Galileo and Lorentz transformation
171 replies · 28K views · last reply
meopemuk said:
You are right, I have a different definition of "reference frame". In my opinion, a better term is "observer" or "laboratory". In my definition, a reference frame is a laboratory fully equipped with measuring devices for all basic observables, which include position, momentum, energy, mass, spin, etc. Time is also measured by the laboratory's clock. Assigning space and time labels to events is just a small part of functions performed by the observer/laboratory. There are many other observables that determine the state of the observed system. It is not a big deal if different observers see different events. A viable relativistic theory must provide transformation laws for connecting system's description between different observers. If these laws are more complicated than relabeling of space-time coordinates, then so be it.
Eugene.
I can agree with all of that. I would note that, by definition, if the events observed actually happened (not illusions), then if two observers observe two different events, then two different events occurred.
Which means that while the events can be related, it obviously must be possible for both to occur if both are observed.
Fredrik said:
In what way are the frames equivalent when they (according to you) don't even agree about measurement results?
Well, in "normal" special relativity different frames also disagree about measurement results (for distances and time intervals). However, this does not make them inequivalent.
Fredrik said:
#2 is enough to imply Minkowski space,
I strongly disagree about that. There is no way you can deduce the existence of Minkowski space-time from the Poincare group alone.
Eugene.
DaleSpam said:
Meopemuk, I think you may be confusing some concepts here, or I am misunderstanding your point. You seem to be erroneously applying a many-worlds interpretation to special relativity where every inertial reference frame is a separate world which can disagree about the existence of physical events.
In MWI if an event happens in this world then it will happen in all reference frames in this world. There may be another world where it does not happen, and in that world it does not happen in any frame. There is no world where it happens in one frame but not another.
If I am misunderstanding your position could you please clarify?
No, I am not a follower of the many-world interpretation. Everything I'm talking about happens in our good old single world.
Eugene.
No, they do not. If a clock measures a given time in one reference frame then it will measure that time in all reference frames. Similarly with the measurement obtained from any rod. Different reference frames may disagree about whether or not that measurement corresponds to that specific frame's coordinate time or distance, but they will all agree on the value that the clock or rod measures.
I think you have a gross misunderstanding of the implications of the first postulate.
meopemuk said:
E. V. Stefanovich, "Violations of Einstein's time dilation formula in particle decays", http://www.arxiv.org/abs/physics/0603043
I guess the deviation appears in the numerical simulations in Figure 2, which is based on Eq 60. But Eq 60 is an approximation - do you think the apparoximation could be responsible for the deviation?
Naively to me I wouldn't think time translation should do anything. On the other hand, it does seem that an "event" doesn't really exist in relativistic QFT - since the Newton-Wigner operator is kinda weird, as you point out.
I don't quite understand what you mean here. Nevertheless let me repeat my most "outrageous" claim, so that it would be easier for you to attack my position.
Let's say we have one physical system - a piece of explosive - which is observed from different reference frames. If the two frames are moving with respect to each other, then standard SR predicts that their observations are different. For example, the two observers disagree about the length of the object in the direction of movement. I am saying that, in addition to that, the two observers may disagree about more substantial things. For example, one observer may find the bomb unexploded while the other may see the explosion.
This claim may look less outrageous if you replace in the previous example the pair of relatively moving observers (i.e., observers related by a boost) by the pair of observers related by a time translation. Then the statement like "the bomb does not explode today, while it will explode tomorrow" looks completely normal.
According to the Poincare group ideology, different types of inertial transformations must bear some similarity (as transformations from the same group). So, if we accept non-trivial dynamical effects of time translations, then we must accept (at least in principle) the possibility of non-trivial dynamical effects of boosts.
Eugene.
Let's say we have a one-meter rod viewed by two different observers. The observer at rest with respect to the rod will find its length to be 1 meter exactly. The observer moving with respect to the rod will find its length to be shorter than 1 meter. This is called "length contraction". This is what I mean by saying that different observers disagree about measurement results.
Eugene.
Yes, eq. (60) is an approximation. However, this is a pretty good approximation, as discussed in the beginning of section 11. I believe that the error associated with this approximation is much less than the magnitude of the obtained effect.
I agree that "localized events" is an ill-defined concept in quantum mechanics. Quantum particles don't stay localized for long - their wave packets spread. Moreover, a particle localized in one frame may be seen as not localized in another moving frame.
