Fuel Saving Thread: Motoring Tips & Tricks
  • Thread starter Thread starter wolram
    Fuel Thread
The discussion revolves around various methods and tips for saving fuel while driving. Participants explore both tested techniques and speculative ideas related to vehicle maintenance, driving habits, and modifications that may enhance fuel efficiency.
  • Some participants suggest that maintaining a vehicle in top running order, including proper tuning and tire pressure, is essential for fuel efficiency.
  • One participant mentions that driving habits, such as driving slower and less frequently, are proven methods to save fuel.
  • There are claims that removing power-hogs like A/C compressors can improve fuel economy, though safety concerns about removing drive belts are raised.
  • Several participants discuss the impact of weight on fuel economy, noting that carrying unnecessary items can significantly reduce efficiency.
  • Using cruise control on trips is mentioned as a method that can help improve fuel efficiency.
  • One participant proposes that buying fuel at cooler temperatures may yield more dense fuel, although others challenge the practicality of this idea due to storage conditions.
  • Performance modifications, such as installing a Yost power tube in carbureted vehicles, are discussed as ways to improve both performance and fuel economy.
  • There are suggestions regarding the benefits of switching to performance exhaust systems and using electric fans to potentially improve mileage.
  • Driving courteously and avoiding aggressive driving are mentioned as methods to save fuel.
  • The use of daytime running lights is debated, with some arguing it increases engine load while others note the minimal savings involved.
Participants express a variety of views on fuel-saving methods, with no consensus on the effectiveness of specific products or modifications. Some ideas are supported by multiple participants, while others remain contested or speculative.
Some claims depend on specific vehicle types or conditions, and the discussion includes various assumptions about driving environments and vehicle configurations. There are unresolved questions regarding the practicality and safety of certain modifications.
Individuals interested in improving fuel efficiency, automotive enthusiasts, and those looking for practical tips on vehicle maintenance and driving habits may find this discussion relevant.
  • #151
OmCheeto said:
...You can now bid on a 150mpg Toyota Prius plug in hybrid on ebay.
150 seems inflated. The PHEV Prius modified by google reports ~93mpg avg, 115mpg peak.
http://www.google.org/recharge/experiment/
  • #152
It's not inflated, it's just that "fuel economy" is a completely meaningless concept when talking about plug-in hybrids. If you take a short trip and never need to turn on the engine, the "fuel economy" would be infinite. If you take a long trip and run on the engine for 90% of it, the fuel economy will be more like 35-40 mpg.
There are federal standards for fuel economy ratings, but they probably have not been updated to cover plug-in hybrids and electrics. They need to be. For pure electric vehicles, you need range and miles per kWh(a direct replacement for mpg that could even use the same test) under city and highway driving. For plug-in hybrids, you need the same thing, plus and city and highway mpg for pure engine operation.
  • #153
Since the graph and statement appear to have been generated by the company which performed the modifications to the Prius, I'd say there is room for suspicion.
EPA Urban Dynamometer Driving Schedule (UDDS) Test Results Show 150+ MPG with L5 PCM
They don't appear to include the energy of the battery pack in the calculations.
At 5kwh rated, it would have expended about 50 cents worth of energy over the 29.4 miles of the test. The general rule is to convert the value of the electricity into equivalent petrol costs. At $2.50/gal, this equates to 1/5 gallon. Which over 29.4 miles yields 147 mpg.
When combined with the mpg of the gas engine, we get about 75 mpg.
Still, not bad.
  • #154
Isn't "L5 PCM" the battery capacity?? The way I read the situation is:
What a Prius mod seems to do is change the formula for mixing the battery and gas power, allowing the battery to run down further than it would under normal hybrid mode. But since the Prius wasn't designed from the ground-up to be a plug-in hybrid, it just doesn't have the range on pure battery power to run for very long. So they run with both - just with less engine than in normal hybrid mode. This gives it what appears to be about 25 mi before exhausting the battery.
It would be beneficial for a consumer to actually be able to adjust the gas/electric mix based on their commute. If they only drive 20 miles, they aren't getting the best "fuel economy" they could because they could be runnig more on battery. If they drive more than 30, they also get hurt by not having any battery power left to help accelerate - basically losing the entire main benefit of a hybrid.
  • #155
Even running on batteries the Prius will occasionally run the engine - I think this is to keep the cat at the correct temperature.
The prius we had at work wasn't particularly impressive - overall mileage was worse than a European sub-compact, their excuse was that it was tuned to meet emissions specs in california which only counted the emissions when it was running on gas, not the overall average.
  • #156
I can't keep up with acronym's anymore. Everyone seems to be speaking in them.
That's exactly how I would do it.
A 3 mode switch on the dash with little symbols for the driving situation:
o:) : pure electric(good for dashes to the corner store, stuck in rush hour traffic, going down hills, Sunday driving): 150 mpg equivalent
:approve: : can't tell it from a pure gas fueled car(dynamic, uncertain situations): 75 mpg equivalent
:devil: : 1/4 mile dragster mode(getting on the freeway, eluding the cops, testosterone overloads): 25 mpg equivalent
The electric sections have the advantage of putting energy back into the battery pack.
