Gδ set in normal space problem
38 replies · 6K views · last reply
micromass said:
Umm, the Weierstrass-M-test didn't work?? You might want to rethink that :smile:
Well, perhaps my resources were a bit bad.
I hate to mention it, but I looked on wikipedia, too :)
http://en.wikipedia.org/wiki/Weierstrass_M-test
according to this, my constant Mn = 1, for every n and x, right? And the series of "1's" does not converge.
Now that I look at Kurepa's analysis book, I find a more sophisticated formulation. Briefly, it says that if every member fk of a series of functions is less (by absolute value) than the corresponding member of a convergent series of positive numbers, then the series of functions fk converges uniformly.
Actually, this is something I need, since I introduced the power series..Hm.
Yes, but in this case you have to find a Mn such that [tex]|2^{-n}f_n(x)|\leq M_n[/tex]. Your series is
[tex]\sum{2^{-n}f_n(x)}[/tex]
isn't it? If the series were
[tex]\sum{f_n(x)}[/tex]
then I'd agree with you. But you've added the [tex]2^{-n}[/tex]...
This is exactly what I was talking about - lack of concentration :)
In this case, it's simple - we end up with a series 1/2, 1/4, etc. i.e. the series of powers of 2, which converges, right?
Yes, that is correct! You've actually solved this problem, I'm amazed :smile: I actually teach topology to a class of undergraduates and I don't think any of them would have found this proof. I think you're a very good mathematician :approve:
That said, I want to make some remarks:
- another way to make one function out of the fn, is by taking the supremum. Thus [tex]f(x)=\sup_{n\in \mathbb{N}}{f_n(x)}[/tex]. But showing continuity is (imo) a a little more tedious then with the series.
- a foreshadowing for later: you will use the same technique in the proof of the Tietze extension theorem. But there, the construction of the right series will be a bit more difficult.
wow, thanks a lot!
I'll post the whole solution tomorrow. Right now, I can't think of anything anymore, but I'll look at the alternative proof tomorrow, too. :)
Hmm, forget about my alternative "proof". It obviously doesn't work. I guess it's getting late for me to :smile:
Here, for convenience, I'll just sum up the sketch of the proof of the other direction.
Let A be a closed Gδ set in X, so it equals a countable intersection of open sets in X. For any positive integer m, define Am = [tex]\cap_{i=1}^m A_{i}[/tex]. Further on, for any positive integer m, apply the Urysohn lemma to the disjoint closed sets A and X\Am in order to obtain a continuous function fm such that fm(A) = 0 and fm(X\Am) = 1. So, we obtain a sequence of continuous functions {fm}.
Now, for every positive integer m, define Sm = {x in Am\A : fm(x) = 0}. Then fm^-1({0}) = A U Sm[tex]\subseteq[/tex]Am, for every m. Now, [tex]\cap_{m}[/tex](A U Sm) = A U ([tex]\cap_{m}[/tex]Sm) = A, which implies [tex]\cap_{m}[/tex]Sm = [tex]\emptyset[/tex]. So, for any x in X, there exists some positive integer m such that fm(x)[tex]\neq[/tex]0. This motivates the following definition:
Define h(x) = [tex]\sum_{k=1}^{\infty}\frac{1}{2^k}f_{k}(x)[/tex]. It is easily checked that for any x in A, h(x) = 0, and for any x in X\A, h(x) > 0. Also, one can show that this series converges uniformly, and that its sum (i.e. h(x)) is a continuous function.
