GE Dielektrol Capacitor Popping Sound While Charging
The discussion centers on a GE Dielektrol capacitor rated at 40,000 volts and 1.85 microfarads, which produces a popping sound during charging at voltages exceeding 2000 volts. The user employs a neon sign transformer and a variac, with a bridge rectifier using 12 kV diodes. Concerns arise regarding potential dielectric failure, as the capacitor's capacitance has decreased from 1.88 to 1.54 microfarads, possibly due to temperature changes. Recommendations include contacting GE for expert advice and ensuring proper grounding and safety measures when handling high-voltage capacitors.
  • Understanding of high-voltage capacitor operation and safety
  • Familiarity with neon sign transformers and variacs
  • Knowledge of bridge rectifier circuits using high-voltage diodes
  • Basic principles of capacitance and dielectric materials
  • Research proper grounding techniques for high-voltage capacitors
  • Learn about dielectric materials and their behavior under temperature variations
  • Study the effects of internal short circuits in capacitors and safety precautions
  • Investigate the use of charging resistors with neon sign transformers
Electronics enthusiasts, electrical engineers, and anyone working with high-voltage capacitors who seeks to understand capacitor behavior and safety measures during charging.
workinprogres
Hey everyone, so I just bought a used GE Dielektrol capacitor rated at 40,000 volts and 1.85 microfarads, and while I'm charging it up there is a popping sound that appears to be coming from inside the capacitor. It only occurs at voltages over about 2000 volts and only while the capacitor is charging. As soon as I disconnect one of the charging wires it goes silent. I'm using a neon sign transformer driven by a variac and run through a bridge rectifier consisting of 12 kv diodes so there is a ground potential from the charging wires but I don't know if this would have anything to do with it. The capacitor holds a charge and has no problems discharging. Also the capacitance has also decreased since I bought it from 1.88 to about 1.54 but I think that may be due to temperature because it's been in my near freezing garage for a day but before it was kept at room temperature (about 70 degrees). I'm a little scared the the dielectric might be failing but I don't really know. Any advice would be helpful, Thanks in advance!
I think you're right to be concerned - could something be delaminating within the cap? I'd contact GE directly and try to find someone knowledgeable on that design. Don't forget that some HV caps, even when you think they are fully shorted, will 'self charge' to some intermediate voltage. (I had a nasty shock one time...). Make sure both electrodes are shorted to each other and Earth ground to safe them.
I sure hope the cap isn't falling apart inside. I'm probably going to call G.E. tomorrow but in the mean time I've brought the cap back inside to see if the capacitance will go back up. Hopefully it will or otherwise I've got even more problems. I'm wondering if maybe the dielectric inside is changing volume with the temperature and moving the conductive plates around or letting holes form or maybe even not absorbing into the dielectric material. And thanks for the tip on HV caps charging themselves with a ground potential! I never would have thought that that might happen but now that I think about it the Earth would make quite the capacitor :)
After making a few calls and some experimentation it turns out I couldn't just use the NST's current limiting and needed a charging resistor.
Good to hear. Make sure you have not damaged the cap - I'd recommend shielding it with
something to stop shrapnel if it decides to dump all its energy with an internal short...
