Free programs to run SQL files and query the output
12 replies · 3K views
Homework Helper
Hi all,
I have an .sql file; written as a set of commands, as a general text file,
with a .sql extension. I need to execute it in order to get some tables as
output, and then run some queries on these tables.
Are there some free programs to run/execute the file? I got some hits on
a search suggesting some sort of free MySQL file, but I have found nothing.
Thanks for any ideas.
the mysql server itself is what runs these files.
mysql -u yourusername -p yourpassword yourschemal < textfile.sql
What have you been using to run the SQL code that you've been studying for the past several weeks?
WWGD said:
So I guess I download Microsoft's SQL server for free
Another option is the MySQL Community server:
http://dev.mysql.com/downloads/mysql/
I use it on Mac OS, and it's very popular on Linux, but I see there's also a Windows installer.
Thank you all, I think I realized where my confusion was; it seems I am having trouble since I have executed (run) the
file as a query (in SQL 2014) more than once. First time is fine, but I seem to be having trouble running the same initial file as a query more than
once.
Probably this is because whatever the SQL program does, it is changing the database file/s itself in some way.
It is designed to process an expected set of data and process it, job done.
Seems to be some assumptions that need a tune-up.
SQL is arbitrarily divided into flavors:
Data definition language DDL - examples CREATE, ALTER, DROP
Data manipulation language DML - examples SELECT UPDATE DELETE INSERT
Data control language DCL - examples GRANT
You can rerun a SQL file DML-only practically forever. Identical file, many times, with some exceptions about data integrity violations.
If you rerun a DML-containing file with commands like CREATE you get errors. ALTER - if it is a different statement each time - is okay.
If you rerun DCL it is usually not going to break stuff, but is a crummy idea except in special cricumstances.
Based on your comment it looks like your SQL has DDL in it. Do not rerun it adhoc like that.
Yeah, if you are trying to create something, you need to wrap it in an IF EXISTS, most sql files are not meant to be run more than once.
Thank you. The SQL I am running lives in a virtual machine. Would there be problems running/executing the same file in different VMs?
The problem is the database content. Re-running DDL can trash an existing schema. Generally you have a single copy of a db on a server. Then you have physically or virtually separate multiple clients running SQL scripts. AFTER the initial DDL run to create the on DB for everybody to use.
Some db's are distributed to local machines after they are built. Code library software uses db technology sometimes. In this case one DB instance per user. But the schema and some seed data exist on the distribution.
There is definitely some sort of disconnect here - could be on my side. If you would, please give us a couple of answers:
1. what is the application requirement the DB meets? (Learn to play DBA, track car repairs, track entries in a collection - are the kind of answer we need here)
2. I gather you understand programming but not relational databases and their real world uses. Correct?
It is more of my having the bad habit of asking simple or poorly-phrased questions and then figuring them out right after I have asked them. I am trying to break it and just think things through carefully and avoid asking poor-quality questions -- thanks for your patience.
Sorry, I don't mean to belittle the feedback, which has been very helpful, I meant that I do not always stop to think things through as I should.
There is also the fact that even if/when I know or should know the answer, I learn new things from the feedback, and by asking alone and seeing the
answer the material is reinforced and I learn some new things at the same time, and dispel some misconceptions. Thanks to all again.
