Frequency for resonance to occur
33 replies · 4K views
Helly123
That is a speaker. Sound wave is sent out from spesker S into pipe of uniform thickness.
Piston P move to left
1st resonance at 0.045 m
2nd resonance at 0.151 m
Frequency of the sounx 1620 Hz
Piston is stopped at the position that 2nd resonance occur
Then, frequency increased litle by litle
Find frequency at which resonance occur again
End correction is 0.008 m
##\lambda## = 0.21 m
Velocity = 340 m/s
Frequency = Velocity/##\lambda##
L2 = 0.151 m = 3/4 ##\lambda##
##\lambda## = 4/3 (0.151)m =0.2
Frequency = 340 / 0.20 = 1700 Hz
How to find frequency when resonance occur again?
What will change the frequency, the velocity, or ##\lambda## ?
What do you think? If you move from a larger to a smaller room, does the speed of sound change?
##\lambda## = 212 m
Velocity = 340 m/s
Notice that your calculated speed of sound does not match the speed of sound given in the problem statement. What are you going to do with the end correction?
Oops. I meant to say your calculated frequency does not match the frequency given in the problem statement.
It changes. Larger room = faster?
tnich said:
Oops. I meant to say your calculate frequency does not match the frequency given in the problem statement.
I calcuated the frequency when occur again, after stopped.
Frequency of 1620 Hz is when 1st and 2nd resonance occurred at initial state
The speed of sound in a ideal gas depends on things like the temperature and the mass of the gas. Here you have air which you may assume is an ideal gas at constant temperature and constant humidity. Therefore, you may safely assume that the speed of sound is constant within the piston.
I am not sure what you mean by that. Did you use the end correction?
Therefore? What affect the frequency is the wave lenght?
Ok. I used End correction to find the lambda before.
First. There are 2 resonances occurred at 0.045 m and 0.151 m . With end correction 0.008 m, frequency 1620 Hz, and lambda is 0.21 m.
Then, the piston stopped at 0.151 m
After that, we want to make the sound to resonance again. At what frequency it is?
This is the full version of the question
In case. I gave the question unclear.
And hope the image shows clear too
And number 4
Piston stopped at position which 2nd resonance took place. If frequency of speaker increased little by little at what frequency for resonance to occur again?
And number 4
Thanks. It helps to have those details. As you said in post #23, changing the frequency will change the wavelength. You have figured out that the first resonance is at ##L_1(λ) = \frac λ 4 - ε## (where L_1(λ) is the length of the pipe and ε is the end correction) and the second resonance is at ##L_2(λ)= \frac {3λ} 4 - ε##. Given a wavelength λ, at what length ##L_3(λ)## will the third resonance occur?
##L_3(λ)= \frac {5λ} 4 - ε##
Right?
Right?
Yes.
tnich said:
Yes.
Lambda when 1,2,3 resonance still the same?
Then frequency not change?
You have the pieces you need. You that increasing the frequency will decrease the wavelength. You know the length of the tube, so you can use ##L_3(λ)= \frac {5λ} 4 - ε## to calculate λ. You know ##fλ=v##, so you can calculate frequency.
So, ##L_3## = ##L_2## = 0.151 m ?
##L_3(λ')=L_2(λ)=## 0.151 m
Do you mean that. We want to have 3rd resonance at the length of 0.151. Hence, we increase the frequency?
I think that is just a restatement of the question in your original post:
The only additional assumption is that frequency at which resonance occurs again is the third resonance.
Ok. The frequency is increased to get 3rd resonance? While the piston not moving?
##L_3(\lambda')## = ##\frac{5}{4}\lambda## - ε
0.151 = ##\frac{5}{4}\lambda## - 0.008
##\frac{5}{4}\lambda## = 0.159
##\lambda## = 0.1272 m
But it is wrong. Why?
Why do you say it is wrong?
tnich said:
Why do you think it is wrong?
Frequency = v/lambda = 340/0.1272 = 2,672 Hz
It's not the answer
It's not the answer
You have accumulated some round-off errors. I get a nice round number for the frequency.
Should i round the answer to 0.13?
If it rounded to 0.2 m
It will get 1700 Hz nice number
Nope. How did you get 340 m/s for the speed of sound?
Lambda * frequency = 0.21 m * 1620 Hz = 340.2 m/s
With no round-offs, I got speed of sound = ##\frac 4 3 (.151+.008) 1620 = 343.44## m/s. That is not a big difference, so maybe that is not the problem, but it does give a round number for the final frequency.
Maybe
##\lambda## = 0.2 * 4/5 = 0.16 = 0.2 m
That way, frequency = 340/0.2 = 1700 Hz
