • Thread starter Thread starter Nikitin
    String
The discussion centers on a physics problem involving a massless string with four uniform masses attached symmetrically, as outlined in the assignment from NTNU. The user is tasked with demonstrating the correctness of the implicit equation for cosine of angle alpha, where x = cos(alpha). The user initially struggles to derive five equations for the five unknowns but realizes that by simplifying the notation and focusing on the tensions T and S, they can relate the equations of vertical and horizontal equilibrium to the distance D, ultimately leading to the correct formulation.
  • Understanding of basic physics concepts such as tension and equilibrium
  • Familiarity with trigonometric functions, specifically cosine
  • Knowledge of how to set up and solve systems of equations
  • Ability to interpret and analyze physics problems from academic assignments
  • Study the principles of static equilibrium in physics
  • Learn about tension forces in strings and their applications
  • Explore trigonometric identities and their use in solving physics problems
  • Review problem-solving techniques for systems of equations in physics
Students studying physics, particularly those focusing on mechanics and equilibrium problems, as well as educators seeking to enhance their understanding of tension and forces in multi-mass systems.
Nikitin
http://home.phys.ntnu.no/brukdef/undervisning/tfy4145/ovinger/Ov03.pdf
look at "oppgave 5".
In the problem, you have a massless string with 4 uniform masses attached symmetrically, and you are supposed to show that the implicit equation for x (and x = cos(alpha)) is correct. Each of the masses are L/5 apart and the distance between the two ends of the string is D.
I should be getting 5 equations for the 5 unkowns, but I am only getting 4 (the last 4 equations written on the paper)..
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-prn2/1234158_10201385459335100_1607600845_n.jpg
This problem would make a lot more sense if I read Norwegian.
Look at the picture in the pdf: You see a massless string weighed down by 4 attached point-masses. Each of the mass is a distance L/5 apart from each-other, where L = total length of the string. D= distance between the two ends of the string.
Next you can see two angles: alpha and beta. The point with this problem is to show that the implicit equation for cosine of alpha written in the assignment,where x = cos(a), is correct.
Please tell me if there is something more you do not understand! I really need help with this
It is more convenient to simplify your notation by calling the tensions T and S.
Then use your D equation to get cosβ in terms of x where x = cosα.
I think that you do not need to use S_{3}.
You are probably right, but if I removed S_3 I would have 4 unkowns and 3 equations.. I don't understand how I can get my last equation?
Also sorry about the notation, but I took it from the assignment.
You have FOUR equations.
Two from vertical equilibrium and one from horizontal equilibirum if you do not use the third tension. But you have also your D equation from which to get cosβ in terms of x where x = cosα.
You mean those involving G? But G is also an unknown, because I don't know the mass. Do you think G would disappear if I inserted the equations into the one for D?
thanks for all help :)
OK after a fresh look at the problem I see you were completely right. thanks !
  • · Replies 19 ·
