Converting Galvanometer to Ammeter: Resistance Wire Placement
The discussion focuses on converting a galvanometer with a resistance of 150 ohms and a full-scale deflection current of 3 milliamperes into an ammeter with a range of 0 to 6 amperes. To achieve this, a uniform resistance wire of 60 cm length and 2 ohms is utilized. The key equation discussed is s = IgG/(I - Ig), which determines the configuration of the resistance wire. It is established that the resistance wire should be connected in series with the galvanometer to ensure accurate current measurement.
  • Understanding of galvanometer operation and specifications
  • Knowledge of series and parallel circuit configurations
  • Familiarity with Ohm's Law and electrical resistance calculations
  • Basic grasp of current measurement techniques
  • Research the principles of galvanometer conversion to ammeter
  • Learn about calculating total resistance in series circuits
  • Explore practical applications of ammeters in electrical measurements
  • Study the effects of resistance wire placement on circuit performance
Students in electrical engineering, hobbyists working on circuit projects, and anyone interested in practical applications of galvanometers and ammeters.
zonie
how will you convert a galvanometer of resistance 150 ohm giving a full scale deflection for a current of 3 milli ampere to a ammeter of range 0 to 6 ampere?a uniform rsistance wire of length 60cm and 2 ohm is given.find the length of the wire required?
s = IgG/I-Ig
Should we connect a piece of the resistance wire in series or in parallel with the galvanometer? Why do you think so?
  • · Replies 18 ·
15K
