The Mystery of the Missing Pi Phase Shift in Gaussian Beam Interference
The discussion centers on the phase shift observed in Gaussian beam interference, specifically the unexpected absence of a predicted π phase shift in the derived expression. The superposition of a Gaussian beam and a plane wave results in an interference pattern where intensity minima and maxima invert, yet the mathematical formulation does not reflect this phase shift. The key equations involve the Gouy phase and the interference term, which does not exhibit the anticipated π change, leading to confusion regarding the inversion of fringes. The participants seek clarity on the mathematical implications and potential coordinate-free representations of Gaussian beams.
  • Understanding of Gaussian beam optics
  • Familiarity with wave interference principles
  • Knowledge of phase shifts in wave phenomena
  • Proficiency in mathematical expressions involving trigonometric functions and complex exponentials
  • Study the derivation of the Gouy phase in Gaussian beams
  • Explore the mathematical foundations of wave interference patterns
  • Investigate coordinate-free representations of Gaussian beams
  • Learn about phase shifts in optical systems and their implications on interference
Physicists, optical engineers, and researchers in wave optics who are analyzing Gaussian beam behavior and interference patterns.
davidbenari
The superposition of a gaussian beam and a plane wave generates a pattern of rings whose phase shift before and after the focal plane (of the gaussian beam) is ##\pi##. This means that if you measure interference before and after you'll see the minimums and maximums of intensity invert.
We can create the superposition via
##(e^{-ikz}+\frac{w_0}{w(z)}e^{-r^2/w(z)^2}e^{-i(kz+\frac{kr^2}{2R(z)}-\psi(z))} ) * (e^{ikz}+\frac{w_0}{w(z)}e^{-r^2/w(z)^2}e^{i(kz+\frac{kr^2}{2R(z)}-\psi(z))} )##
The obtained expression is
##1+\frac{w_0^2}{w(z)^2}\exp(-2r^2/w(z)^2) + 2 \frac{w_0}{w(z)} e^{-r^2/w(z)^2} \cos (\frac{kr^2}{2R(z)}-\psi(z))##
Remember ##R(z)=z[1+(z_R/z)^2]## and ##\psi(z)=\textrm{arctan}(z/z_R)##
MY PROBLEM IS:
This equation doesn't predict the pi phase shift!
Consider the argument of the cosine function.
##R(z^+)= R##
At ##z^+##
The argument is
##\frac{kr^2}{2R}-\pi/2##
at ##z=-z^+##
The argument is
##\frac{-kr^2}{2R}+\pi/2##
Now we know ##cos(\theta)=cos(-\theta)## therefore there is no pi phase shift.
But I know as a matter of fact that there should be a pi phase shift( I've observed it!).
But I don't understand what's happening here mathematically.
Any help will be very much appreciated.
Science news on Phys.org
By ##\pi## phase change, they must mean the Gouy phase ##\psi(z)##. As you go from ##-\infty## to ##\infty##, this term undergoes a change of ##\pi##.
Yeah, but the interference term isn't changing by ##\pi## which would explain the inversion of fringes. How else can one explain this inversion of fringes ? The sources I've seen just say "it's due to the gouy phase as can be seen from the interference term".
Is there any way to write a coordinate free gaussian beam so as to make ##k## negative some times? This would fix a lot of things!
  • · Replies 19 ·
  • · Replies 21 ·
  • · Replies 21 ·
