Calculating Gauge Pressure at the Bottom of a Test Tube
The discussion focuses on calculating the gauge pressure at the bottom of a test tube containing 3.8 cm of oil with a density of 0.81 g/cm³ and 6.4 cm of water. The formula used is P1 - Po = ρ_oil * g * h1 + ρ_H2O * g * h2, leading to a calculated gauge pressure of 929 Pa. The participants confirm the correctness of the calculation and clarify the notation used in the equations, emphasizing that gauge pressure is calculated relative to atmospheric pressure.
  • Understanding of fluid mechanics principles
  • Familiarity with gauge pressure and absolute pressure concepts
  • Knowledge of density units and conversions
  • Proficiency in using the equation of hydrostatic pressure
  • Study hydrostatic pressure calculations in various fluids
  • Learn about the effects of atmospheric pressure on gauge pressure
  • Explore fluid density variations and their impact on pressure readings
  • Investigate applications of gauge pressure in real-world scenarios
Students in physics or engineering courses, educators teaching fluid mechanics, and professionals involved in pressure measurement and analysis.
DrMcDreamy
A test tube standing vertically in a test tube rack contains 3.8 cm of oil, whose density is 0.81 g/cm3 and 6.4 cm of water. What is the gauge pressure on the bottom of the tube? The acceleration of gravity is 9.8 m/s2. Answer in units of Pa
P1-Po=\rhooilgh1+\rhoH2Ogh2
P1-Po= (810 kg/m3)(9.80 kg m /s2)(0.038 m) + (1000 kg/m3)(9.80 kg m/s2)(0.064 m)
P1-Po= 929 Pa
Is the work and answer right? TIA
They are indeed correct.
Thank you! :smile:
Actually, I wonder whether you should also consider atmospheric pressure.
Also, why is it P1-P0 and not +?
^It came out right with 929 Pa.
The way the prof had shown it in class is P1-P0:
P2=Po+\rhooilgh1
P1=P2+\rhoH2Ogh2
P1=Po+\rhogh1+\rhogh2
P1-Po=\rhogh1+\rhogh2
Oh ok, it was down to notation, then.
When I thought you might need the atmospheric pressure is because I was calculating P1, but you needed P1-P0. :)
