Calculating Fuel Efficiency of Rocket Going Near c
  • Context: High School
  • Thread starter Thread starter Peter564
    Efficiency Fuel Rocket
To calculate the fuel efficiency of a rocket weighing around 10 tonnes traveling near the speed of light, one must utilize the relativistic rocket equation and consider the exhaust velocity of the rocket. The fuel efficiency can be defined as the ratio of the change in energy of the rocket to the change in energy of the fuel. Key parameters influencing this calculation include the exhaust velocity, the starting mass ratio, and the current velocity of the rocket. Additional considerations may involve analyzing relativistic effects such as Doppler shift in scenarios like a laser-driven light sail.
  • Relativistic rocket equation
  • Exhaust velocity of rockets
  • Mass ratio calculations
  • Doppler effect in relativistic physics
  • Research the relativistic rocket equation in detail
  • Study the concept of exhaust velocity in rocket propulsion
  • Explore mass ratio calculations for space travel
  • Investigate the Doppler effect and its implications for high-velocity objects
Aerospace engineers, physicists, and anyone involved in advanced rocketry or space travel calculations will benefit from this discussion.
Peter564
How would you calculate the fuel efficiency of a rocket (around 10 tonnes) going near the speed of light?
You would take the change in energy of the rocket and divide it by the change in energy of the fuel.
There are several things you might be interested in - are you interested in how much fuel you need to get a specified increase in velocity?
Basically, you need the relativistic rocket equation, and the exhaust velocity of the rocket, if that's what you're trying to measure. I would suggest https://math.ucr.edu/home/baez/physics/Relativity/SR/Rocket/rocket.html for the relativistic rocket equation. Wikipedia also has an entry which I'm less familiar with, https://en.wikipedia.org/wiki/Relativistic_rocket.
Other interesting cases you might consider are a relativistic laser driven light sail with perfect transmission efficiency. But I don't recall seeing anything written about that, though it's an interesting case to analyze. Doppler shift of the light from the laser makes the acceleration of the rocket taper off as it reaches higher and higher velocities.
It's really up to you to give more details of what you consider to be "fuel efficiency", one suggestion is the amount of energy in the burned fuel vs the amount of energy that the rocket gains in some specific frame of reference where the rocket's velocity is given by some particular value. You will, of course, find in this case that choosing this definition of "fuel efficiency" makes the "fuel efficiency" dependent on the choice of frame of reference in which it's mentioned.
The key parameters I see are the exhaust velocity of the rocket, the starting mass ratio of the rocket, and the current velocity of the rocket.
  • · Replies 52 ·
  • · Replies 114 ·
12K
  • · Replies 90 ·
  • · Replies 16 ·
  • · Replies 28 ·