Until we can figure out how to convert CO2 and H2O back into methane on the fly, ICE's are on my poop list.
I'd say company cars would be the worst example of potential for gas mileage. I've driven with my companies couriers. If they're not paying for the gas, it's :devil: mode all day long.
I'll see if I can't get the mpg numbers from our "fleet services" department.
  • #157
You comparing apples and pumpkins. The prius is not a subcompact and is actually a fairly good sized car. Most of those 50+mpg European cars can't even hold a bag of golf clubs let alone comfortably sit 4 people.
  • #158
Oh I agree - it was more that 'hybrid' doesn't automatically mean super fuel economy.
A small car VW Lupo, Nissan Micra with a 1.2litre diesel will do 70mpg for a fraction of the cost.
Even in city driving VW's approach of leaving out the batteries and having a small diesel engine that can start almost instantly and so turns off if you are stationary for more than a few seconds is possibly a better aproach.
  • #159
A recent article I read (I forget where, possibly The Engineer) interviewed two or three chief engineers working on hybrids. This was the primary complaint from all of them, and all their respective companies are currently lobbying governments to address this issue.
I'll try and find the article at work tomorrow, you'd find it good reading.
  • #160
They also need to be adjusted both ways - a lot of places have tax incentives for hybrids without considering how green they really are:
So Mercedes now have a hybrid option for their s400 luxury salon - it's a 300hp V6 gasoline with an 20hp electric motor, in case your CEO needs to reduce your CO2 emissions.
Our safety team has a hybrid Ford truck that is completely useless. If you go above 5mph or turn on the AC it starts the gas engine to provide enough power - the batteries can just about run the electric windows. I think the logic was, environment is good, safety is good therefore the safety guys must have a green vehicle!
  • #161
They probably have AA's powering the electric motor too. Sadly there is a lot be bureaucracy that comes with "going green". A lot of people spend money on crap like that just so they can think they are trendy and are making a difference. If you really want to save some fuel, then ride your bike like me.
  • #162
The UK introduced company car taxes based on the CO2 emission to discourage huge luxury company cars (or to tax the poor oppressed CEOs depending on you POV).
I'm betting Merc has found a loophole somewhere that you don't pay tax on hybrid company cars.
  • #163
mgb_phys said:
Side lights are compulsory over here.
Strangley my car turns them off when you put the handbrake on - even if the engine is running. It's a manual and I learned in the UK so I put the brake on like a good little safe driver everytime I stop.
Having a manual here is a great anti-theft device - people steal your car and drive off in first gear. It also means you don't have all that safety interlock crap where you can only start of the seatbelt is on, car is in neutral, feet are on the brake and you whistle the "star spangled banner" three times.
Hee hee.:smile: I dig standard for all those reasons and more... its also more gas efficient. However, you can't do cruise control which is highway gas efficient.
Yah, my solution is the Extreme Miser Driving School of Hard Knocks. This includes coasting up to red lights or... if on a hill... not accelerating. It also means coasting with no acceleration down hill. And never exceeding 50k (30mph) where posted since it is optimum (so we're told) for fuel saving measures. This gets the aggressors more aggressive so... in the long run and looking at the whole... perhaps it doesn't save gas because it gives the aggressive driver a reason to gun it!
  • #164
Let's get drastic. Electric cars will save lots of gas. The first city in North America to allow completely electric cars on its streets was Oak Bay just outside of Victoria BC in Canada. The next is Vancouver. We have electric truck and car manufacturers on the Island and Mainland who are doing better and better these days. Their getting some major speed out of these things and distances of about 180 k (kilometres). This is mostly for fleet vehicles mind you. There are some fuel cell fleet vehicles trolling around as well out of Vanc.
  • #165
Hmm, my manual has cruise control...
  • #166
My manual has cruise too.
  • #167
So does my wife's Subaru Legacy, and unless the terrain is very hilly, that little sucker stays right on target within a mph or 2.
  • #168
I had no idea. Well, it is Canada.
  • #169
Well that says it all right there. :biggrin:
  • #170
baywax said:
Let's get drastic. Electric cars will save lots of gas. The first city in North America to allow completely electric cars on its streets was Oak Bay just outside of Victoria BC in Canada. The next is Vancouver. We have electric truck and car manufacturers on the Island and Mainland who are doing better and better these days. Their getting some major speed out of these things and distances of about 180 k (kilometres). ...
Great! You buy the first round though.
  • #171
They are actually converting Ford F150s and the like.
Here are some manufactured from the ground up in Quebec (home of Bombardier)
http://www.zenncars.com/
Here's the Vancouver Electric Vehicle Association.
http://www.veva.bc.ca/home/index.php
Here's the full story about "Electric-car conversion alive on Vancouver Island"
http://www.canada.com/vancouversun/news/driving/story.html?id=e0190a0b-62d6-4d09-8eb7-0ac67ae8547d
He started out converting S10s (?) and now will convert any car as long as its lighter in weight. Looks like he got some of his inspiration from the State of Arnold (California).