On the other hand, the decay law (considered in the paper) is a well-defined quantum-mechanical concept. In order to measure the decay probability (in any frame) you just calculate the ratio of decayed particles to the total number of unstable particles in the batch. If the batch is big enough, statistical deviations can be reduced to zero.
Eugene.
meopemuk said:
I don't quite understand what you mean here. Nevertheless let me repeat my most "outrageous" claim, so that it would easier for you to attack my position.
That claim isn't outrageous at all.
But "device has exploded" and "device hasn't exploded" are not a single event with different coordinates assigned by different observers. And they obviously don't contradict each other, unless an observer observes the former precede the latter instead of the other way around.
Now if the events are "device exploded when the attached clock read noon" and "attached clock goes past noon but device hasn't exploded", if each event is observed by different observers, they are two different events, not a single event observed differently, unless one is an illusion.
They certainly don't disagree in the way that we've been talking about so far. When two clocks disagree, it's because they're displaying the proper times of two different curves in spacetime. When two (inertial) rulers disagree about the length of an object, it's because they measure the proper distances of two different curves in spacetime. This is all completely standard, but it's not what we've been talking about. What you've been claiming is the equivalent of claiming that a single clock can display two different times at a single point in spacetime, in two different coordinate systems. This is extremely non-standard, so I find it strange that when I ask you about it, you're replying with a comment about trivial standard stuff.
You didn't explain how you can consider two inertial frames that can't even agree about what happens at a single event to be equivalent in any way.
Regarding the first "postulate": I have said this many times before, and I guess I'll have to say it many times again. It isn't a well-defined statement that you can use as the starting point of a derivation! It's often stated in the form "The laws of physics are the same in all inertial frame". The most generous interpretation of this that we can make, is that this represents a set of well-defined statements, that has one member for each definition of "inertial frame", each definition of "law of physics" and each definition of what it means for two laws of physics to be "the same".
I didn't say that. First, I have never referred to a "single point in spacetime". I even don't understand what this phrase means. I don't know which experimental measurements can tell two observers whether the events they see occur "at the same spacetime point" or at different spacetime points. I prefer not to use the "spacetime" language at all. Second, I don't like the term "coordinate system". It suggests the presumption that the only difference between moving reference frames (or observers) is in assigning different labels (or coordinates) to events, while all observers must agree on the presence/absence/nature of the events. I think that the terms "inertial observer" or "inertial laboratory" are more appropriate, because they do not exclude the possibility that different observers may actually see different events happening.
Eugene.
I disagree with that. In my opinion the first postulate is the most powerful, deep, and non-trivial statement in all physics. It just tells you that idential experiments in different laboratories produce identical results. It does not matter whether the laboratory is in Paris or in London. It does not matter whether the experiment was made today or a century ago. It does not matter whether the experiment was made in a spaceship standing still or in a spaceship moving with high velocity. Without this relativity principle, it would be impossible to compare results obtained by different researchers. Entire physics would be impossible.
Eugene.
If their observations are contradictory, logic dictates that at least one of them is simply wrong.
This is standard SR length contraction, but even here every frame agrees about the outcome of all measurements. The moving observer agrees that the stationary observer measures 1 m, and the stationary observer agrees that the moving observer measures less than 1 m.
meopemuk said:
I am saying that, in addition to that, the two observers may disagree about more substantial things. ... like "the bomb does not explode today, while it will explode tomorrow" looks completely normal.
This is just standard relativity of simultaneity. Is there something more to your position or are you just trying to state standard SR in a provocative manner?
Two inertial observers may see quite different events (not just the same events with different space-time labels, as usually postulated). This does not contradict any law of logic or physics.
Eugene.
This has nothing to do with the relativity of simultaneity.
In standard special relativity two moving observers may disagree about such "kinematical" properties as the length of an object or the duration of a time interval. However, they always agree about "dynamical" properties, like whether the bomb is exploded or not.
I am saying that these views must be generalized. Dynamical properties should be considered relative as well. I.e., different observers may disagree about them. It is possible that observer at rest does not see any explosion, while the moving observer (in the same location, at the same time) sees the explosion of the same object.
Eugene.
This is completely contrary to the first postulate. It is also not appropriate for this forum.
Of course they may see quite different events, as long as the observations don't contradict each other.
