Function represented as a power series
illidari
[url]http://img.photobucket.com/albums/v257/gamer567/powerseries.png[/url]
[url]http://img.photobucket.com/albums/v257/gamer567/cramster.png[/url]
I am getting lost from the transition in the 1/x-2 to 1/(x-2)^2. Could someone explain to me what happened? I think I could finish this problem and several others if I could understand this. Also is there a better approach? In other problems I took the derivative and put into a power series and then took the integral. This doesn't seem to be working on this one(?)
Apologies I am unable to edit, the equation in the picture needs to be represented as a power series if I didn't make it clear.
Before differentiating, the right-hand side can be rewritten as
[tex]\frac{-1}{2} \sum \frac{x^n}{2^n} = - \sum \frac{x^n}{2^{n+1}}[/tex]
Thus, we differentiate to get:
[tex]\frac{d}{dx}[\frac{1}{x-2}] = \frac{d}{dx} [ - \sum \frac{x^n}{2^{n+1}}][/tex]
[tex]\frac{-1}{(x-2)^2} = - \sum \frac{n}{2^{n+1}}x^{n-1}[/tex]
The reason we do this is because now we can multiply both sides by -x to give us:
[tex]\frac{x}{(x-2)^2} = \sum \frac{n}{2^{n+1}}x^{n}.[/tex]
Do you see how this is helpful in trying to get to the power series of f(x)?
As far as I know, this is the standard and easiest approach. You should learn and understand this method because I wouldn't be surprised if it pops up in some other problems.
Awesome that helps :) Got confused when they rearranged stuff while saying they are taking derivative.
No doubt this would be a nice mean test question :( Shall be redoing this one a couple times.
Handwritten-style derivation: putting x = 0 gives A = 0, tan^-1 x as a power series, then 1/x^2 minus tan^-1 x over x^3 rewritten with index shifted to n = 1, ending with a boxed term (-1)^(n+1) x^(2n-2)/(2n+1).
^^ New problem
If you don't mind me asking one more question, I am stuck as to how they got the last line of this solution to another problem.
From what I can tell, they plug in n=0 and got 1/(x^2) and then changed the power series to n=1
1/(x^2)-1/(x^2) cancels out and disappears. The thing I don't understand is how (-1)^n becomes (-1)^(n+1)
What am I missing here? The answer in the back of the book has it as well.
There's a negative sign in front of [tex]tan^{-1}x.[/tex] They bring it into its power series formula, thus raising the exponent on -1 to n + 1.
