Undergrad Is the Frobenius Norm a Reliable Indicator of Matrix Conditioning?
The Frobenius norm of a matrix, calculated as 1.45 in this discussion, does not directly indicate whether a matrix is well-posed or ill-posed. The critical factor for determining matrix conditioning is the ratio of the largest singular value to the smallest singular value. A significant disparity, such as a ratio of 10^40, indicates an ill-conditioned matrix, despite the Frobenius norm being relatively low at 1.5. This highlights the importance of understanding the relationship between different norms and their implications for numeric stability.
  • Understanding of matrix norms, specifically Frobenius and Max norms
  • Knowledge of singular value decomposition (SVD)
  • Familiarity with concepts of well-posed and ill-posed problems in numerical analysis
  • Basic principles of linear algebra, particularly from "Linear Algebra Done Wrong"
  • Study the relationship between singular values and matrix conditioning
  • Learn about the implications of different matrix norms on numeric stability
  • Explore the concepts of well-posed and ill-posed problems in numerical methods
  • Read "Linear Algebra Done Wrong" to strengthen foundational knowledge in linear algebra
Mathematicians, data scientists, and engineers who work with numerical methods and matrix analysis, particularly those interested in understanding matrix conditioning and numeric stability issues.
SeM
I have calculated that a matrix has a Frobenius norm of 1.45, however I cannot find any text on the web that states whether this is an ill-posed or well-posed indication. Is there a rule for Frobenius norms that directly relates to well- and ill-posed matrices?
Thanks
I assume by "ill posed" you mean poorly conditioned, i.e. potential numeric stability problems associated with inversion.
Like I said in your thread here:
https://www.physicsforums.com/threads/how-can-i-analyse-and-classify-a-matrix.931056/
it's the ratio of the largest singular value to smallest singular value that matters. I really struggle to imagine why you'd take that information and then ask a question about about adding up all the squared singular values, and asking what that sum (or the square root of that sum) tells us about condition number.
Perhaps it'd be prudent for you to make your way through the first 7 chapters of Linear Algebra Done Wrong:
https://www.math.brown.edu/~treil/papers/LADW/LADW.html
It would walk you through many of the fundamentals needed to connect the dots between these different ideas.
Not really need to go through an entire book for this. It's actually as comprehensive as you wrote here, which I was not aware of. However, the strange thing is that if the ratio between the smallest and largest values of the matrix is in the magnitude of 10^40, it defines an ill conditioned matrix, and the Max norm is very high, about 78. However, the Frobenius norm is "only" 1.5 , so I thought it was strange these two norm would deviate so much.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 17 ·
  • · Replies 27 ·