Logic only dictates that two mutually exclusive events don't both happen, so if both are observed, one of the observations is in error.
But this still has nothing to do with transforming the coordinates of a single event between reference frames.
DaleSpam said:
For example?
I keep repeating the example of a bomb, where two observers disagree about whether the explosion has occurred or not. I use this dramatic and unrealistic example just to make the general point absolutely clear.
More realistic examples concern observations of decays of unstable particles. In the post #5 I've cited a few references in which decay laws of moving particles have been studied in a rigorous relativistic quantum-mechanical setting. It follows, for example, that the particle that is seen as yet undecayed by the observer at rest (at time 0) has a non-zero decay probability from the point of view of the moving observer (at the same time). This is a more realistic analog of the unexploded/exploded bomb discussed above.
Of course, for known unstable particles and realistic observer speeds the "boost induced decay probability" is extremely small and cannot be presently observed. So, the whole issue is rather academic, but I think it is important nevertheless.
Eugene.
The first postulate tells that experiments in different laboratories yield the same results. This means that each laboratory studies its own copy of the physical system. The first postulate does not say how measurements performed by different observers on the same object are related to each other. In order to find these transformation laws one needs a full dynamical description of the system, i.e., the representation of the Poincare group in the Hilbert space of the system. In the instant form of Dirac's dynamics, this description demands the non-trivial dynamical character of boosts. See, for example
S. Weinberg "The quantum theory of fields" vol. 1. section 3.3.
I am ready to stop if you think so.
Eugene.
meopemuk said:
I didn't say that.
Actually you did. I said this:
Fredrik said:
You seem to be saying that a person can get shot and killed at age 20 in one coordinate system and die of old age at the age of 125 in another.
You replied:
meopemuk said:
Your example is rather extreme. Calculations show that the dynamical effects of boost are rather weak (there are no experiments capable of seeing these effects today). However, as a matter of principle, I would answer "yes".
In SR, a person's entire existence is represented by a set of curves in Minkowski space. For our purposes, we can ignore the spatial separation between these curves and describe a person's existence approximately using only one curve. The endpoints of the curve represent the beginning and the end of the person's life. If a person gets shot and killed at the age of 20, then the endpoint of the curve that has the higher time coordinate (in all inertial frames) is the mathematical representation of his death in the real world. All of the other points on the curve are mathematical representations of events earlier in his life. Every one of those points represents an event where his age is 20 or less. And you said that there are points on this guy's world line at which his age is 125.
So you have clearly said (possibly without realizing it) that there's a point in Minkowski space where this particular "clock" (a person is a clock too) is displaying 125 years in one coordinate system and 20 or less in another.
How can you not? You must know that each point in Minkowski space is supposed to be a representation of an event in the real world, or rather in the universe described by the theory. (I prefer to think of a descriptive theory as SR as an exact description of a fictional universe that resembles our own, than as an approximate description of our universe).
Special relativity is by definition a theory that uses a manifold called Minkowski spacetime to represent events. The definition of a manifold includes a bunch of stuff about coordinate systems, and a Lorentz transformation is a transition function between coordinate systems. So if you don't like those things, you must hate special relativity.
Edit: I have now read the posts where you talk about how the principle of relativity says that certain laboratories get the same results. I see what you mean now about laboratories vs. coordinate systems.
meopemuk said:
It suggests the presumption that the only difference between moving reference frames (or observers) is in assigning different labels (or coordinates) to events, while all observers must agree on the presence/absence/nature of the events. I think that the terms "inertial observer" or "inertial laboratory" are more appropriate, because they do not exclude the possibility that different observers may actually see different event happening.
I haven't completely ruled out that something like what you're suggesting might actually be valid, but the way you're talking about it is really strange. It's like you don't even see that what you're saying is something extremely different from anything that most of us have ever heard of in the context of SR. If it hadn't been you saying this (I've seen threads where you're the only one who gets it right), and if I hadn't read Leonard Susskind's claim that if you fall into a black hole, you pass through the horizon unharmed in one coordinate system and get incinerated by radiation in another, I would have dismissed it as crackpot nonsense right away.
I don't understand Susskind's example either, but at least there's an event horizon in his example to make things more complicated
Normally I'd agree, but since Meopemuk is a competent poster (at least in the quantum physics forum :smile:), I hope he gets a chance to explain his position.
