Freezing Lake - Heat Energy Questions
The discussion centers on calculating heat transfer and ice formation in a small pond with a 1cm thick layer of ice at -10°C air temperature. Participants confirm that the temperature of the liquid water just below the ice is 0°C, as it is the coldest temperature water can reach without freezing. The forum also emphasizes the importance of expressing the rate of heat transfer through the ice and the heat flow required to freeze water, guiding users to consider factors like temperature difference and insulation thickness in their calculations.
  • Understanding of heat transfer principles
  • Familiarity with phase change concepts
  • Knowledge of the specific heat capacity equation (Q = mcΔT)
  • Ability to apply the latent heat equation (Q = mL)
  • Research the heat transfer equation for conductive materials
  • Learn about the effects of temperature gradients on ice formation
  • Explore the concept of latent heat in phase changes
  • Investigate the relationship between insulation thickness and heat loss
Students studying thermodynamics, physics enthusiasts, and anyone interested in understanding heat transfer and ice formation in natural bodies of water.
CallMeShady
Freezing Lake
A small pond has a layer of ice 1cm thick floating on its surface. The air temperature is -10°C. Steps (a-c) should help you find the final answers in (d) and (e).
(a) What is the temperature of the liquid water just below the ice?
(b) Write the expression for the rate of heat transfer through the ice as a function of thickness of the ice?
(c) Write the expression for the rate of heat flow required to freeze the water? Hint: first find how much heat must be removed to freeze a given thickness of ice.
(d) Find the rate in cm/hr at which ice is added to the layer.
(e) How long does it take for a 20cm layer to build up?
Q = mcΔT (temperature change)
Q = mL (phase change)
I cannot begin the other parts of this question without having the first part answered and I am stuck right in the beginning. I need a booster to help me get started and to push along this question. At the moment, I attempted to solve part (a) and figured that there are no calculations involved; I assume that the water just below the ice would be at 0°C since that immediate area between ice and water in contact is where the phase change occurs. However, I might be wrong. Anyone here willing to guide me in the right direction?
Thank you.
For (a) ... the water just below the ice is still a liquid ... what is the coldest water can get without freezing?
I figured that out... I am working on part c) and d) now. The coldest the water can get is 0°C without completely freezing.
Thank you for your assistance. :)
No worries: it is common that even just writing down the question leads to the answer.
Helps to show your working for a and b though ... part of the point of these forums is so that your difficulties can help others in the same fix later: you may have the answers now but others googling to your question may be yet to find them.
Tell me when you are next stuck.
I am actually stuck on this question too. I managed to figure part A out on my own but I'm stuck on part B.
Think about what the heat loss is likely to be proportionate to.
For example the heat loss from a building is likely to be proportional to the temperature difference between the inside and outside, the type of insulation etc and inversely proportional to the thickness of the insulation. What's the simplest way you can write that out.
Welcome to PF Maskawisewin ... ideally OP will tell you how he did the parts you are stuck on but CWatters has a good hint too ;) Let us know how you get on.
