Freely maintained water transfer
  • Context: Graduate
  • Thread starter Thread starter cala
    Water
The discussion revolves around a hypothetical system involving two water tanks connected by springs, exploring the mechanics of water transfer and energy conservation. Participants examine the implications of this setup on energy input and output, questioning the feasibility of achieving perpetual motion or energy gain from the system.
  • One participant describes a system where compressing a spring in an empty tank initiates water transfer from a full tank, suggesting that this could lead to energy gain.
  • Another participant questions the practicality of building such a system, implying skepticism about its feasibility.
  • Several participants argue that the proposed system violates the first and second laws of thermodynamics, emphasizing that energy cannot be created from nothing and that losses must be accounted for.
  • One participant asserts that the initial potential energy and losses in the system would prevent any net energy gain, reiterating the importance of thorough energy calculations.
  • Another participant describes the process of reaching equilibrium between the tanks, stating that energy harvested would not exceed the energy input required to fill the tanks initially.
Participants express disagreement regarding the feasibility of the proposed system and the interpretation of energy conservation principles. While some participants challenge the validity of the concept, others defend it, leading to an unresolved debate.
Participants reference the first and second laws of thermodynamics as critical to understanding the limitations of the proposed system. There is an acknowledgment of the need for complete energy calculations, which remain unaddressed in the discussion.
This discussion may be of interest to individuals exploring concepts of energy conservation, thermodynamics, and the feasibility of perpetual motion machines.
cala
freely maintained water transference
Hello again.
Just a little and simple question, i think you'll see what i mean:
Imagine a full tank of water 1m long. This tank has a spring behind, compressed by the water weight on top. This spring is 1m long from the ground, so the water is at 2m from the ground.
Imagine another empty tank of the same dimensions. This tank has another spring behind, but as the tank has no water, the spring is uncompressed. This uncompressed spring is 2m long from the ground, so the tank is at 2m from the ground.
The two tanks are connected, but as the water level on one tank is the same as the ground on the other, no transference happen.
Now, you compress a part of the uncompressed spring, say 0.2m from the ground to 0.1m. This effect is the same that a water level of 0.1m will cause.
Now, the ground of the empty tank is 0.1m behind the water level of the full tank (because you compressed the spring, but not with water weight), so a water transfer starts.
the sequence now happens like this:
A-water...A-spring...A-total...B-water...B-spring...B-total
1m...1m...2m...0m...2m...2m
1m...1m...2m...0m...1.9m...1.9m
0.9m...1.1m...2m...0.1m...1.8m...1.9m
0.8m...1.2m...2m...0.2m...1.7m...1.9m
0.2...1.8m...2m...0.8m...1.1m...1.9m
0.1m...1.9m...2m...0.9m...1m...1.9m
0m...2m...2m...1m...1m...2m
As you can see, we apply the force of 0.1m of water weight to the spring to start the process , and obtain 10 times (1m) the transference of this water.
If the tanks were 50 times longer (5m) than the equivalent water energy input (and supposing the springs could follow the same changes), then we will get 50 times the transference of the initial equivalent water.
I mean, you can apply the same work to start, and have a longer or shorter transference between the tanks, independent of the initial energy input. The transference depends of the kind of tanks and springs.
So, as energy input is independent of the process, what avoid us to get more energy from the process than the needed to start it again to the other hand?.
For example, a turbine connecting behind the tanks will collect the energy from the transference, and later we could use this energy to compress a part of the spring to start the process again.
Of course, the turbine will oppose to the transference in some manner, but if the initial level difference of the water tanks is big enough, this opposition can be bypassed, and start the process.
At this point, the energy input needed is only to pass the turbine opposition. Once the turbine start to work, the transfer is maintained at the same water levels, and this transference could be for a long time, obtaining several times the energy needed to start it.
Any question?
Why not build one?
HAHAHA
JUST BUILD IT !
Will i obtain that SAME answer ALWAYS ?
Is that the way you explain physics ?
This time the concept is very very easy to understand, no zero point virtual particles, no time reversal, no quantum physics or relativity, just two tanks, two springs and water.
I'm not interested on how it works... I'm interested on see how do you explain it wont.
This is debunked somewhere else on this site. Can't remember where.
The real purpose of that example is to make the issue more complicated than it really is, thereby making it harder to debunk.
