How Do You Calculate Friction and Motion for a Grocery Cart on Asphalt?
  • Thread starter Thread starter Dyna
    Friction
The discussion focuses on calculating the friction, acceleration, and distance traveled by a grocery cart on asphalt. The cart has a mass of 32.0 kg, and an applied force of 400 N is used to move it. The coefficient of friction is 0.87, leading to a calculated frictional force of approximately 270 N opposing the motion. The net force results in an acceleration of about 4.0 m/s². Participants emphasize the importance of significant figures in calculations and correcting any rounding errors to ensure accuracy in the final results.
Dyna
1.A grocery cart has a mass of 32.0 kg. An applied force of 4.00 x 10^2 N [E] is used to move the cart. The cart starts from rest and the force is applied for 5.0s.
a) Calculate the force of friction acting on the cart if the coefficient of friction between the cart and asphalt is .87
b) Calculate the acceleration of the grocery cart
c) How far does the cart move in 5.0s?
Edit: since there is no vertical movement Fnety = 0 and Fg = mg
therefore Fn = mg
Fn = (32 kg)(9.81m/s^2)
= 313.92 N
=310 N (sigdigs)
Ff = mu(Fn)
=.87 x 310
= 269.7 N
= 270 N [W]
but i have no idea if that's accurate or not =\ i started on part b, which is dependant on part a so if i don't have this correct then i can't continue
Edit two
i began part b ...
so...
Fnetx = (4.0 x 10^2 N [E]) - 270 N [W]
= 130 N
F = ma
130 N = 3.2 kg (a)
a = 4.06 m/s^2
a = 4.0 m/s^2
Welcome to PF.
I see the three part question, but I don't get much of a sense of 3 part effort on your part to address the problem.
Care to share what you are having a problem with?
Oh sorry >.< Okay so i tried finding the friction
therefore Fn = mg
= 313.92 N
=310 N (sigdigs)
Ff = mu(Fn)
=.87 x 310
= 269.7 N
= 270 N [W]
Rounding 313.92 N to three sig. dig. precision gets you 314 N, NOT 310 N. Can you see that 310 N would not make any sense? If some force was exactly 313.92 N, but you had a weigh scale to measure it that was only accurate to the nearest Newton (i.e. the markings on the dials on the weigh scale are in 1 N increments), then your measurement of this force will cause the needle to appear very close to the 314 N marking. You would conclude that (to the accuracy of your measuring device), the force was 314 N.
In this case you aren't doing the measurements yourself, but you are assuming that the numbers quoted in the problem are measured quantities, not exact ones. Therefore, you are limiting your calculated results to have the same precision as that of the least precise given measurement, therefore using it to determine the appropriate number of sig digs for the answer (a number that ensures you are not overstating the precision of your result and therefore overstating the certainty with which you know it).
If you intended to express it to two sig digs, then remember that trailing zeros count as sig digs. Therefore, you cannot state it as 310 N. You would have to say 3.1 x 102 N. Because your precision is limited to two sig digs, all you can say is that the measurement is somewhere between 310 and 320 N, but you don't know it any more precisely than that, because you can't measure that third digit.
Anyway, your calculation of the normal force looks fine, aside from that error. Your equation for the frictional force also looks correct (although you must correct that error in order to get the right friction force).
Oh okay thank you but then wouldn't i have to state the answer for part a as 3.1 x 10^2 because i cannot state 3.14?
i began part b ...
so...
= 130 N
F = ma
130 N = 3.2 kg (a)
a = 4.06 m/s^2
a = 4.0 m/s^2
Well...32.0 kg and 9.81 m/s2 are both given to three significant digits. So why are you limiting yourself to two for the final answer?
Dyna said:
i began part b ...
so...
= 130 N
F = ma
130 N = 3.2 kg (a)
a = 4.06 m/s^2
a = 4.0 m/s^2
I haven't checked your arithmetic. Your method looks okay. Okay, so now you know that the cart is moving with some constant acceleration, and you know what that acceleration is. You also know how long it accelerates for. Can you think of some equation that can give you the final velocity of an object that has been accelerating at a constant rate for a certain amount of time?
We were taught that for sigdigs we use the lowest amount of sigdigs in the given information as the number of sigdigs in our final answer
So would I find v2 since v1 = 0 ?
a = v2-v1 over time
4.o m/s^2 = v2 - 0 over 5s
20m/s = v2
therefore subbing in 5 seconds? to find the distance?
Or can i not sub in 5 seconds twice?
LOL. I know that. What I am saying follows exactly from that rule. Since both of the quantities you used to calculate the normal force have three sig digs, the lowest number of sig digs of the two of them is...three. Therefore, the final answer for the normal force should have three sig digs.
a = v2-v1 over time
20m/s = v2
Your work looks correct, although I think you have a fair bit of rounding errors. Although you should express (i.e. write down) your answers to the correct number of sig digs, in multi-step calculations, you should keep the full number of digits for the calculated intermediate values on your calculator, and not round until you get to the end of the multi-step calculation. This avoids rounding errors from being introduced throughout your calculation. So for instance:
313.92 N * 0.87 = 273.1104 N.
You would express the answer as 2.7 x 10^2 N, but in the NEXT step, you would keep the full value (273.1104 N), and say:
Fnet = 400 N - 273.1104 N = 126.8896 N
a = 126.8896 N / 32.0 kg = 3.9653
You would express this final answer correctly (to two sig digs due to the friction force) as 4.0, but in the NEXT step you would likewise use the full value of the acceleration (to prevent rounding errors).
Sorry, I made a mistake here. I thought that the question was, "How fast is the cart moving after 5.0 s?" But it is in fact, "How far does the cart go in 5.0 s?" Therefore, you need to use an entirely different equation, one that gives you the distance traveled given a constant acceleration and a certain time interval.
No, you can't just sub the 5.0 s in again, because the velocity is not constant.
Wow thanks for all the help!
I'm going to try redoing my questions with your advice =]
I may be back for another question later tonight haha >.<
Thanks again~
  • · Replies 27 ·
10K