So if some moderator is thinking about closing the thread, please don't. At least not yet.
All of this is true, but it's still ill-defined. It doesn't unambiguously identify which laboratories produce the same results.
I'm going to get some sleep, so I won't read any answers for at least 8 hours.
You and I are talking about two rather different approaches to relativity. They are based on different sets of postulates. Your (as well as Einstein's and lot of other people's) approach assumes the following postulates:
1. The principle of relativity (never mind that you don't like it, this principle remains true nevertheless).
2. The invariance of the speed of light.
3. The Minkowski space-time manifold in which all events are "embedded" (this postulate can be derived from 1. and 2. if you add the "coincidence condition" that we discussed earlier).
One problem with this logic is that it is not easily compatible with quantum mechanics. One example is the difficulty of defining the "time operator" (which, according to your approach, must exist, because space and time coordinates must be "interchangeable"). This difficulty was discussed in one of recent threads in the "Quantum physics" forum.
I begin from a different set of postulates:
1. The principle of relativity.
2. The Poincare group structure of transformations between different inertial observers.
3. Postulates of quantum mechanics.
In my approach I can also describe events with their space and time coordinates. However, these events are not regarded as points in the Minkowski space-time. The whole idea of the Minkowski space-time is just absent. Transformations of space and time labels of events between different observers can be calculated from quantum laws, and these transformations do not necessarily agree with Lorentz formulas, which are assumed exact and universal in your approach. Moreover, if one observer sees an event (e.g., an explosion or a collision of particles), another observer may not see it. The "coincidence condition" is not valid.
As far as I can tell, experimental consequences of the two approaches are pretty close. I couldn't find experiments, where predicted differences can be measured with modern tools. So, which approach is better should be decided on the basis of logic and consistency. You can make your own judgement.
Fredrik said:
Normally I'd agree, but since Meopemuk is a competent poster (at least in the quantum physics forum ), I hope he gets a chance to explain his position.
Thank you, Fredrik. I appreciate that.
Eugene.
It's not that I don't like the principle of relativity. It's just that it's ill-defined, and therefore useless as a mathematical axiom. 3 can't be derived from 1 and 2. It can be guessed from 1 and 2. Alternatively, we can interpret 1 as a set of well-defined statements and then determine which members of the set are consistent with the assumptions a) that spacetime is the set [itex]\mathbb R^4[/itex] with the standard manifold and vector space (or affine space) structure, and b) that functions that represent a change between coordinate systems are smooth and take straight lines to straight lines. These assumptions can be weakened, but it's definitely never correct to start with an ill-defined axiom.
Both of the approaches I described lead to 3, but the steps that take us from 1 and 2 to 3 (a guess, or a derivation based on clarifying and supplementary axioms) are not a part of the definition of the theory. The theory is defined by axioms that tell us how to interpret the mathematics of Minkowski space as predictions about results of experiments. (But there's of course a rigorous version of 1 and 2 that's implied by the definition of Minkowski space).
Not true. The only operators that must exist because of what I've said are the ones that can be constructed from the Poincaré algebra. The fact that Minkowski space has a non-trivial group of isometries make it obvious (once you understand the math, as I think you already do) that we should change the axioms of quantum theory to include the axiom that there's a group homomorphism from that group (the Poincaré group) into the group of probability preserving bijections on the set of unit rays. Wigner's theorem takes care of the rest.
It's hard to see a difference between this and my approach, other than that you choose not to mention Minkowski space. I think the proper way to do that is to use the algebraic approach to QM. As I said in #42, according to this article (which I have only skimmed...I intend to return to it later), it's actually possible to reconstruct Minkowski spacetime from the Poincaré algebra (and the axioms of the algebraic approach).
Yes, it does, all of the experimental results must be the same regardless of which coordinate system is used.
The bomb either explodes or does not explode based on the action of some set of physical laws from some set of boundary conditions. The coordinate system that you use to express those laws and those boundary conditions must lead to the same experimental outcomes in all cases. Otherwise you have violated the first postulate.
As long as the rest observer also predicts that the moving observer measures a non-zero probability and the moving observer also predicts that the rest observer measures a zero probability then this is standard fare for SR.
I also have a nagging suspicion that this is a large miscommunication. Usually I am better at understanding what is being proposed than in this thread.
Yes, it seems like a good approximation, but why do you think the associated error is less than the obtained effect?