If you want the scientific explanation, go look for it. But Integral is right: the issue really is if YOU think it works, then YOU should build it. It doesn't require debunking since there is nothing to debunk since you can't build one that works.
Its what I like to call "self-debunking."
As i said to Integral
...You explained NOTHING
If it doesn't work, I'm asking WHY.
Is this a physics forum or WHAT??
russ: The proposse of this post is just the opposite you said.
I talked before about tanks and springs on another topic, but now I think this method is more easy to understand, getting the same effects.
So it is to make it simple.
And the topic was not debunked, finally, no one talked about it any more. We reach the JUST BUILD IT point.
If i asked you how or why an electric motor work... would you tell me JUST BUILD IT?...I'm not from GENERAL MOTORS INC.
Cala-
The first and second laws of thermodynamics are your first clues that you have done an INCOMPLETE analysis of your designs for energy/power producing contraptions. It is your responsibility to do the COMPLETE energy calculations for ALL steps in the processes you propose.
Do this much at least, and present your calculations in detail, or, "BUILD IT!"
I would explain it of course. But you are not asking how something works, you are asking us to prove to you why something you believe works does NOT work. Big, big difference.
The first is a desire to be educated, the other is a desire to AVOID being educated since you already have your conclusion. The fact that you continue to try and come up with new ways to avoid the first law of thermodynamcs shows you have no desire to learn.
So it really is useless to argue with you. We explained why already and you simply won't accept it.
People have been designing and building self-powered water wheels for centuries. The first (on record) in fact was what lead to the discovery of the first law of thermodynamics. Not one has ever worked, but the US Patent Office continued to get submissions. The patent office adopted the position (and this is where I got the position from) that since the science behind this is well understood, no patent application will even be accepted for review until such a device has been shown to run unpowered for a year.
Essentially though (I'll throw you a bone, though we alredy told you and you ignored it), there are two flaws in your reasoning (and for that matter every other perpetual motion machine ever designed).
1. You improperly use the potential energy level of the initial state in each iteration including the first. That's the 1st law of thermodynamics.
2. You ignore losses. Thats the 2nd law of thermodynamics.
The 1st law problem here is quite simple. The initial state has some potential energy: x. At the beginning of the next iteration, you have the same initial state and thus the same potential energy: x. The maximum amount of energy that can be generated by the system is x-x=0. Everything in betweeen the two initial states is smoke and mirrors designed (either by accident or on purpose) to cloud this simple equation.
cala,
When you push down on empty tank A
(compressing its spring) such that
its bottom is below the water level of the full tank B, water
will start to flow from the full
tank to the empty tank. If you
maintain compression of tank A's
spring at that level the full
tank B will slowly rise as the weight on it decreases and more
of its water will run into tank A.
Eventually they will reach equi-
librium with each half full. At
this point water transfer will
stop.
You have, however, not harvested
more energy from this than you
put into it. It required energy to
put water into the full tank to
begin with and most of what you
get out is simply the release of
this energy that has been stored
in the full tank's compressed
spring. In addition you have to
apply force to compress the spring
beneath the empty tank and to
maintin that force until equi-
librium is reached.
-Zoob
Hello zoob, you're right:
"You have, however, not harvested
spring."
Yes, but you can use this energy once and again from the transference of water from one tank to another. The springs store or bring energy meanwhile the water transference happen.
"In addition you have to
librium is reached."
Yes, you apply an initial work to compress part of the empty tank spring, but when you reach the compression point, you keep the force, but you don't make work any more.
Cala,
You can use the energy stored in
the spring once, but once you have
used it it is not possible to use
it again. This is because "using"
it means turning it into work.
If you use the water flowing from
one tank to the other to run a
turbine to generate electricity
then the energy of the compressed
spring is now electrical energy.
The amount of this electrical en-
ergy will never be equal to the
original work it took to put water
into the tank to begin with and
compress the empty tank's spring.
You will have lost some energy to
friction/heat, sound, vibration.
You will be able to replace some
of the water but not all. The
second cycle will produce less
electrical energy than the first.
Each cycle will produce less elec-
tricity until the thing stops
running. In the meantime all it
has accomplished is to run itself.
In conclusion all you have done
is to create a very awkward kind
of pendulum.
zoob
  • · Replies 22 ·
  • · Replies 28 ·
9K
