Friction : BLOCKS AND A PULLEY
The discussion revolves around a physics problem involving two blocks stacked on top of each other, connected to a third block via a pulley system. The problem focuses on the forces acting on the blocks, particularly the frictional forces, and the conditions under which the blocks move together or slip relative to each other. The subject area includes dynamics, friction, and Newton's laws of motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the forces acting on the blocks, particularly the frictional force required to prevent slipping between block 1 and block 2. There are attempts to derive expressions for the frictional force and the conditions for motion. Questions arise regarding the nature of static versus kinetic friction and how to relate the forces to the masses involved.
The discussion is ongoing, with participants exploring various interpretations of the forces involved and attempting to clarify their understanding of the frictional interactions. Some participants have made attempts to solve parts of the problem, while others are seeking clarification on specific aspects of the setup and the equations involved.
There is a mention of constraints related to the coefficients of friction and the conditions under which the blocks move together. Participants are also navigating the complexities of the problem setup, including the roles of static and kinetic friction.
judas_priest
A block of mass m1 is on top of a block of mass m2. Block 2 is connected by an ideal rope passing through a pulley to a block of unknown mass m3 as shown. The pulley is massless and frictionless. There is friction between block 1 and 2 and between the horizontal surface and block 2. Assume that the coefficient of kinetic friction between block 2 and the surface, μ, is equal to the coefficient of static friction between blocks 1 and 2.
Q1 : The mass of block 3 has been changed such that block 1 and block 2 are moving together with a given acceleration of magnitude a. What is the magnitude and the direction of the force of friction exerted by block 2 on block 1?
Q2: What is the minimum value of m3 for which block 1 will start to move relative to block 2?
Force of friction exerted by block 2 on block 1 to keep them both moving without one sleeping over another is [tex]m3g - μ(m1+m2)g = μm1g[/tex] Correct me where I'm wrong.
minimum value of m3 for which block 1 will start to move relative to 2 is [tex]m3g>μm1g[/tex]
Therefore, m3>μm1
Both my answers are wrong. Not able to go any where with this. Someone please explaing, and I'll solve.
Take it in smaller steps. You are given that the acceleration is a. What are the forces acting on block 1? If it's accelerating at rate a, what does that tell you about the frictional force between 1 and 2?
Forces acting on 1 is friction between block 2 and block 1 towards left. It is accelerating with block 2, so friction gets stronger to maintain no slipping condition. The friction, since it is static, cannot be μN.
How do I get the value of friction force so that it moves with block 2?
Towards the left on which block? Which way is block 1 accelerating?
Why does the force need toi get stronger to accelerate at a constant rate?
Static/kinetic refers to relative movement of the surfaces in contact. If 1 is not slipping on 2 it's static friction.
You know the mass, you know the acceleration, so what's the force?
I figured out the second part. Could you hint me with the third?
Here's my attempt to the third part:
Since block 1 starts to move relative to block 2, it goes into kinetic friction. therefore:
[itex]m1a = mu*m1g[/itex]. Cancelling m1 would give me the minimum acceleration. How do I relate it to m3?
After drawing FBD for block 2 and 3, and substituting the acceleration for in previous post, I et
[tex](2*mu*m2+mu*m1)/(1-mu)[/tex]
Is this correct?
Is this correct?
I get something slightly different, Pls post your working.
For block 3:
[itex]m3g - T = m3a[/itex]
For block 2
[itex]T - mu*(m1 + m2)g = m2a[/itex]
From block 1, a = mu*g.
Substituted a in equations of block 2 and block 3.
Where am I going wrong?
Need to learn Latex. Sorry for making it confusing.
You've left out a force on m2.
Which one? I don't see any more horizontal forces. Is it the reaction force of friction on block 1?
Still don't get the answer. What did you get? How did you do it?
Yes. What do you get when you include that?
Okay, got it! Thanks!
Why do not suppose that 1 "feeling" that 2 moves to the right generates a friction to the left to compensate m3g ?
I am unable to decipher your question.
Instead of asserting that 2 generates a friction to prevent 1 to stay steady, why don't you assert that it's 1 which generates a friction to prevent 2 to move ?
We are not concerned (in the last part of the question) with whether 2 moves. The critical point is whether 1 moves with 2 or lags behind. Besides, the friction between 1 and 2 could never prevent 2 from moving.
Hello. I've been working on this problem as well and I have not been able to get my head around both of these questions. Could you please help me? :)
As for a new thread, please post your attempt.
Yes, I have now.
  • · Replies 37 ·
  • · Replies 17 ·