But, I'll buy the first round!
Anyone ignoring or frightened by the prospect of getting off gas as a propellant is going to miss out on the multitude of new opportunities that will inevitably sweep the world. The same way gasoline exploded as an economic engine, sustainable electricity will be the next wave. Would Cold Fusion help in some way in this project? If so, can it actually happen?
  • #172
I'm not afraid.
I built an electric boat this year.
hmm... well, not totally unafraid...
I only invested $80...
And 70 of that was for that battery that I didn't pull out of my chia-boat.
  • #173
Vancouver just chnaged the rules it allowed light electric vehicles on roads where the speed limit was <40kmh - it just raised that to 50km/h (ie 30mph) to encourage them. Unfortunately there are a lot of bridges in Vancouver and the speed limit on all of them is 60km/h - so you can have an electric vehicle here, you just can't get it in or out of the city. (you can ride 50km/h limited gas powered scooters on the bridges)
  • #174
OmCheeto said:
I'm not afraid.
Whoa cool!
Solar panels instead of sails!
  • #175
That's true. Tons of bridges. Officially it would be a traffic violation. Unofficially there are scooters, electric scooters and Honda Passports on them all the time that don't do more than 40 kmph.
Sorry for side-railing the topic. This is supposed to be about saving fuel, not eliminating it from the diet. There's probably a while to go on gas before plugging into electricland.
Have U.S. car makers been aware of a way to manufacture highly efficient engines, yet have been held back from this practice by their main supplier of fuel, the oil industry? There's always rumours about that. How would one find out? Freedom of info?
  • #176
baywax said:
Whoa cool!
They can function as both.
I would say more, but that would be like giving away already known secrets. :wink:
  • #177
Mech_Engineer said:
This is what many people I know use: http://www.scangauge.com/
Love my new toy, thanks.
I'd be remis, however, if I didn't consider if such a device is worth the money for someone who buys it purely to improve fuel economy. So a little payback calculation:
I drive a Mazda 6i (2.4l, 160hp) that typically gets around 27 mpg. Let's say I am able to improve my fuel conomy by 5% and gas will cost an average of $2.50 a gallon for a while.
For every thousand miles I drive, I burn 37 gal at a cost of $92.60. So I'd save about $4.60 per thousand miles. The scangauge costs $170, so it will take 37,000 miles of driving to break even at that rate.
  • #178
This is just trash talk. For one thing, "freedom of information" applies to information that the government has. You can't knock on Ford's door and demand to see anything in their research files. For another, what do you mean by "their main supplier of fuel"?? The oil companies sell gasoline to you and me, not to Ford. Finally, the car manufacturers are in business to sell cars, not gasoline. If they could build a car that was identical in every way to an existing model, but used less gas, they would do it without hesitation.
The fact is, in America anyway, the customers have been choosing to buy big heavy "cars" (ie, SUVs and pickups) because we like the size and the performance. Suggesting that the manufacturers have been coercing us into this is just denial. Look back at the cheep cars marketed in the early 1980s (ford fiesta, renault 'le car', etc). These were popular for about six months and then were relegated to "sh*tbox" status. They are slow, with lousy acceleration, and you feel like nobody will let you merge into traffic, and once you are in traffic everyone is passing you. This goes against our "competitive spirit" and general machismo. Driving powerful cars is fun.
  • #179
So you're saying that if we want cars that get gets good gas mileage I should not buy a huge SUV that looks like an army truck? Gmax, how much are the oil companies paying you to say this?
I'm always amazed that when it comes to gas supply and prices, everyone points their finger at the oil companies or the auto manufacturers and never at themselves. People have been saying for years that the price of gas is so high because the demand is so high. No one listened and still blamed OPEC. Now that the economy has gone strait to hell and there has been a sharp decrease in demand, a gallon of crude is about $64 now I think? Perhaps the solution to the energy crisis is just to keep the world in a permanent recession.
  • #180
hmmm...
The most fun I've had was in a pedal powered go-cart when I was 11.
My favorite automobile(I've owned about 10) was a 1972 Toyota Corolla, 5 speed, with a 1.6 liter hemi-engine. Even when towing my boat, it would effortlessly cruise at over 90mph.
Before that I owned a 1.2 liter corolla. Quite the little "sh*tbox". But I could get around 40mpg driving back and forth between Portland and Seattle.
I drove the two Toy's for about 10 years. If I could find one of the hemi's today, I'd buy it in a heartbeat.
My least favorite car is the one I'm driving now. A lumbering, 3500 pound behemoth, with more horsepower than my last 4 cars combined.
I've never owned an SUV, so I don't know what the attraction is. My guess is that people want the utility of a station wagon, but they don't want to be seen in a station wagon, so they buy a station wagon that has a different, cooler name. And they keep getting bigger because those tiny little SUV's make really crappy station wagons. Perhaps they should have bought mini-van's in the first place.
63K
