Function of a random variable and conditioning
5 replies · 3K views
Hejdun
Ok, since nobody answered my last problem, I simplify. :)
Let Z = γ1X1 + γ2X2, where the gammas are just constants
p(Z) = exp(Z)/(1 + exp(Z))
X1 and X2 are bivariate normal and put
Y = α + β1X1 + β2X2 + ε where ε ~ N(0,σ).
Now, we want to find f(p(Z)|X1,Y). In this case, is it legal to do the
operation f(p(Z)|X1,Y)=f(p(Z|X1,Y))?
That is can we write
f(exp(Z|X1,Y)/(1 + exp(Z|X1,Y)))?
Thanks for any help!
/H
Let [itex]X_1[/itex] and [itex]X_2[/itex] each be bivariate normal random variables
Let [itex]Z = \gamma_1 X_1 + \gamma_2 X_2[/itex] where [itex]\gamma_1[/itex] and [itex]\gamma_2[/itex] are constants.
Let [itex]Y = \alpha + \beta_1 X_1 + \beta_2 X-2 + \epsilon[/itex] where [itex]\alpha,\beta_1,\beta_2[/itex] are each constants and [itex]\epsilon[/itex] is a normal random variable with mean 0 and standard deviation [itex]\sigma[/itex].
Is that notation supposed mean you want the probability density function for [itex]Z[/itex] given [itex]X_1[/itex] and [itex]Y[/itex] ?
I don't know what that notation means. The conditional density function of [itex]Z[/itex] is some function of the variables [itex]Z, X_1,Y[/itex] but what does the notation "exp(Z|X1,Y)" mean?
Yes.
For instance, if we want to know the distribution of p(Z) = exp(Z)/(1 + exp(Z)) and we know the distribution of Z, then we make a simple transformation, put the inverse in the pdf of Z and multiply with the derivative as usual.
However, the problem is finding the disitrbution of p(Z)|Y. My idea was then to put the inverse in the pdf of Z|Y and then multiply with the inverse. I am not sure if my approach is correct, but if you have another suggestion of how to proceed I would be grateful.
/H
Let's try again:
Let [itex]X_1[/itex] and [itex]X_2[/itex] be random variables that have a joint bivariate normal distribution (rather than each of them being bivariate normal).
Let [itex]W = \exp(Z)/(1 + \exp(Z))[/itex]
Let [itex]Y = \alpha + \beta_1 X_1 + \beta_2 X_2 + \epsilon[/itex] where [itex]\alpha,\beta_1,\beta_2[/itex] are each constants and [itex]\epsilon[/itex] is a normal random variable with mean 0 and standard deviation [itex]\sigma[/itex].
Do you want the conditional distribution of [itex]W[/itex] given [itex]X_1[/itex] and [itex]Y[/itex] ? (Your other thread mentioned a joint distribution instead of conditional distribution and also it mentioned that the final goal was to find an expected value.)
Stephen Tashi said:
Let's try again:
The final goal is to find the conditional distribution of X1 and Y given W. Of course, there are different ways of getting there depending on how you calculate the joint X1, Y, W.
My question in this thread may solve a part of the problem and also the disitrbution of W given X1 and Y.
Now that the problem is established, help me understand the question about technique.
Who's inverse and who's derivative are you talking about? Let's say [itex]Z[/itex] has cumulative distribution [itex]F_Z(x)[/itex] with inverse function [itex]{F_Z}^{-1}(x)[/itex]. Using that notation, what is your claim about the probability density (or cumulative distribution) of [itex]W[/itex] ?
