Calculating Frenet-Serret Equations for a Twisted Curve
  • Thread starter Thread starter bigevil
The discussion focuses on calculating the Frenet-Serret equations for a twisted curve defined by the equation y³ + 27axz - 81a²y = 0, parametrically represented as x = au(3 - u²), y = 3au², and z = au(3 + u²). Key findings include the arc length formula ds/du = 3√2a(1 + u²), the total length of the curve from the origin to the point (2a, 3a, 4a) being 4√2a, and the radius of curvature at any point with parameter u being 3a(1 + u²)². The discussion highlights a common error in the evaluation of the unit normal vector, specifically regarding the placement of the √2 factor.
  • Understanding of parametric equations in three-dimensional space
  • Familiarity with calculus, particularly differentiation and integration
  • Knowledge of the Frenet-Serret formulas and curvature concepts
  • Experience with vector calculus and unit vectors
  • Study the derivation of the Frenet-Serret equations in detail
  • Learn about curvature and torsion in three-dimensional curves
  • Explore applications of parametric curves in physics and engineering
  • Practice problems involving the calculation of arc length and curvature
Students and professionals in mathematics, physics, and engineering who are working with curves in three-dimensional space, particularly those interested in advanced calculus and differential geometry.
bigevil
For the twisted curve y^3 + 27 axz - 81a^{2}y = 0, given parametrically by
x=au(3-u^2), y=3au^2, z=au(3+u^2)
show that the following hold
\frac{ds}{du} = 3 \sqrt{2} a(1+u^2), where s is the distance along the curve from the origin
the length of curve from the origin to (2a, 3a, 4a) is 4\sqrt{2}a
the radius of curvature at the point with parameter u is 3a(1+u^2)^2
The first two parts are relatively painless. First part, evaluate \frac{d\bold{r}}{du}\cdot\frac{d\bold{r}}{du}. Second part is to integrate its square root between s=1 and s=0.
The last part is a bit troublesome though. First, I get \hat{\bold{t}} = \frac{dr}{ds} = \frac{dr}{du} \cdot \frac{du}{ds}, where du/ds can be gotten from above.
then \hat{t} = \sqrt{2}(1+u^2)^{-1} [(1-u^2)\bold{i} + 2u\bold{j} + (1+u^2)\bold{k}].
Then evaluating, x component of dt/du: -4\sqrt{2} \frac{u}{(1+u^2)^2}
y component of dt/du: 2\sqrt{2} \frac{1 - u^2}{(1+u^2)^2}
z component is zero.
Evaluate dt/ds = dt/du (dot) du/ds,
\frac{d\hat{t}}{ds}= \frac{-4u}{3a(1+u^2)^3} \bold{i} + \frac{2(1-u^2)}{3a(1+u^2)^3} \bold{j}
Then taking magnitudes and applying the inverse, \rho = \frac{3}{2}a(1+u^2)^2
Which is pretty weird! The answer does not have the 1/2 coefficient. I'm not sure where I went wrong here. Guidance will be gratefully accepted...
Check your unit normal t-hat. I've got the sqrt(2) in the denominator. Not the numerator.
  • · Replies 27 ·
  • · Replies 22 ·
