Torshi
- 118
Dick said:Sure plug and chug part b). Then part c) says to take a guess. Part d) says to verify it using the definition of derivative. Where are you stuck?
Torshi said:Part B: I did a similar one earlier, but alright so I'm using the g(x) equation right?
Double check:
So to get the value for 1.9 for the table I plug that number into this equation
5(1.9)^2+3(1.9)-4 - 5(2)^2 + 3(2) - 4 / (1.9-2)
Dick said:Ok. You aren't really using enough parentheses to indicate what you mean, but I'll trust you know. What do you get?
Torshi said:I got for question C - a number around 23.
The values I got for the table is in order from left to right: 22.5, 22.95, 23, 23, 23.05, 23.5
I need help for question D: I'm not familiar with the chain rule
Dick said:Ok, so you must have a pretty good idea for c). Why do you think you need a chain rule for d)?
Torshi said:Not sure, a friend told me - he may be wrong.
It says to calculate the IRC at x=2, do I just plug in 2 for 5(x)^2+3X-4 ?
Dick said:The IRC is the limit of g(x) as x->2, isn't it? That's what part b) was on about. g(x) is a difference quotient for f(x). What do limits of difference quotients have to do with derivatives? Check back to the definition of derivative.
Torshi said:a derivative is a function changing due to a different input or also how one quantity is changing due to another quantity.
Dick said:That's vague. The definition of f'(a) is limit x->a of (f(x)-f(a))/(x-a). Don't you have that definition someplace?
Torshi said:Yes, it's on the THQ question.
The reason why I'm sort of lost on these questions is 1.) I just started calc and 2.) We only covered 2 sections so far barely going over any problems. Matter of a fact our first problem section is tom w/ a classroom quiz over this material that he hasn't even covered fully.
Sorry for my lack of knowledge regarding this material. This is my last question and the packet is due tomorrow.
As for your question - yes i have it - not in classroom notes because he didn't go over it. But there is a question in the packet that involves the difference quotient and I solved it since it I knew it from college alg.
I'm still unsure for this last part. My 3rd class for calc is tom so we literally started a week ago.
Dick said:All ok. Part b) is asking you to compute values of (f(x)-f(2))/(x-2) for values of x that get close to 2. The closer x gets to 2 the closer you should be to the IRC. You should have guessed that the IRC is 23. To find it analytically you need to compare that with f'(2). Do you know how to find the derivative of f(x)=5x^2+3x-4 and put in x=2?
Dick said:Yes, but no chain rule. It's just differentiating really. Can you differentiate 5x^2, 3x or 4? Just checking what you know.
Torshi said:I got 10X +3
10(2) +3 = 23 IRC
I wasn't even taught this, but figured it out. Is this a precal thing?
Dick said:No, it's a full calculus thing. The precalculus thing would have been to derive lim x->2 (f(x)-f(2))/(x-2) from first principles. Any idea how to do that? Not having taken precalc is not going to help. But try and tough it out.
Torshi said:No idea how to do that. Did I get the right answer though?
And yea I'ma try. I really need to. This is my last semester in order to graduate ;/
Dick said:It's the right answer. The derivative of 5x^2+3x-4 is 10x+3. It's nice to know how to really derive things, but if it's the last semester just try and bluff your way through. Good luck!
Torshi said:Thanks, I appreciate the help! And I'll do my best to do so!
