Gauss' Law Help don't even know where to start
The discussion revolves around calculating the outward electric flux through the ends of a cylinder in a uniform electric field. The electric field is defined as E = 250 N/C for x > 0 and E = -250 N/C for x < 0. Initially, the user attempted to integrate the surface area of the entire cylinder, which led to incorrect results. The correct approach involves calculating the area of each circular end and multiplying it by the respective electric field at that end. Ultimately, the user realized that only the end areas were needed for the flux calculation.
miniMitts27
An electric field is E = 250 N/C i for x > 0 and E = -250 N/C i for x < 0. A cylinder of length 20 cm and radius 3 cm has its center at the origin and its axis along the x-axis such that one end is at x = +10 cm and the other is at x = -10 cm.
What is the outward flux through each end?
a) +x end
b) -x end
I tried integrating the surface area of the cylinder, then multiplying by the electric field within that area but it's not correct... so a starting point or walk-through would be greatly appreciated.
What do you mean? Did you find the area of each circular end surface?
That should work, assuming you have the correct signs.
Show what you did.
I figured it out actually. They were just looking for the flux through the very end, so I only needed to find the area of the end of the cylinder, then multiply that by the electric field. I was integrating the surface area of the entire cylinder and then multiplying the charge by that. Obviously a very different number.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 26 ·
