Freefall problem of a diver jumping horizontally upward
  • Thread starter Thread starter RaeZ
    Freefall
The forum discussion focuses on solving the freefall problem of a diver who jumps vertically from a platform 3 meters high and comes to rest in 0.80 seconds after traveling through 3.6 meters of water. Participants emphasize using kinematic equations, specifically d = v_0t + 0.5at² and v = v_0 + at, to find the diver's final velocity upon hitting the water and the acceleration experienced while decelerating in the water. Key insights include the necessity of eliminating acceleration from the equations to solve for initial velocity and utilizing average velocity concepts to simplify calculations.
  • Understanding of kinematic equations: d = v_0t + 0.5at², v = v_0 + at
  • Knowledge of average velocity concepts
  • Familiarity with the principles of constant acceleration
  • Basic understanding of vertical motion dynamics
  • Learn how to derive initial velocity using kinematic equations without knowing acceleration
  • Study the concept of average velocity in uniformly accelerated motion
  • Explore the effects of different mediums (air vs. water) on acceleration
  • Investigate real-world applications of kinematic equations in sports and physics
Students studying physics, particularly those focusing on kinematics, as well as educators seeking to enhance their teaching methods for motion problems involving vertical jumps and freefall dynamics.
RaeZ
A diver jumps vertically straight up off of a platform 3 meters above the surface of a pool below. The diver hits the water and comes to rest in 0.80 seconds after traveling through 3.6 vertical meters of water. (See the diagram below). Assume the acceleration of the diver through the water is constant. The goal of this problem is to work backwards to eventually find the velocity of the diver at the instant the diver leaves the platform.
Find both the velocity with which the diver hits the water and the acceleration that the diver experienced when slowing down through the water.
d=v_0t+.5at^2
v=v_0+at
v^2=v_0+2ad
I have no idea how to determine the final velocity of the diver(when they hit the water) without either a known initial velocity or the distance they traveled from their max height to the water.
I drew the diagram for this and looked at previous problems but none gave as little information. I also tried to use the third equation with v_0=0 and d=3 for the fall from it's maximum height to the water, but this doesn't make sense since the displacement was more than three since they jumped upwards from 3
Welcome to PF!
See if you can find the the speed the diver hits the water by considering just the motion while in the water.
TSny said:
Welcome to PF!
TSny said:
Welcome to PF!
I have the same problem with that though, I could use the third equation and solve for v_0, with a final velocity of zero, but i do not know their acceleration in the water...
You can try to combine the equations that you wrote in such a way that you eliminate the acceleration and express V0 in terms of the time and distance.
Or, try to use the concept of average velocity.
How can I eliminate acceleration, the acceleration water is different than the acceleration in air
Two unknown, so you need 2 equations.
"Eliminating the acceleration" means to combine the equations to produce a new equation in which the acceleration does not appear in the new equation but the initial velocity, time, and distance do appear. So, you won't need to know the acceleration to solve for the initial velocity.
Or, another approach is to use the concept of average velocity. If an object has constant acceleration while the velocity changes from v0 to vf, how can you express the average velocity?
9K
11K
10K
