Frustrated by simple algebra problem
  • Thread starter aerospacedout
    Algebra
4 replies · 2K views · last reply
aerospacedout
For small changes in temperature, the formula for the expansion of a metal rod under a change of temperature is:
L-Lo = aLo(t - to)
L= length at temp. t
Lo= initial length at temp. to
a= constant that depends on metal
A) express L as a linear function of t. Find the slope and y intercept(hint: treat the other quantities as constants.)
Y=mx+b
Y-Yo=m(x-xo)
Solution 1?: the slope is aLo as stated by the equation, and the y intercept is Lo...
Distribute
L= a lot-aLoto+Lo
L=Lo(at-ato+1)
Doesnt work, still has variable to, lo, etc.
Solution 2?: assume a=1
L=Lo(t-to+1)
Slope= Lo? Y intercept also lo?
Solution 3: Lo, a and to=0
L=0... doesn't work
Or, pretend all constants=1
L-1=1(t-1)
L=t
Seems too specific.
I don't really know from which other angle to tackle this problem, I would appreciate some ideas, although I can imagine the answer should be obvious to me. I don't know how to turn this fully into y=mx+b. Thanks in advance.
Are to, lo variables? Or are they constants which look like variables?
They are constants i suppose, because they are the initial condition which doesn't change. But i don't understand what "treat them as constants" means... does it mean i could just ignore them?
Tried another way..
From L=a lot-aLoto+lo
Y intercept= aLoto+lo
Slope=aLo
Tried another way..
Slope=aLo
That y intercept is -aL0t0 + L0 .
Either way might be correct.
The initial result is correct if the y-axis is at t = t0 .
The result is the post quoted here is correct if the y-axis is at t = 0 .
The slope is the same in both cases.
The result you have in your Original Post makes more sense to me.
Tried another way..
Slope=aLo
Your final answer here is not quite correct. If we use 'intercept' to have its normal meaning, then you need Intercept = L_0 - a L_0 t_0 (not L_0 + a L_0 t_0 as you wrote).
"Treating them as constants" means that they are not the variables in this problem, but certainly you cannot ignore them. The only "variables" here are L and t. In a specific problem the parameters L_0 and t_0 would be given some numerical values, but that would still allow L and t to vary.
